[Solved] Steelseries Rival 110 Mouse Cursor Jamming: Solutions for Windows 10, AMD Ryzen 3 1200
aragox078 28425 17
Why does my Steelseries Rival 110 mouse cursor keep cutting out in Windows 10, and what should I check besides the cable?
The most likely cause is a faulty mouse or sensor/cable issue rather than Windows 10 or the Ryzen PC, so first test it on another computer or from a Linux live USB to isolate the fault [#18012670] [#18012998] If it still glitches there, return it under warranty; one user reported the Rival 300 was replaced this way, and the advice was to describe the real symptom as cursor/sensor cutting out and include the proof of purchase [#18013009] [#18013057] If you cannot test elsewhere, cleaning the mouse inside with alcohol was also suggested [#18012670] Another possibility raised was the mousepad, so try a different surface as well [#18042552]
  • #1 18012458
    aragox078
    Rate: 23
    Hello!
    I have a mouse Steelseries Rival 110 and for a long time I have been facing the problem where the mouse sensor just cuts, whether in games or browsing the internet. The cable is fine, plugging it into another USB hub helped, but only for a few minutes. What else could be causing this? The system I use is Windows 10
    Specification:
    Processor: AMD Ryzen 3 1200
    Graphics: Palit GTX 960 JetStream 2GB
    RAM: Patriot Viper 2x4GB DDR4 3000MHz
    Motherboard: Gigabyte B450M DS3H
    HDD: Seagate Barracuda 1TB
    SSD: Patriot Buster 240GB
    Power supply: SilentiumPC Vero L2 Bronze 500W
    Kamil532
    Have you tried to connect to another computer? If you have the opportunity to disassemble the mouse, unscrew it and clean it inside with alcohol
    enhanced
    Help: 963
    Rate: 883
    And you do not have shit on the computer that would overload it in an excessive way?
  • #4 18012942
    aragox078
    Rate: 23
    I cannot unscrew it or connect it to another computer. As for the crap on the computer, I recently did the format, so it is unlikely that I have crap on the computer.
    enhanced
    Help: 963
    Rate: 883
    Check on linux live from pendrive yet. Because nothing else can be done.
    gandalfero
    Rate: 17
    I had a similar problem with the Rival 300. I gave the mouse back under warranty and they replaced it with a new one without any problems. The new one is flitting as it should ;)
  • #9 18013026
    aragox078
    Rate: 23
    I bought the mouse from RTV EURO AGD, it is still under warranty, so you can try it. Just what to write in the description of the problem? That the mouse sensor is jamming?
    Kamil532
    In the description of the problem, write what is actually the problem, i.e. the sensor jamming, because if you think up somehow, they may think that you are trying to extort them for a free repair. If the mouse has no mechanical damage, they should take it under the warranty and they will probably replace it with a new one, also remember that for the warranty you need a proof of purchase (receipt), because that's the thread from the warranty
  • #12 18013138
    aragox078
    Rate: 23
    I gave everything as it should, I gave a photo of the receipt, all you need to do now is wait.
  • #13 18042307
    aragox078
    Rate: 23
    I received a new mouse from the store, however I have the same problem again. It must definitely be the fault of some software that the mouse keeps cutting every now and then. But what?
  • #15 18042457
    aragox078
    Rate: 23
    I have already used this guide, but it did not bring any positive results
    haderach
    Help: 118
    Rate: 181
    Either fickle mice or a mousepad :)
    Robert B
    Help: 2027
    Rate: 1412
    And I have another question. Is the drive operation light illuminated during these jams? Observe.
    In addition, it would be appropriate to write about the hardware configuration, which is required in this section:
    https://www.elektroda.pl/rtvforum/topic2996917.html
    BTW:
    Not the sensor jamming, only the cursor. Correct the topic title and your own naming.
  • #18 18072748
    aragox078
    Rate: 23
    A new mouse has arrived and it works like a glove. Thanks a lot to everyone for your commitment and help in this topic :)
The discussion revolves around issues with the Steelseries Rival 110 mouse, specifically cursor jamming on a Windows 10 system with an AMD Ryzen 3 1200 processor. Users suggested various troubleshooting steps, including testing the mouse on another computer, cleaning the mouse internally, and checking for software conflicts. The original poster confirmed the mouse was under warranty and received a replacement, but the problem persisted, leading to speculation about potential software issues. Additional advice included checking the mousepad and observing the drive operation light during jamming incidents. Ultimately, the user reported that a new mouse resolved the issue.
TL;DR: Rival 110 launched in 2017; "linux is the best choice" to isolate OS issues. Try rear USB ports, disable USB selective suspend, adjust polling rate, update AMD chipset drivers, and test on Linux Live. If it still freezes, claim warranty. [Elektroda, Anonymous, post #18013018]
  • Typical gaming-mouse polling rates are 125/500/1000 Hz; 1000 Hz equals 1 ms response. Lowering rate can smooth stutter. [Razer, "What is Polling Rate?"]
