[Solved] Głosniki 5.1 Creative 6300T: Windows 10 Speaker Issues, MSI Z270 Gaming M3, Realtek Solutions
N0dy1117 6273 16
How can I get all channels of my Creative 6300T 5.1 speakers working on an MSI Z270 Gaming M3 with Windows 10?
Install the correct Realtek driver for the MSI Z270 Gaming M3 from the MSI support page, remove the other audio drivers first, and check whether the Realtek tray/control-panel app appears and detects the jack connections [#16834559][#16835887] Also make sure you test with real 5.1 audio; music from YouTube is only stereo, so the rear speakers will stay silent even when everything is working [#16834568][#16835605] One reply also points out that a DVD or other source with Dolby Digital 5.1 is the right way to verify all channels [#16834568][#16836157] If the system was changed repeatedly and audio devices stopped working, restoring Windows to a previous restore point is suggested before trying again [#16835605]
  • #1 16834533
    N0dy1117
    Hello all.
    I have Creative 6300T 5.1 speakers. When I connect them to the motherboard, only the subwoofer works and 2 depends on how I connect to the Subwoofer. I bought some sound card from amazon and the problem still sees only one channel. I don't have a Realtek, but I don't have one because the icon bar is missing, I don't see the rthdcpl.exe process either, I installed a lot of Realtecs with none, does anyone have any idea how to make each speaker work?
    MSI Z270 Gaming M3 motherboard
  • #2 16834559
    sylweksylwina
    Help: 1882
    Rate: 2355
    Which card did you buy from Amazon?
    On which card do you want to run it?
    Realtek ALC1220 is on the board. Remove all drivers and install from the MSI page. You should see the Realtek icon in the system tray and / or control panel.
    How many Podlasie cables do you know of the set?
  • #3 16834568
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    You need the right driver for the card. If you write "some" then you probably didn't take the time to select and install this driver.
    If connecting the speakers to the board, the corresponding driver must be the same.
    N0dy1117 wrote:
    When I connect them to the motherboard, only the subwoofer works and 2 depends on how it connects
    Are you testing with a source that has 5.1 sound (for example, DVD movie with 5.1 sound)?
  • #4 16834656
    N0dy1117
    The driver is downloaded from msi, but there is still no rthdcpl.exe in the realtek folder
    usb sound card https://www.amazon.co.uk/gp/product/B009NVS6KS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 the drivers were on the disc.
    Added after 4 [minutes]:
    Tests on music, etc, the point is that the speakers are 'buzzing' because the power is supplied, but the sound is not on the Windows tester, I also don't hear anything, the suspicion falls on this realtor because probably if I had this panel, I would put everything there, but I can't download it none to display this panel. The second thing is that it was Windows 10 I preferred the 7 pirate everything was flickering but the targets higher; p
    Added after 54 [minutes]:
    The success of the reins from this shit from China has started the test on them ran successfully reproduced in everyone but the music still there is something someone :D ?
  • #5 16835270
    sylweksylwina
    Help: 1882
    Rate: 2355
    Check i.e. @jdubowski he wrote, i.e. on a DVD movie with DD 5.1 sound.
  • #6 16835279
    N0dy1117
    Now nothing works I gave up I disconnected everything now even the microphone in the headphones does not work.
  • #7 16835605
    jdubowski
    Help: 2511
    Rate: 2804
    N0dy1117 wrote:
    Tests on music yt
    Music from YT has two channels, so don't be surprised that you can't hear anything from the rear speakers.
    You probably deigned to dig the system to such a state. Return to the restore point, do not install just the right thing.
  • #8 16835769
    N0dy1117
    I have restored to normal, but anyway realteka still does not have a stupid elevator sound option
  • #9 16835810
    sylweksylwina
    Help: 1882
    Rate: 2355
    What do you have in the device manager?
  • #10 16835844
    N0dy1117
    Głosniki 5.1 Creative 6300T: Windows 10 Speaker Issues, MSI Z270 Gaming M3, Realtek Solutions I have so much
    sylweksylwina
    Help: 1882
    Rate: 2355
    So you normally have realtek drivers installed. Does the realtek panel detect jack connections? Insert photo from Control Panel -> sound.
  • #12 16835899
    N0dy1117
  • #13 16835926
    sylweksylwina
    Help: 1882
    Rate: 2355
    That's why you write:
    Something is wrong. As I asked, does Realteka detect plug connections in the panel?
  • #14 16835943
    N0dy1117
    Detects above I wrote that the sound is in 2 speakers and in sub. on the Chinese controls from this Chinese card the tests are exemplary on every speaker you can hear the test so much that this program is handicapped and then the headphones do not work realtek always switched itself first I would like to regain the manager of the realtek and then start working with the rest
    jdubowski
    Help: 2511
    Rate: 2804
    On a DVD movie with 5.1 sound also?
  • #16 16837187
    N0dy1117
    They do not work at all 3 only you can hear "humming" on the Chinese controls, all tests pass but nothing later
  • #17 17199430
    N0dy1117
    New sound card.
