Can a solar installation be connected to your network without reporting?
Jakubosz 26316 11
Can I install grid-connected photovoltaic panels without notifying the utility if I only want to self-consume and let the grid cover any shortage?
If you use a normal grid-tied inverter, you should report the installation to the utility; the inverter synchronizes with the network and any surplus is sent to the grid instead of being cut off [#16742424] [#16742593] [#16742374] With an electronic meter, that surplus can be counted as consumption, so the safest advice in the thread is to notify ZE even if you plan to use most of the power yourself [#16761976] [#16742593] One reply adds that zero-export inverters exist, which block sending surplus to another energy receiver, and says that in that case you do not have to report it [#16742692]
  • #1 16742089
    Jakubosz
    I have a question.
    I would like to install photovoltaic panels on the roof. I would not want to sell energy to the EE but to consume it on a regular basis without using batteries and storage, and the shortage should be taken from the EE. Do I have to report it to ZE?
    Will connecting the inverter under my installation at home synchronize itself with the network?
    I do not assume excess energy, but it can happen. What about her? Will the inverter cut the excess?
  • #2 16742352
    FankyKoval
    Help: 6
    Rate: 34
    The energy meters most often produce as consumption and you pay for it, so it does not make sense. Remember that the most efficient warehouse is the network.
  • #3 16742374
    kosmos99
    Help: 338
    Rate: 820
    No, send to the network.
  • #4 16742397
    Jakubosz
    I am still looking for an answer. In principle, the most important question.
    Will connecting the inverter under my installation at home synchronize itself with the network and give electricity to my installation?
  • #5 16742424
    chrobry25
    Rate: 76
    On a formal issue - you must report.
  • #6 16742593
    Jan_Werbinski
    Help: 76
    Rate: 671
    Apparently, you must report by law, but not announce it is not penalized, so you can not report. If you have a bad meter, then it will not be production to make fun as consumption. It is better to report. This in no way prevents full consumption of your own energy. Failure to report in a situation where you plan full consumption does not make sense even more than with excess production. The only reason that comes to mind is shitty, incompatible, no documentation panels or inverters.
  • #7 16742674
    prose
    Level 36  
    Help: 173
    Rate: 850
    There are inverters that do not allow the surplus to be sent to the CW or another energy receiver you do not have to report.
  • #9 16761474
    JESIOTR1
    Help: 64
    Rate: 441
    Without notification - When ZE cuts off the power supply, and you continue to power it and it will cause an electric shock outside your installation - judgment or pardon?
    Only asking.
  • #10 16761644
    kosmos99
    Help: 338
    Rate: 820
    JESIOTR1 wrote:
    and you will continue to power it
    If there is no power supply, the inverter will turn off, so there is no danger.
  • #11 16761735
    prose
    Level 36  
    Help: 173
    Rate: 850
    How to power the house with an aggregate or a hybrid, what will punish him will hurt someone, let's not exaggerate, ladies @ JESIOTR1 it is not a commune that you could not have your own energy, there are inverters without going into the network, it will automatically turn off when the power goes down.
  • #12 16761976
    Leon444
    Help: 48
    Rate: 355
    Only asking.
    My colleague probably meant that some inverters have an island function, i.e. they can work even after the network is down, of course it is forbidden due to the possibility of electric shock when the power cut off the electricity for maintenance or repair ...
    And back to the main topic, if you have an electronic meter installed in your home, any excess production and going to the network will be counted by the meter as a download from the network, report the installation to the ZE and the problem, after all you do not pay anything, after the name itself indicates "you are reporting" and you do not ask for permission, do not understand this approach a little, what are you afraid of?
    Going on vacation for 2 weeks, for example, and you will not have any wear at home and what then? Will you disconnect the installation so as not to sell yourself electricity? No sense...
The discussion revolves around the installation of photovoltaic panels and the legal requirements for connecting them to the electrical network without reporting to the energy provider (ZE). Users express concerns about whether they need to report the installation if they plan to consume the generated energy without selling it back to the grid. Responses indicate that while it is legally required to report the installation, some users suggest that failure to do so may not result in penalties. The conversation also touches on the functionality of inverters, with some models capable of preventing excess energy from being sent back to the grid. Concerns about safety during power outages and the implications of not reporting the installation are also discussed.
