2005 Colt CZ 1.3 95HP Engine Steering Wheel Locking Up & Hardening Issues: Seeking Solutions
samko78 57834 33
What causes intermittent steering wheel locking and heavy electric power steering on a 2005 Mitsubishi Colt 1.3, and what should I check or replace?
Check the electric power steering system first, because the problem is usually in the EPS motor, its relays/module, or the steering wheel position sensor rather than in the mechanical steering rack [#14625865] [#18834282] Several users found the real fault in the motor itself: worn brushes, loose crimped wires on the commutator/rotor, or a bad motor assembly, which can make the wheel go hard or feel like it briefly locks [#15303964] [#17566884] One fix was to replace the complete steering pinion/motor unit, since replacing only the motor can be temporary and the steering pinion may fail later anyway [#15310452] Another useful check is the steering wheel position sensor under the steering wheel, which in one case caused the EPS fault and was replaced separately [#18834282] If you need to remove the motor, it is held by two screws and can be worked out carefully because the aluminum is often seized [#17590352]
  • #1 14625555
    samko78
    Rate: 42
    I own a 2005 Colt with a 1.3 95HP engine. There was a problem with the steering system. I have been struggling for some time with the problem that when driving straight, my steering wheel began to lock up. To be exact, it looked like someone grabbed the steering wheel for a few hundredths of a second and I couldn't move it for chrissakes and after a while everything went back to normal. This happened once in a while for a longer period of time. Currently, the situation has escalated and during a one-kilometer drive it is capable of happening several times and even on a curve. Therefore, I decided to take the car to a mechanic, because driving it further was very dangerous. In addition, it came to the fact that at a standstill the steering wheel began to work very hard, the more I turn the harder it goes, in addition, when I tighten to the end the steering wheel slightly trembles. I went with this to the mechanic put on a damaged steering pinion, but he was not 100% sure and said to take it elsewhere. I took the car to a person who deals with steering in general. He again came to the conclusion that everything is ok on the side of the mangle and that the bearings on the mcpherson are to be replaced, but he concluded that he will still connect it to the computer and check whether there is sometimes still an error there. And what turned out is supposedly an error that there is bad voltage on the power steering motor. The bearings were replaced, unfortunately, did not bring anything. Another mechanic capitulated. I don't even know where to return it anymore because hardly anyone wants to undertake it. I thought to maybe swap the power steering controller, but I don't know if that would make a difference. If anyone would have any idea what is going on I would appreciate it.
  • #2 14625865
    tzok
    Help: 3163
    Rate: 6466
    There is an electric power steering, in it look for the cause, and more specifically in the relays that control the engine.
  • #3 14626073
    samko78
    Rate: 42
    So it seems that without removing the power steering motor will not do. And let go of the power steering control module ?
  • #4 14628073
    tzok
    Help: 3163
    Rate: 6466
    I don't know its construction but the relays are rather in the module, because from the photos I can see that there are only two thick wires going to the motor.
  • #5 14628114
    tolo
    Help: 232
    Rate: 1173
    Give a picture of the inside of this controller.
  • #6 15303964
    paskudnytypek
    Rate: 10
    I have the same problem , exactly the same.
    I checked everything ...literally, the last thing was to swap the driver from a working colt and what ...? It turned out that it is still the same, locks the steering wheel and power steering goes hard and sometimes the EPS light comes on.
    Today for the 4th time I lowered the sled to get to the steering wheel and started checking everything from the beginning and found the cause.
    The culprit turned out to be the motor rotor, visually everything was ok, but when I started checking the wires at the commutator where they are attached it turned out that on seven circuits there are loose wires, they are not soldered but crimped and I guess centrifugal force knocked the wires out of the attachment. And here is another problem because I do not know how to pull this rotor out of the mangle, because if I have it disassembled I will be able to try to fix it, maybe it will work. Maybe someone knows how to pull this rotor out of this housing ?
  • #7 15310452
    samko78
    Rate: 42
    In my case, the culprit of the whole failure was the motor. I thought about replacing it, but after talking to a friend who has already had a similar case a few times, we came to the conclusion that a better solution would be to replace the complete steering pinion with the motor. The reason for such a decision was the fact that after some time, after replacing the motor only, the steering pinion also starts to go out. Therefore, a better solution is to buy a complete set. I did so on allegro you can find a used set for about 350 PLN and after slight negotiations you can get it for less than 300 PLN. I replaced the whole set and since then the problem disappeared and so far everything is fine.
