Photovoltaic installation - connection to the grid without selling electricity
pklawit 50157 19
Can I connect a small rooftop PV system to my home grid so it powers my appliances and never exports electricity to the utility, without special permits or a sales contract?
Yes — the thread’s answer is to use an internal on-grid setup with export limiting, so the PV covers home consumption first and any surplus is diverted locally instead of being sent to the grid [#14667611][#14667683] The recommended device is a power guardian / wattrouter, which can steer excess energy into controllable loads like a water heater; one reply says you can buy one ready-made or build it yourself [#14667683][#14667691][#14673994] If household demand is higher than PV production, the grid simply supplies the missing power as usual; one project mentioned balances the connection with triac-controlled heaters and can regulate to about 1 Wh [#14672689][#14672788] If you want a system that never synchronizes back to the grid at all, a hybrid/off-grid inverter or On-Line UPS with batteries was suggested, described as taking but not returning energy [#16602178] For a formal micro-installation, the utility replaces the old meter with a two-way meter and may require the fuse panel to be rebuilt with rail-mounted breakers [#14667861][#14669575]
  • #1 14667531
    pklawit
    Rate: 50
    I am planning an independent construction of a small photovoltaic installation on the roof of the house - approx. 2kWp.
    When I read the list of requirements and permits needed to connect such an installation to the power grid (to sell electricity to the grid), I started to wonder if there is an easier way to connect such a power plant to the home power grid - just to save on energy fees purchased from the supplier .
    Maybe someone from the forum members will advise - is it possible to carry out such a connection of a PV power plant without permits and contracts with the operator, so that home appliances are powered from the sun (when it is on), and if necessary (when the sun is not shining) to work "in the old way"?
    I have read about inverters with the bypass option - they switch to the network in the absence of DC voltage from PV panels - is this the right direction?
    I have calculated the average electricity consumption at home and it seems not high (about 0.5kW per hour, i.e. 500W of continuous power). Of course, it is known that there are periods of much greater consumption - kettle, oven, etc.
    or just complementing?
    Maybe lame questions, but in general, I mean whether my colleagues see any option of connecting a small PV system so that it produces electricity only for its own needs.
    Greetings,
    Peter
  • #2 14667611
    Lesio_Q
    Help: 13
    Rate: 73
    ZE customer contracts do not prohibit this, there is only a point about not sending energy from your own devices to the grid.
    And for this it is enough to use the excess production at home. So it's an internal on-grid :D
  • #3 14667645
    pklawit
    Rate: 50
    Ok, but how do you ensure that this point about "not sending energy from your own devices to the grid" is met?
    If I take a "normal" inverter on-grid (they are even plugged into a socket), it may always happen that at a given moment not everything produced by PV will be used up at home and the electricity consumption meter will start spinning backwards :-)
    And that is what I would like to avoid.
    An inverter with a bypass system (or an ordinary off-grid inverter plus a separate bypass system) would do the trick, but I have no idea how such a system would work at times when the needs of home appliances exceed PV production.
    Greetings,
    Peter
    Lesio_Q
    Help: 13
    Rate: 73
    We had a couple of threads here about the guardian of power.
    I use my own invention, you can also buy a ready-made one.
  • #5 14667691
    pklawit
    Rate: 50
    Ah, actually, I saw something called a watt-router or something.
    Ok, let me read, it would be the best solution.
    On-grid, but without pushing the surplus to the network, only e.g. water heating, etc.
    Thanks for the hint.
  • #6 14667741
    putas
    Renewable energy sources specialist
    Help: 48
    Rate: 534
    Wattrouter is cool, but the price is prohibitive - about PLN 1600.
  • #7 14667861
    rwxw
    Help: 5
    Rate: 64
    pklawit wrote:
    As I read the list of requirements and permits needed to connect such an installation to the power grid
    Don't overdo it, there isn't that much of it. You need an inverter that meets the requirements and a signature on the application of the electrician who installed / verified the installation. Are you sure you read about the micro-installation notification and not the connection to the concession?
  • #8 14669449
    pklawit
    Rate: 50
    And what qualifications must the electrician signing such a micro-installation notification for the energy sector have? Typical electrical ones or some special ones for PV assembly?
    The second thing is the meter measuring the amount of "pushed" energy to the network - I currently have it
    a small recess in the wall with an old mechanical counter with a shield and a micro-panel with 9 screwed fuses.
    From what I read, I need to have space to mount this additional meter - does it have to be in the same cavity as the consumption meter?
    And how does it connect then - if I connect the inverter output to this additional meter, then nothing from the energy produced will go to power household receivers, but to the network.
    Do I get it wrong?
    Greetings,
    Peter
  • #9 14669501
    putas
    Help: 48
    Rate: 534
    I recommend reading the drawings at http://pvmonitor.pl/sprzet.php
    An exemplary connection is shown in a very good way. It is true that there is a connection for monitoring purposes: one meter counts the entire production from PV, the other meter counts the entire consumption of the house. And the meter for settlements with ZE will be installed by them themselves - between your box and the first security ("S").
