Amica PI6509L Induction Hob Error E4: Causes, Repair Options & Controller Module Replacement
yzrej 51438 12
What causes the E4 error on an Amica induction hob, and what repair options are there besides replacing the whole controller module or cooking zones?
E4 on this Amica hob is usually treated as a fault in the cooking zone/module, but it is not always limited to a full module replacement. If the E4 code appears on the left or right side of the panel, the first step is to perform the configuration [#15477200] Reported board-level repairs include replacing the TNY266 or TNY288/TNY268 supply IC and the 29Ω or 20–50Ω resistor [#18275216] [#18403888] Another suggested fix is to check and replace the 39Ω resistors in all fields, preferably with 3W or 5W parts [#15538236] The main practical obstacle is the coil desoldering and the multilayer construction of the module, which makes repair difficult [#15477200] [#18275216]
  • #1 15453645
    yzrej
    Rate: 22
    I rummaged, rummaged and nothing. I was searching the internet about the causes of the E4 error in the Amica induction hob, the only thing I found was a controller error and you need to replace such a module, and preferably also the heating zones. After all, this is not the point, unless the module has a chip that cannot be replaced, and the heating fields are built in such a way that it cannot be disassembled. In general, the question is why such an error pops up and what is its cause, or what are the repair options, because that's what elektroda.pl is for.
    Advice on this type of module replacement is rather a bit too simple for an electrode true :D Generally, I haven't dismantled my CD yet because I wanted to get the "language" first, but unfortunately there is a problem with that. Maybe the subject should be explored.
  • #2 15475686
    777adam
    Hello. I also have such a problem. Did you find the answer?
    Regards
  • #3 15476525
    yzrej
    Rate: 22
    Unfortunately no, no one seems to have explored the subject as well, because 2 are still working. :D
  • #5 15478066
    yzrej
    Rate: 22
    And that was the point, someone wrote why not !! :D
    Not just a laconic "need to be replaced"
    This post will cool down the enthusiasm of others who come to repair.
    Now I know that you have to look around for a replacement because I have already tried the configuration.
    Bravo and thank you for your answer. :D
    yzrej
  • #6 15538236
    Przemek7
    Level 19  
    Help: 21
    Rate: 164
    I believe the solution here Link . It concerns Teka, but Amica has a clone of this album. 39? resistors to be checked and to be replaced (preferably in all fields). I recommend, from my experience, to use the largest resistors (power-dimensions) that can fit 3W or 5W.
  • #7 16358496
    yzrej
    Rate: 22
    Question to specialists. Amica PI 6509 l plate and PI 6510TU plate.
    One is only for 230V and the other is for 400 / 230V. Are the cooking zones interchangeable or are the controls different? Probably the module from which the voltage goes to individual fields is different, it is understandable, but how does this relate to the others, i.e. the aforementioned heating and control field?
    I am asking for hints.
  • #8 17043493
    morzej
    Rate: 14
    This problem can be fixed. I just picked up the Amica board from repair to the two right fields and the E-4 error.
  • #9 17043525
  • #11 18275216
    mario151515
    Rate: 24
    The repair is simple, we open each box and replace the TNY266 and the 29? resistor, you can change to the TNY288 and the 20-50? resistor. The problem is de-soldering the coil.
  • #12 18403888
    mery5
    Rate: 70
    mario151515 wrote:
    can be changed to TNY288
    I think on TNY268, much easier available!
  • #13 21650452
    mariuszheniek1
    How to configure such a board?
    Added after 4 [minutes]: .
    >>15477200 How to perform such a configuration?
Discussion about the E4 error in Amica induction hobs PI6509L and PI6510TU, focusing on whether the fault is caused by the controller module, heating zones, or power-supply components. Early replies suggest that if E4 appears on the left or right side, the first step is configuration, but later posts indicate that the issue can often be repaired by replacing failed components on the control board rather than replacing the entire cooking zone. Suggested repairs include checking and replacing high-value resistors, TNY-series switch-mode power supply ICs, and in some cases swapping the damaged field/module. One reply notes that the main difficulty is desoldering the coil assembly. The thread also discusses interchangeability of zones between 230 V and 400/230 V versions and whether the control modules differ.
