Hotpoint Ariston LTF11H132EU Dishwasher: Dealing with Persistent Error 15
CceresisS 84849 10
Why does my Hotpoint Ariston LTF11H132EU dishwasher show error 15 after a few minutes and stop, and what should I check or replace?
Error 15 is a virtual sensor fault: the controller gets incompatible readings from the washing pump and drain pump, so the first thing to do is clean the washing pump and then replace it if cleaning does not solve the problem [#16732467] [#16832422] One user found sludge, hairs, and even a grape seed in the pump; after cleaning the mount, the dishwasher worked normally again [#16732467] Another user cleaned the pump but still had the fault, and replacing the washing pump fixed all symptoms; the old pump showed a large clearance on the rotor axis [#16832422] It is also worth checking the drain pump, but that is usually quicker because it is only unscrewed [#16732467] If the dishwasher is still under warranty, the advice was to call service [#16702888]
  • #1 16702612
    CceresisS
    When in March I bought a dishwasher: Hotpoint Ariston LTF11H132EU at first worked without problems. However, for the last two months a mistake has started to appear (after switching on the dishwasher the device is pumping water, I wash the dishes for a while). However, after a few minutes, the number 15 appears and I stop working at that moment. If anyone knows this and knows what's going on, I'm asking for help.
    Piotr2608
    Help: 851
    Rate: 4488
    F15 - Virtual sensor error fault
    You have nothing else to do but call a service. You have a warranty on the dishwasher.
    ZimTech Piotr Zimny
  • #3 16724780
    TomSlaski
    Rate: 28
    And what does this error mean, because I have the same problem but I do not have a guarantee anymore
    widaw
    Help: 21
    Rate: 173
    The programmer does not receive the right information from the sensors at a given time. The machine does not perform properly programmed activities.
  • #5 16728404
    TomSlaski
    Rate: 28
    Thanks for the information, and that means you need to check the contact / replacement parts? Is there any website describing such a case?
  • #6 16729193
    widaw
    Help: 21
    Rate: 173
    This may be, for example, exceeding the programmed time of filling or releasing water.
  • Clogged wash pump caused error 15
    #7 16732467
    rapidBUNNY
    Rate: 19
    I had the same problem of error 15. Symptoms: after turning on the program, the dishwasher pumped out the water, started to play a little bit, and after a few minutes there was an error. At the beginning she did so in the middle of washing after about 1 hour. Then from the very beginning, without even taking water. The trail hit me because it happened 30 days after the 2-year warranty. I found a service instruction in which it was written:
    Error 15 - virtual sensor error - reading from the washing pump incompatible with the reading from the drain pump - whatever that means :P
    Recommendation: replacement of the washing pump.
    It was a pity me to spend 300 zlotys on the new pump immediately. I dismantled the old one (it was not easy for me because I never did it), there was a lot of "silt" in the middle, a few hairs and a small seed of grapes. I have cleaned the mount and the problem is gone. The dishwasher normally works :)
    It seems to me that through these dirt, the impellers of the pump encountered resistance as if it were water inside. Since every program starts with pumping out the remaining water, the dishwasher tried to do it 3 times, the resistance did not disappear, it returned error 15. (there is water in the washing pump, not in the drain pump - that's what I understand).
    By the way, I cleaned the drain pump, nothing was there, but I think it's always worth checking out because it's a lot less work with it because it's only unscrewed and you do not have to play with the terminals. I hope someone will help ...
  • #8 16832422
    TomSlaski
    Rate: 28
    Hello, I've done what he wrote rapidBUNNY - indeed there was a lot of sludge and leftovers in the pump, I cleaned the pump, but this procedure did not help. I replaced the washing pump with a new one and all the ailments have passed.
    Looking at her carefully, it could be seen that the rotor axis had a very large clearance, which was probably the cause of the failure. Disassembly of the pump and its unscrewing is not terribly troublesome, but you can do it yourself. It can be stated that for this type of error, the pump should first be cleaned, and if the exchange does not help.
  • #9 17100980
    A-Mail
    Help: 22
    Rate: 215
    For me, after three years of work, it was necessary to replace the pump having. She has graphite cups for this powder with cleaning tablets and pump replacement. I undressed the pump with the thought that it will be possible to make some more pan, but ...
  • #10 17846917
    ltms
    Two years and seven months ... washing pump for replacement.
  • #11 17846928
    A-Mail
    Help: 22
    Rate: 215
    Cleverly made, I thought that I would make some brass from myself and now 2 weeks ago it definitely fell
The Hotpoint Ariston LTF11H132EU dishwasher is experiencing a persistent Error 15, which indicates a virtual sensor error related to the washing and drain pump readings. Users suggest that this error may stem from issues such as clogged pumps or faulty sensors. Recommendations include checking and cleaning the washing pump, as debris can cause malfunctions. If cleaning does not resolve the issue, replacing the washing pump is advised. Some users have successfully fixed the problem by cleaning the pump, while others had to replace it after warranty expiration. The error typically arises after prolonged use, often around two years.
