Amica PI6512TG Induction Hob Freezing and Displaying 'E' and 'A' - Possible Reasons?
robert-r 103014 9
Why does an Amica PI6512TG induction hob sometimes freeze and alternately show E and A on the display, and what is the likely cause?
The EA/E freeze usually points to a fault in the hob electronics or sensor circuit, not a normal operating mode, and the suggested repair is to replace the power supply/control module [#12920601] One explanation given was a temperature sensor / cooling element signal problem, with the control board seeing an unclear signal even when the cooktop is off, possibly due to a damaged AD converter [#12920601] Another user reported that the real fix in practice was replacing the left or right plate/module, especially if the hob had been flooded [#14520758]
  • #1 12882563
    robert-r
    Rate: 14
    I have a problem with the Amica induction hob, model PI6512TG (type: PG4VI512FTB4S).
    Every now and then the hob freezes, but not all of some cooking zones. Then, symbols "E" and "A" are displayed alternately on the panel.
    The only thing that helps is unplugging the board and turning it on again to restart it.
    Has anyone encountered a similar problem? If so what could be the reason.
    Thank you in advance for your help,
    Robert
  • #2 12917837
    bn1
    Rate: 33
    Hey, I have exactly the same problem. Cooking zone EA error. My motherboard is the PI6512TF model. Uncle Google doesn't help with this. Maybe someone here will know what the reason is, or you will need to call the service ...; (
  • #3 12920075
    robert-r
    Rate: 14
    I am also counting on a hint on the forum, although it seems to me that the only salvation is the website. And here is a problem - the service would have to be called when the cooking zone is frozen and nothing to do until then (because how to show and prove what is happening?). Again, warranty service usually takes 2-3 days from reporting the fault to the Call Center.
  • #5 14441441
    adamadam22
    Rate: 20
    I have a similar problem with the Amica NPI 6541 TU induction hob. After briefly using one half of the combined cooking zone (included in this hob) on power level 9, a flashing message: E A. Both parts of the combined cooking zone are flashing. The hob has already cooled down after cooking and the problem is still there. There will be no need to call the service. Unless someone knows a solution that will remove the problem without calling the service and will not void the warranty.
  • #6 14520683
    wiktor3a
    Rate: 30
    @ robert-r Hello, What was the end of this matter with the induction hob? Amica PI6512TG - The induction hob freezes, displays E and A.
  • #7 14520758
  • #8 14520787
    wiktor3a
    Rate: 30
    I had an error on the lower left, then on the upper right (i.e. two different layouts). Of course, only disconnecting from the network (two plates to be replaced?) Helped. Do you know what the costs are (after the warranty). Now I managed to get back to normal on the record turned on (I pressed the "-" button for a long time and didn't have to disconnect the hob from the mains, it went back to normal operation). I tested it for a while and it works for now. There is a chance that it has hung up ?! Greetings.
  • #9 14534862
    emimo
    Rate: 9
    SKRYN I have this question for you. My amica PB4VI509LFT board also freezes, but the problem is that when it starts, everything is ok, but if it is turned off for more than a few minutes, of course, all the lights are off, it will not turn on. You have to disconnect it from the mains and turn it on again, but you have to do it as if it was going to spark in the socket. It's hard to explain a bit, but usually pulling out and inserting the plug will not do anything!
  • #10 14535164
The Amica PI6512TG induction hob is experiencing intermittent freezing issues, displaying error codes "E" and "A." Users report that the problem occurs with various cooking zones and can be temporarily resolved by unplugging the unit. Possible causes identified include a malfunctioning temperature sensor, issues with the cooling element, or a damaged AD converter. Some users suggest that replacing the power supply may be necessary. Others have encountered similar problems with different Amica models, indicating a potential common fault across the brand. Warranty service may be required for repairs, but some users have found temporary fixes that do not void the warranty.
