  • #1 14618147
    And!
    Admin of Design group
    Help: 175
    Rate: 785
    The Internet of Things can be built on many different solutions, below are some inspirations. What other platforms can you recommend for IoT ?
    IoT according to Atmel (25 proposed platforms for building IoT devices)
    Not all of the proposed platforms have a wireless, or Ethernet interface, but they can easily be equipped with a WiFi, Bluetoth or other module that allows connectivity to an internet-connected hub.
    SAM R21 Xplained Pro
    Arduino Uno
    Arduino Yún
    Arduino Pro Mini
    Arduino Nano
    Pinoccio
    TinyDuino
    UDOO
    Libelium Waspmote
    The AirBoard
    Tessel 2
    panStamps
    Flutter
    SODAQ
    IMUduino BTLE
    SparkFun RedBoard
    XinoRF
    The Rascal
    Microduino
    Nanode
    OpenKontrol Gateway
    Arietta G25
    WIOT
    SmartEverything
    Apio
    TI test kits - connected launchpads
    CC3200-LAUNCHXL
    EK-TM4C1294XL
    CC3200MOD-LAUNCHXL
    Freescale IoT center
    STM Nucleo
    NUCLEO-L053R8
    X-NUCLEO-IDB04A1
    Microchip IoT demo WCM Development Kit 1
    we-io
    rascal
    Intel IoT
    Many of the mini-computers could work as part of the IoT:
    https://www.elektroda.pl/rtvforum/topic3020260.html
    What other platforms can be used for IoT ?
    pancio
    Help: 14
    Rate: 13
    A great platform to start with would be the standalone ESP8266 - comes in various versions, with IP stack, WIFI. Decent price (from $2) allows for IoT madness :-)
    AzureWave AW-CU282A and AW-CU288 IoT modules
    #5 14787688
    KeinXor
    Help: 62
    Rate: 63
    Azurewave AW-CU282A
    MCU: Cortex M3 200MHz
    Wi-Fi: 802.11 b/g/n 2.4GHz
    Antenna: 1x1 Diversity
    Interface: UART / SPI / I2C / JTAC
    Form factor: Solder Down Module
    Low Power Solution
    Dimension: 23.11 x 42.67 x 2.3mm
    and
    Azurewave AW-CU288
    Interface: UART / SPI / I2C / JTAG
    Low Power Solution
    Dimension: 18 x 36 x 2.5mm
    www.azurewave.com
    TINY-Tiger 2 offers extensive IoT interfaces
    #6 14801754
    KeinXor
    Help: 62
    Rate: 63
    TINY-Tiger™ 2 Multitasking Computer
    2 MByte or 4 MByte FLASH for program and data
    1 MByte SRAM with Backup Input
    56 I/O Lines overall
    40 universal digital I/O bitwise programmable as In- or Output, Expansion Bus, Timer, Counter and Encoder
    2 serial UART-interfaces with Hardware Handshake
    Multi-channel serial Soft-UART with or without Handshake
    12-channel 10-bit Analog/Digital Converter Inputs
    CAN Bus 2.0
    I2C Bus, SPI, Microwire
    2-channel PWM
    Real Time Clock, ultra low power with separat Battery input and alarm output
    Fast downloads: Standard download with 115,200 baud, Fast download with 307,200 baud
    TINY-Tiger
  • #7 16252325
    krzbor
    Help: 43
    Rate: 1073
    Also worth noting is the ESP32 - the successor to the ESP8266. It has two cores, Wi-Fi as well as Bluetooth, sensor inputs, A/D and D/A converters and many other interesting things.
  • ESP32 features and module options for IoT
    #8 17912868
