[Solved] Decoding Error F15 on Hotpoint Ariston LTF 11M121 B EU Dishwasher: Experiences and Guidance
Jacoll213 71958 10
What does error F15 mean on a Hotpoint Ariston LTF 11M121 B EU dishwasher, and what should I check first to diagnose it?
F15 on this dishwasher is most likely related to the washing/circulation pump, often because the pump is blocked or mechanically damaged [#16423010] [#16429898] [#17341505] One user fixed it by dismantling the pump and finding a popcorn grain blocking the impeller [#16429898] Another reported that the pump’s rotor pin had worn the housing, so replacing the washing pump solved the fault [#17341505] A service-based reply also stated that the fault is a pump defect, and in that case the repair cost was close to buying a new dishwasher [#16423010]
  • #1 14659054
    Jacoll213
    In the Hotpoint Ariston LTF 11M121 B EU dishwasher, error F15 appears during various washing phases and on all washing programs. I searched the googole doctor, unfortunately I did not find a description of this error, I have no idea what activates it. If someone has error descriptions of Ariston's Hot-point dishwashers, or has encountered this problem, please give tips on how to figure out the topic of this fault.
    • Decoding Error F15 on Hotpoint Ariston LTF 11M121 B EU Dishwasher: Experiences and Guidance DSC_0016.JPG (1.34 MB) You must be logged in to download this attachment.
  • #2 16422916
    Bogdan007
    Rate: 159
    Hello, I was able to decode the F15 error?
    Regards
  • #3 16423010
    piotrd1
    Rate: 55
    Apparently, this is a defect in the washing pump
  • #4 16423172
    Bogdan007
    Rate: 159
    How do you get this knowledge, I don't even get water?
  • #5 16423259
  • #6 16423902
    piotrd1
    Rate: 55
    I just know from the service and I had to buy a new dishwasher because the cost of repair was similar to the new one
  • #7 16429898
    Bogdan007
    Rate: 159
    I wonder if they put you in a bottle? I took the pump apart in 10 minutes and put it back together in 15 ;-) It was due to a grain of popcorn blocking the pump impeller. All guts look like new inside after almost three years of use, and the structure is as simple as that of a flail. Best regards and I wish you as little failure as possible. Thanks for helping me decode the bug.
  • #8 16430164
    piotrd1
    Rate: 55
    Well, knowing this website, it is possible. And no other professional would do it. I didn't have time to rummage through it. I had to buy a new one quickly, unfortunately
  • #9 16570593
    galik49
    Rate: 21
    For me, it gets water and displays error F15 what is it?
  • #10 17304855
    Aja90
    Rate: 19
    I also had this F15 error, I poured a liter of vinegar and two packages of baking soda. Of course, in two turns and it helped, and the dishwasher continues to work.
  • #11 17341505
    marko08111
    Rate: 12
    I had a similar problem, I was getting an error from time to time F15 in the end, nothing could be done. I replaced the washing pump and it is ok, and the old one turned out to be damaged, the rotor pin wiped the housing holding it ...
    Decoding Error F15 on Hotpoint Ariston LTF 11M121 B EU Dishwasher: Experiences and Guidance I have corrected TONI_2003
The F15 error on the Hotpoint Ariston LTF 11M121 B EU dishwasher is commonly associated with a defect in the washing pump. Users have reported various experiences, including complete failure to receive water and issues caused by blockages, such as a grain of popcorn obstructing the pump impeller. Some users successfully resolved the error by cleaning the pump or using vinegar and baking soda to clear potential clogs. However, others found that replacing the washing pump was necessary due to damage. The cost of repairs can be comparable to purchasing a new unit, leading some users to opt for replacement instead of repair.