TL;DR: If you leave for 2 weeks, any solar excess will export; “report the installation to the ZE.” [Elektroda, Leon444, post #16761976] Why it matters: This FAQ helps homeowners planning self-consumption PV decide when to report, how to avoid export, and what inverters actually do.
Do I have to report my PV if I only want self-consumption?
Yes. Forum practitioners state you must notify the utility (ZE) before connecting a PV inverter to the grid, even for self-use. Reporting does not stop you from consuming your own energy. It documents your connection and prevents metering and compliance issues later. [Elektroda, chrobry25, post #16742424]
Will a grid-tie inverter synchronize with my home and the utility grid?
Yes. A grid-tie inverter locks to grid voltage and frequency, powers your loads first, and any surplus flows to the grid. It will not “cut” excess on its own; export is the default behavior. [Elektroda, kosmos99, post #16742374]
Can an inverter really block export (0 kWh to the grid)?
Some inverters or controllers include a no-export mode that limits output to match local load, holding export at 0 kWh. Use this when you must avoid feeding the grid. Confirm the feature in the inverter’s documentation before purchase. [Elektroda, prose, post #16742692]
What happens to my PV during a power outage?
For safety, grid-tied inverters stop producing when the grid goes down. This prevents energizing external lines during maintenance or faults. Your house will not be powered by the PV unless you use a hybrid system configured for island operation. [Elektroda, kosmos99, post #16761644]
Is island mode allowed for home PV systems?
Forum users warn that island-capable setups can be dangerous to line workers and are not allowed for typical grid-tie connections. The safe default is automatic shutdown on grid loss, not backfeeding lines. [Elektroda, Leon444, post #16761976]
Will my meter charge me for my own exported energy?
A contributor notes some electronic meters may treat reverse energy as import, charging you for it. Reporting and proper metering avoids this edge-case failure. Ask the utility to verify meter behavior after PV commissioning. [Elektroda, Leon444, post #16761976]
Is failure to report penalized?
One poster claims the law requires reporting but says non-reporting is not penalized; however, they still recommend reporting. Unreported systems risk billing errors and safety disputes. “It is better to report.” [Elektroda, Jan_Werbinski, post #16742593]
How do I avoid sending surplus to the grid?
Choose an inverter with a certified no-export function and enable it. Size PV so daytime loads absorb production. Verify at the main meter that export reads 0 kWh under typical operation. [Elektroda, prose, post #16742692]
What if I’m on vacation and loads are near zero?
Expect export unless the inverter blocks it. A forum example cites a 2‑week trip with no home usage, so all PV becomes surplus. Plan for no-export control or accept export and report the system. [Elektroda, Leon444, post #16761976]
Does the inverter limit power automatically to prevent export?
A standard grid-tie inverter does not. It supplies loads and sends any extra to the grid. If you need zero export, pick hardware with an explicit limiter feature. [Elektroda, kosmos99, post #16742374]
What’s the best way to use the grid with PV self-consumption?
“The network is the most efficient warehouse.” Use the grid to balance shortfalls or surpluses, and report your PV for correct metering. This avoids batteries if you don’t need backup. [Elektroda, FankyKoval, post #16742352]
Quick how-to: set up self-consumption with no export
  1. Select a no-export capable inverter and enable its limiter.
  2. Connect per the manual and verify on-grid operation.
  3. Confirm at your meter that export stays at 0 kWh during typical loads. [Elektroda, prose, post #16742692]
Will a hybrid inverter keep my house powered during outages?
Hybrid systems can power selected circuits in backup, but forum users emphasize they must not energize the public grid. Ensure transfer/islanding protection is correctly configured. [Elektroda, prose, post #16761735]
If ZE disconnects my street, can my PV shock someone outside?
With a compliant grid-tie inverter, no. Anti-islanding turns the inverter off when the grid disappears, removing backfeed risk beyond your installation. [Elektroda, kosmos99, post #16761644]
Does aiming for 100% self-consumption guarantee no export?
No. Cloud edges and load changes cause momentary surplus. Without an export limiter, that surplus flows to the grid. Use a no-export inverter to enforce zero export. [Elektroda, prose, post #16742692]
