How Is Photovoltaic Output Power Used: Onsite Consumption vs Grid Export and Billing?
312 6
  • #1 21667944
    Leo Eden
  • #2 21667945
    Steve Spence
  • Grid export requires synchronized inverter and special metering
    #3 21667946
    stephen Van Buskirk
  • Grid-tied inverters handle synchronization and voltage regulation
    #4 21667947
    Chuck Sydlo
  • Large solar arrays still have poor payback at current rates
    #5 21667948
    stephen Van Buskirk
  • Solar inverter costs, warranties, and payback estimates
    #6 21667949
    Chuck Sydlo
  • Grid-tie inverter enables backup and no special meter
    #7 21667950
    Steve Spence
Photovoltaic (PV) system output power is primarily consumed onsite if local loads require it, effectively offsetting electricity drawn from the utility. Excess power not immediately used flows back into the grid, reducing the end user's electricity bill, typically at a lower compensation rate than retail. Modern grid-tied inverters handle DC to AC conversion, synchronization, and voltage regulation according to standards such as UL 1741 and IEEE 1547/1547.1, ensuring safe and efficient grid integration. While historically synchronization and switchgear costs were prohibitive for small producers, advances in inverter technology and price reductions have made grid-tied PV systems accessible and cost-effective for homeowners and businesses. Inverters range from small microinverters (~200 W) to utility-scale units (up to several hundred kW), with warranties of 10-25 years. Installation costs and requirements vary by location, with some areas offering rebates that improve payback. No special meters are always required, though some utilities may mandate additional metering for net metering purposes.
