Amica PI6506TF Induction Hob Error F5 Only on Left Side After Module Replacement
Robert-X- 9354 6
  • #1 14637216
    Robert-X-
    Rate: 15
    Welcome gentlemen.
    The induction hob displays error F5.
    The problem is that the control module with the processor is functional. I exchanged it for a new one and still silence ...
    The error only appears on the left side of the disc.
    What can cause such behavior?
    What could have happened to the left module? I replaced transistors in it, large oval capacitors and all electrolytes.
  • #3 14639283
    Robert-X-
    Rate: 15
    Yes and after replacing it, the error only appears on the left boxes ...
    I have to change the left module but in its turn there is a problem that after replacing the transistors does not see the left big field but on it the error f5 does not occur.
    So in total I have two broken modules ...
    What can I possibly replace in modules?
  • #4 14641391
    Robert-X-
    Rate: 15
    I ordered the module in the promotion for 180 PLN today.
    If I replace it, I will let you know if everything is playing. :)
  • #5 14642991
  • #6 14643114
    Robert-X-
    Rate: 15
    I understand.
    Only the software and control module I exchanged for the one used with another, but 100% efficient.
    Something must be wrong with the left module because as I replace it with another, the error does not display.
    Anyway, the module has already been ordered and the price is not huge, so we'll see what will happen.
  • #7 14666873
    Robert-X-
    Rate: 15
    After replacing the left module, the disc works without problems.
The discussion revolves around an Amica PI6506TF induction hob displaying error F5, indicating a communication issue on the left side of the device. The user has replaced the control module and transistors but continues to experience problems. After further troubleshooting, it was determined that the left module was faulty. The user ordered a new left module, and upon its installation, the induction hob functioned correctly without errors.