  • #10 14669575
    pklawit
    Rate: 50
    These drawings on the LAN connection of the controller show how to connect what to have information about the production / consumption yourself.
    And I mean, what is the connection of the inverter to the network in the context of meters
    energy assembled by the power industry.
    If I now have one tag energy consumption meter and when connecting micro-installations they install a second one, what does it look like then?
    Or like the drawing I scratched out?
    Or is it different - they take off the old meter and install a new one, which counts in both directions at once?
    Greetings,
    Peter
    Added after 1 [hours] 2 [minutes]:
    I called the supplier (ENEA) and the matter became clear.
    No space is needed for an additional counter.
    The old counter is disassembled and in its place a new one - two-way is installed.
    The gentleman told me that I would have to redo the panel with fuses, because in such a situation fuses (the usual screwed ones) cannot be installed.
    Or I have to disassemble everything and install the rail and the "S" fuses on it,
    or replace the fuses themselves with such screw-in automatic devices.
    Greetings,
    Peter
  • #11 14672351
    marekj31
    Help: 27
    Rate: 113
    Internal on-grid, overproduction for own use, e.g. by such a waatrouter, as with network synchronization, you can synchronize yourself with an inverter without reporting to the network, or through such a waatrouter, e.g. we do not synchronize with the network
  • #12 14672383
    Lesio_Q
    Help: 13
    Rate: 73
    Well, how on-grid is synchro with the network!
    ZE has no copyright on the 50Hz waveform phase :D
  • #13 14672689
    puta
    I recommend reading http://openenergymonitor.org/emon/mk2/pvmeasurement
    It is a project based on pvmonitor.
    Generally, it controls (in group) the triac (heaters) so as to balance the energy at the connection with an accuracy of 1Wh.
    Load control can be converted to phase or PWM.
    Additionally, the system performs a monitoring function.
    I made the layout, modified the code a bit for my needs and it flies ;-)
  • #14 14672693
    Lesio_Q
    Help: 13
    Rate: 73
    I am concerned about the idea of using group control. Cool, because it does not interfere, but the meters probably have a problem with it and do not integrate to zero.
  • #15 14672721
    PV_Albert
    Help: 11
    Rate: 117
    Yeah, some are supposed to work fine. Probably with discs it is without problems in group control.
    Phase control and PWM are mercilessly disturbing. So much so that all ds18b20 sensors are crazy. Probably a good rule is to connect such a driver almost on the heater, but will it help?
  • #16 14672788
    puta
    Many meters have a so-called "sweet zone" ~ 3600J = 1wh.
    Within this "buffer" the meter indicates consumption by "flashes" of the diode, but pulses are not counted on the main abacus.
    Probably the "primary counter" is bidirectional.
    In the pvrouter code, you can freely change the size of the "sweet zone".
    Reducing it will improve the stability of the "balance" but will increase the "flicker" effect. PS pvrouter has "AntyFlicker" implemented.
  • #17 14672828
    Lesio_Q
    Help: 13
    Rate: 73
    That would be interesting - the LED is blinking, but the pulses are not counted.
    How to confirm this on the Polish market of meters ...
    My bad experiences with the 'group' ended with the LED blinking, I didn't verify if the meter was counting them :|
  • #18 14672920
    puta
    How to confirm - preferably with this system.
    It is not complicated - Maga328 + current transformer + voltage transformer (in my case 320-> 2x9V) + 7805 + triac + driver (in my case optoisolated), several resistors and capacitors. You can forgive the radio and send readings to rs232. You can also simulate pv production without an inverter in the software.
    The different versions of fw are here: http: //openenergymonitor.org/emon/node/1757
    In Rob's videos (links on the same page), the reaction of the dial and electronic counter is shown:
    https://www.youtube.com/watch?v=WVqL30uOluQ
    It is known that it is generally a prosthesis of dissolution, but you have to live with it until the end of the year ;-) Unfortunately, it took several years for the rulers of our beloved country to try to solve what could be solved with the help of the old Pafala.
  • #19 14673994
    CzystyZYSK
    Help: 18
    Rate: 81
    Well, it is such a wattrouter ;-) but you have to do it yourself with electronic components.
  • #20 16602178
    Sa2k
    Level 19  
    Rate: 52
    What if you were to use an On-Line UPS?
    Push energy through the batteries.
    This kind of Off-Grid Hybrid Inverter
    Takes but does not return
The discussion revolves around the feasibility of connecting a small photovoltaic (PV) installation (approximately 2kWp) to a home power grid without selling excess electricity to the grid. Users explore options for internal on-grid systems that utilize solar energy for household consumption while avoiding the need for permits and contracts with energy suppliers. Key solutions mentioned include inverters with bypass options and devices like watt-routers that manage energy flow to prevent sending surplus energy back to the grid. Participants also discuss the requirements for micro-installation notifications, the qualifications needed for electricians, and the installation of additional energy meters. The conversation highlights the importance of ensuring that energy produced by the PV system is used internally without causing the consumption meter to spin backwards.