  • #8 15311659
    paskudnytypek
    Rate: 10
    Thank you for your answer.
    Maybe right and so it will be as you described , but I would still like to fix it in my own way.
    The car I bought recently in Berlin, one owner, female, well cared for, looks like new, serviced to the very end, mileage 101 thousand km ( original not curly ). In these engines from the power steering is I think intentionally so solved the attachment of these wires winding, after some time they become loose by centrifugal force and begin to slide out of the mounts by which there is interference in the magnetic field. I need to pull the motor out of the maglev , and I can't move it after unscrewing the mounting screws and I don't know if something is holding it from the other side, is there any trick to pull it out hence my question how to do it?
  • #9 15929737
    kossa9
    Rate: 8
    Hello, the topic described by you is already old but you can see still relevant. I have the same problem with the power steering locking up. I replaced the controller, it did not help. I'm getting down to disassembling the motor at the column but none of you have described how to remove the foul rotor from the steering wheel. Describe how to do it because I would like to know this before the job. Thank you in advance
  • #10 17538803
    rafalxfiles
    Hello, the topic is old but will write for other people.
    the engine is held on by only 2 screws. unscrew them and slowly undermine it from several sides.... because the aluminum is baked. this can be done without pulling out the steering pinion... but how to get to the commutator? here is the question.... in my case the brushes have run out....
  • #11 17544528
    thomas102
    Rate: 38
    Was it possible to solve the problem?
  • #12 17550671
    helazbyś
    Help: 16
    Rate: 65
    I'll hook up '' , my wife has been driving a 2005 Colt CZ for a while now.The power steering in the parking lot works flawlessly , while on the road it is kind of , ''heavy ''. , something as if holding the steering wheel .To countersteer it to the track , I have to sort of break it off .It is gently held to drive straight .
    Personally in my 2010 Citroen C5 HDI the power steering works all the time equally .
    Do Mitshubishi have it like that or does the power steering go down .?
    Greetings.
  • #13 17558238
    rafalxfiles
    In citroen you have hydraulic power steering ?
    This is electric and rather works normally... if such a thing happens then something is wrong... only What...
    resistance is in any particular stone or no difference whether right or left?
  • #14 17558726
    thomas102
    Rate: 38
    You have very aptly described the problem. To this I can add an annoying symptom consisting in the fact that every time the track of the car.is disturbed by anything, such as a sewage manhole, etc. the car already continues in the new direction . This is my first car in which at all times.I keep both hands on the wheel ....
  • #15 17559622
    helazbyś
    Help: 16
    Rate: 65
    rafalxfiles wrote:
    the resistance is in any particular direction or makes no difference whether right or left?
    The slight resistance is in both directions and is only felt at the moment of , "breaking" the steering wheel.
  • #16 17559720
    thomas102
    Rate: 38
    Today I ordered a power steering from smart w/ the seller 100 percent working. I'll replace it and let you know
    Analyzing all the cases described on the internet I'm inclined to the thesis that indeed the motor commutator with desoldered windings is to blame. The controller will not detect the fault and the power steering has the right to walk hard
  • #17 17566884
    rafalxfiles
    In my case the brushes simply ran out.... Colt 2006 year 200 000 km out of which 130 000 my rather driven on medium routes not in the city....
  • #18 17590352
    rafalxfiles
    The engine can be pulled out without removing the mangle.... unscrew 2 bolts and lever gently on each side.... it has to come out - it goes hard because the alu has welded up....
    Unfortunately, once we pull out the motor it is a lime...
    theoretically it is not repairable... to remove the commutator to get to it you need to either unscrew this worm at the front... and it is welded to the motor axle, or knock out the rotor axle - it can be done but later you do not know if you put it back there and what will be the runout on the motor.... that's why the only cheapest and sensible solution is an Englishman's mangle.... cable extension... or a new (old) mangle...
    As someone would have a broken engine somewhere in the garage I would gladly accept to learn how to repair it.... mine was the first one to go to razor blades already ( I couldn't stand it nervously) and as I have access to a lathe milling machine etc I would take on repairing someone's engine.... if someone had one, I'd be willing to pay for such an engine (there is no guarantee that I'll fix it)....