  • USB Selective Suspend can pause USB devices; disabling it often resolves intermittent disconnects and freezes. [Microsoft, "USB selective suspend"]
  • Keep AMD Ryzen/B450 USB stable by installing the latest AMD Chipset Drivers for your board. [AMD, "Chipset Drivers"]
  • A Linux Live USB test cleanly separates hardware faults from Windows driver/software issues. [Ubuntu, "Try Ubuntu without installing"]
  • In the EU, a 2‑year legal guarantee covers defects; claim with proof of purchase. [European Commission, "Legal guarantee"]
How can I quickly tell if the cursor stutter is hardware or Windows?
Boot a Linux Live USB and test the mouse outside Windows. If it’s smooth there, focus on Windows drivers and settings. If it still freezes, suspect hardware, cabling, or the surface. How-To: 1. Create a bootable Ubuntu USB. 2. Boot "Try Ubuntu" (no install). 3. Move the mouse for 5–10 minutes and observe. [Ubuntu, "Try Ubuntu without installing"]
Which Windows 10 setting most often causes mouse cutouts?
USB Selective Suspend can power down ports briefly and disrupt mice. Disable it: open Power Options, edit plan settings, Advanced settings, USB settings, then set USB selective suspend to Disabled. Apply and reboot. This change often stops intermittent cursor freezing or brief disconnects. [Microsoft, "USB selective suspend"]
Will switching USB ports or avoiding hubs help?
Yes. Connect the Rival 110 directly to the PC, preferably a rear motherboard port. Avoid unpowered hubs and front-panel extensions during troubleshooting. Try different ports to rule out a flaky connector. Also remove other USB devices temporarily to reduce bus contention, then add them back one at a time. [Microsoft, "Troubleshoot USB devices in Windows"]
Should I lower the Rival 110 polling rate in software?
Yes. Set polling from 1000 Hz (1 ms) down to 500 or 250 Hz in SteelSeries software. A lower rate reduces USB and CPU load and can smooth stutter on marginal USB setups. Restore 1000 Hz once stability returns. As an expert note: "1000 Hz equals 1 ms." [Razer, "What is Polling Rate?"]
Do AMD Ryzen 3 1200/B450 chipset drivers affect USB stability?
They do. Install the latest AMD Chipset Drivers for your B450 board. These packages update USB controller components and can resolve intermittent device freezes. Reboot after installation and retest the mouse on a rear port. Update BIOS later only if your vendor recommends it. [AMD, "Chipset Drivers"]
Can a bad surface or dirty sensor cause the cursor to jam?
Yes. Reflective, transparent, or very glossy surfaces cause tracking failures. Try a plain, non-glossy mousepad or paper. Clean the sensor window with a lint-free cloth and isopropyl alcohol. Also remove hair or dust from the feet. This fixes many "stops/starts" that feel like freezes. [Logitech, "Mouse cursor behaves erratically"]
What should I write in my warranty claim for this issue?
Describe symptoms exactly and attach proof of purchase. Quote the behavior (e.g., “cursor freezes intermittently during normal use”). As one helper put it, “write what is actually the problem,” and include your receipt. Avoid inventing causes; stick to observable facts and frequency. [Elektroda, Kamil532, post #18013057]
Is this a sensor issue or just the cursor freezing?
In the thread, a helper clarified: “Not the sensor jamming, only the cursor.” Watch your drive-activity LED when freezes occur to spot storage spikes that can stall input. If the light is solid, check for background tasks or updates. [Elektroda, Robert B, post #18042562]
What finally solved it for the original poster (same hardware)?
A replacement unit. After troubleshooting and an earlier swap that didn’t help, the next new mouse “works like a glove.” This points to intermittent hardware faults that may survive initial RMA and justify trying another replacement within warranty. [Elektroda, aragox078, post #18072748]
Can heavy background tasks or "crap" software cause cursor stutter?
Yes. High CPU, disk, or DPC latency from overlays, RGB apps, or antivirus can stall input. Close launchers, disable in-game overlays, and pause real-time scans to test. The referenced guide also suggests reducing polling rate and disabling USB power savings to stabilize input. [Przerywanie lub zacinanie myszki komputerowej — jest na to sposób!]
How do I disable USB Selective Suspend (step-by-step)?
  1. Control Panel > Power Options > Change plan settings. 2. Advanced settings > USB settings > USB selective suspend setting. 3. Set to Disabled (both battery and plugged in), then Apply and reboot. Test the mouse after the restart to confirm improvement. [Microsoft, "USB selective suspend"]
Is this covered under EU consumer law if the store warranty is unclear?
Yes. The EU legal guarantee is two years for consumer goods. Present proof of purchase and describe the recurring fault. You may request repair or replacement first, then a refund if fixes fail within a reasonable time. Keep all correspondence. [European Commission, "Legal guarantee"]
