How to remove applications from Smart TV LG 47LB650V-ZN running webOS 1.3.2-3232
jaceksz777 36081 2
  • #1 14572845
    jaceksz777
    Rate: 50
    Hello, as in the topic of how to remove applications from the LG 47LB650V-ZN Smart TV with webOS 1.3.2-3232. I want to remove applications, but I do not know how if someone knows how to do it, please help me.
  • #2 14573130
    KOCUREK1970
    Help: 3862
    Rate: 5492
    Why do you want to delete anything?
  • #3 14573642
    jaceksz777
    Rate: 50
    Because some applications are not needed, but I have already solved the problem, so I close it and for those who will have a similar problem, a few words of explanation on the remote control, press the MY APPS button and our installed applications will be displayed, select the applications to be removed with the direction buttons on the remote control, select up a cross will appear above the application, we put it up again and confirm with the OK button on the remote control and our application is removed. And all this, I hope someone will find it useful.