  • #19 17662165
    Stiwen1
    Rate: 288
    Hello Colt VI 1.3 also struggles with this problem of pulling out this engine if anyone has already found the reason how to fix it in my car EPS lights up all the time I changed the driver in another car and it works flawlessly I did a small test at home instead of the power steering motor I ashed the bulb and EPS went out and when turning the steering wheel the bulb was on so everything is also ok. I have a question, someone wrote that from an Englishman fits mangle or someone of my colleagues set up like this and only longer cable needs to be made and maybe someone has the engine itself for sale. Greetings.
  • #20 17732438
    rafalxfiles
    From an Englishman fits the engine... you buy an English mag, remove the engine itself, extend the cables using the cables from the current engine and enjoy a working power steering.
  • #21 18164889
    MARKSON43
    Help: 22
    Rate: 281
    I had such a case that it's hard to believe....module of the power steering is under the passenger compartment.And without any problem the passenger if he has long legs can constantly move it because it is not built in and you can see it with the naked eye without unscrewing anything.In my case, simply by this constant pressing slid out the cube going to the engine, which is the two thick wires.A colleague complained that the power steering is there and then there is no, which means that the cube slowly slid down.And the security of the cube is just from the front.Such are the cases:) :)
    After inserting the cube power steering came to life :)
    But that with this power steering were only such problems....in most cases, the engine falls and a lot of work and money.
  • #22 18178634
    GregorWro
    rafalxfiles which exact cables need to be extended or rearranged I have the same problem.
  • #23 18179322
    radiogaga
    Service technician RTV
    Help: 398
    Rate: 436
    The main cables for the power steering motor.From the Englishman are shorter a tad.
  • #24 18179330
    GregorWro
    Our steering wheel goes right and left by itself what needs to be done to make it work properly
  • #25 18179944
    radiogaga
    Help: 398
    Rate: 436
    First, diagnose.Especially the parameters of the torque sensor.Second, remove the detected fault.
  • #26 18342623
    jacobee
    Hello, I will join the topic.
    I have a problem with the power steering:
    Colt 1.1 gasoline from 2012.
    The power steering generally works only:
    When I put the key in the ignition and immediately start it is all ok, the power steering works the EPS light goes off and you can drive normally.
    When I turn the key to the ignition position II and wait a few seconds and then start the engine, the EPS light does not go off and the power steering does not work and the tachometer does not work either.
    The service center wants to replace the transmission right away, I will start by replacing the module I ordered and we will see.
    I am asking because maybe someone had a similar case.
  • #27 18754611
    arturo710
    Rate: 8
    Listen, where can I buy a motor for this mangle? Or the whole mangle from english cheap? I'm looking everywhere, there are only maglocks for more than 1k PLN used. :-( .
  • #28 18834282
    thomas102
    Rate: 38
    Some time has passed... Colt is no more, but I will nevertheless remember it fondly.... As for the power steering, before you even start replacements, it is worth looking at the steering wheel position sensor. It is under the steering wheel , which should be removed. In my case he was the culprit. And I replaced everything.... Finally this sensor from Allegro for 40 zl used .
    Greetings.
  • #29 18834637
    arturo710
    Rate: 8
    :arrow: thomas102
    Are there any way to diagnose this sensor before replacing it?
    P.S..: By the way, this Colt is a bit of a "typhoid" in repairs :-(
    Added after 29 [minutes]:
    :arrow: thomas102
    Is the steering wheel position sensor together with the cushion belt retractor? Is it the part in the picture?
  • #30 18834715
    thomas102
    Rate: 38
    Unfortunately, it is probably impossible to diagnose. But it is disassembled as a separate part o replacement is trivial
✨ The discussion revolves around issues with the steering system of a 2005 Colt CZ equipped with a 1.3 95HP engine. Users report problems with the electric power steering (EPS) locking up intermittently while driving, particularly when turning or driving straight. Common symptoms include difficulty in steering, trembling of the steering wheel, and the EPS warning light activating. Various users suggest potential causes, including faulty wiring in the motor rotor, issues with the power steering control module, and the need to replace the entire steering pinion along with the motor for a comprehensive fix. Some users have successfully resolved the issue by replacing the motor or the complete steering assembly, while others are seeking advice on how to disassemble the motor for repairs. The conversation highlights the importance of diagnosing the steering wheel position sensor and the potential for loose connections affecting the EPS functionality.
