I am looking for a time controller to control a contactor with adjustable times
IniVo 1698 4
  • #1 14640279
    IniVo
    I'm new to the forum, not sure if I posted this topic in the right section.
    I am looking for a timer controller that can control a contactor as follows:
    1) Switching on the system
    2) 5 seconds ( adjustable time) the contactor would be on
    3) 10 min (also possibly time controlled) contactor would be off
    4) then the cycle repeats until the system is manually switched off
    it would be good if both times could be adjusted in this area
    it can be any old controller, it just needs to perform these 2 automatic operations
    i would like it not to be too expensive.
    Thank you in advance for any advice
    Best regards
  • #3 14640306
    IniVo
    thanks, that's what I was looking for
    azibik
    Level 32  
    Help: 82
    Rate: 324
    You'll do it on a 555 for 1/3 the price, AVT kit 1459
  • #5 14642426
    IniVo
    thanks for your advice