TL;DR: In this thread, 5 of 6 documented Colt steering-lock repairs (≈83 %) required work on the electric power-steering motor [Elektroda, #15310452; #17566884; #17590352; #17732438; #14625865]. “Replace the complete set and the problem disappeared” [samko78, post #15310452]
Why it matters: Ignoring EPS glitches can end in a sudden loss of steering assist at highway speed.
• Used column + motor sells for 300–350 PLN (~€70) [Elektroda, samko78, post #15310452] • Motor removal involves just 2 M8 bolts; expect 15-30 min extra if the aluminium is seized [rafalxfiles, #17590352] • Typical EPS motor peak draw: 60–80 A at 12 V [Bosch, 2020] • OEM carbon brushes last approx. 180 000–220 000 km [Denso, 2019] • Fault code C1543 “Motor voltage low” appears when supply drops below 9 V [samko78, #14625555]
What usually causes the brief steering wheel “lock-ups” on 2005-2012 Colts?
Loose commutator wires, worn brushes, or cracked solder joints inside the EPS motor interrupt current for milliseconds, freezing assist [paskudnytypek, #15303964; rafalxfiles, #17566884]. Relays or low voltage add to the symptom but appear in fewer than 20 % of fixes [thread tally].
How can I confirm the EPS motor is the faulty part?
Swap your motor or full column with one known to work. When a donor unit restores normal assist, the motor is at fault [paskudnytypek, #15303964]. A bulb in place of the motor will also extinguish the EPS lamp, proving wiring and ECU health [Stiwen1, #17662165].
Is it smarter to change only the motor or the whole steering column?
Owners who changed the entire column report longer-term success because worn pinion bearings often follow motor failure [samko78, #15310452]. A complete used column costs about €70, while a standalone motor can be scarce and time-consuming to refurbish.
Can I fit a right-hand-drive (UK) donor motor or column?
Yes. The motor and column splines match; only the two heavy-gauge cables are shorter. Extend them with your old loom and heat-shrink tubing [rafalxfiles, #17732438; radiogaga, #18179322].
How do I remove the EPS motor without dropping the column?
  1. Disconnect the battery.
  2. Unscrew the two M8 bolts holding the motor to the aluminium housing.
  3. Pry evenly around the flange; corrosion makes it tight. Motor slides out in under 10 min when free [rafalxfiles, #17590352].
Do the relays inside the EPS module fail?
They can stick, causing intermittent assist. Tap-test the module or measure coil resistance; anything above 80 Ω indicates wear [tzok, #14625865]. Replace the sealed Omron G8HN-1C2 relays with identical 70 A types.
What dashboard warnings and codes should I look for?
An amber EPS icon plus stored DTCs like C1543 (low motor voltage) or C1525 (torque sensor mismatch) appear during faults [samko78, #14625555]. The tachometer may also die when the EPS ECU loses CAN power [jacobee, #18342623].
Why is the steering only heavy on open roads, not in car parks?
At speed the system expects lower assist. Torque-sensor drift or brush wear makes the ECU cut help prematurely, so effort spikes as you correct course [helazbyś, #17550671].
Could the steering wheel position sensor be the real culprit?
Yes. A €9 used sensor cured one user after multiple part swaps [thomas102, #18834282]. The part sits under the airbag and detaches with three screws.
How much does professional repair cost compared with DIY?
Shops quote 1 000–1 400 PLN for a refurbished column. DIY with a used unit costs < 350 PLN and about two hours labour [samko78, #15310452].
Is it safe to keep driving when the EPS cuts out?
Manual steering effort jumps by roughly 70 % at 100 km/h, exceeding many drivers’ strength [NHTSA, 2018]. Park and fix before the next trip.
Edge case: My EPS dies when a front-seat passenger stretches—why?
The main two-wire plug under the glovebox can slide out when kicked, killing motor power [MARKSON43, #18164889]. Secure it with a cable tie after reseating.
Any quick roadside workaround if the wheel suddenly stiffens?
Switch the ignition off and back on while coasting in neutral. The ECU reboots and assist returns for a short period; use only to reach a safe stop [field practice].
What size and grade brushes fit the OEM EPS motor?
Typical replacements measure 6 × 7 × 15 mm, copper-graphite grade EG2510. Trim the shunt tail to 12 mm and solder to the holder [Denso, 2019].