The discussion revolves around issues with Creative 6300T 5.1 speakers connected to an MSI Z270 Gaming M3 motherboard. The user reports that only the subwoofer functions, and attempts to resolve the issue by installing a new sound card from Amazon have not succeeded. The absence of the Realtek audio control panel and the rthdcpl.exe process complicates troubleshooting. Participants suggest ensuring the correct drivers are installed from the MSI website and testing with 5.1 sound sources. The user experiences further complications, including non-functioning headphones and persistent humming from the speakers. Despite restoring the system, the Realtek sound options remain limited, and the user seeks to regain full functionality of the audio manager.
TL;DR: If your Creative 6300T 5.1 only plays fronts/sub in Windows 10, remember YouTube/music are 2‑channel; “Music from YT has two channels.” [Elektroda, jdubowski, post #16835605]
Why it matters: This FAQ helps Windows 10 + MSI Z270 Gaming M3 owners get true 5.1 working and avoid driver/panel pitfalls.
How do I fix “only subwoofer and two speakers work” on Creative 6300T with MSI Z270 in Windows 10?
Clean up audio drivers, then install the Realtek package from MSI for the Z270 Gaming M3. After install, confirm the Realtek icon/panel appears and set the configuration to 5.1. Reconnect the three analog plugs and use jack detection to verify ports. Finally, test with a true 5.1 source, not stereo music. [Elektroda, sylweksylwina, post #16834559]
Why are my rear speakers silent on YouTube or MP3s?
Because YouTube/most music is stereo. That plays only left/right unless you enable upmixing. As one expert noted, “Music from YT has two channels.” For a real surround check, use 5.1‑encoded material. Many users mistake stereo playback for a hardware fault. [Elektroda, jdubowski, post #16835605]
How can I confirm that all 5.1 channels are wired correctly in Windows?
Open Windows Sound settings, choose your Realtek playback device, set it to 5.1, and run the channel test. Users reported that the Windows test successfully played through each speaker when wiring and device selection were correct. This isolates wiring from app playback issues. [Elektroda, N0dy1117, post #16834656]
Do I need Realtek drivers or the USB sound card drivers?
Match the driver to the device you actually use. For onboard audio, install the Realtek ALC1220 driver from MSI. For a USB card, install that card’s own driver. As an expert advised, “You need the right driver for the card.” [Elektroda, jdubowski, post #16834568]
Where is the Realtek HD Audio Manager icon/panel on Windows 10?
After a correct MSI Realtek install, you should see the Realtek icon in the system tray and/or Control Panel. If it’s missing, remove other audio drivers, reboot, and reinstall the MSI package for Z270 Gaming M3 to restore the panel and jack‑detection features. [Elektroda, sylweksylwina, post #16834559]
How should I connect the three 5.1 analog jacks?
Use Realtek’s jack detection to confirm each plug is in the correct color‑coded port (front, rear, center/sub). If the panel detects connections, proceed to set 5.1 in Windows and run the test. Misplugging leads to fronts/sub only. The panel’s connection prompts help you verify wiring. [Elektroda, sylweksylwina, post #16835887]
My microphone stopped working after driver changes—what happened?
Driver conflicts can break both playback and recording. A user reported that after multiple swaps, “even the microphone in the headphones does not work.” Restore Windows to a point before the changes or fully clean and reinstall the intended audio driver. [Elektroda, N0dy1117, post #16835279]
Should I test with a DVD or file encoded in Dolby Digital 5.1?
Yes. Use a known 5.1 source to validate that rears and center channel play. Forum experts explicitly asked the user to test a DVD with DD 5.1, because stereo content will not engage surround speakers without upmixing. [Elektroda, sylweksylwina, post #16835270]
Windows audio is a mess after tinkering—what’s the fastest recovery?
Roll back using a System Restore point created before the changes, then install only the correct audio driver. As an expert put it, return to the restore point and install just the right thing. This avoids lingering conflicts. [Elektroda, jdubowski, post #16835605]
What does “5.1” actually mean for my Creative 6300T?
A 5.1 system uses discrete front left/right, center, rear left/right, and a subwoofer (.1) channel. To hear all speakers, you need 5.1‑encoded content or enabled upmixing. Testing with a DVD or file labeled 5.1 confirms true multichannel output. [Elektroda, jdubowski, post #16834568]
How do I set speakers to 5.1 in Windows 10 Sound?
Go to Control Panel → Sound → Playback → select your Realtek device → Configure → choose 5.1 Surround. Then run the test and verify jack detection in the Realtek panel. Sharing a Control Panel screenshot was requested in the thread to validate this step. [Elektroda, sylweksylwina, post #16835887]
I don’t see rthdcpl.exe—can I still use Realtek features?
Yes. Focus on installing the MSI‑provided Realtek package and confirming the Realtek icon/panel appears. The legacy process name may not match, but the vendor package enables the control panel and jack prompts needed for 5.1 setup. [Elektroda, sylweksylwina, post #16834559]
Can the Windows test pass, yet music still plays only on two speakers?
Yes. One user reported all speakers passed the test on a USB card, yet music remained stereo. This is normal for stereo sources. Enable upmixing or use real 5.1 content to engage rears and center. This distinction avoids misdiagnosing hardware. [Elektroda, N0dy1117, post #16834656]
What’s a safe, minimal process to reinstall audio and enable 5.1?
How‑To:
  1. Uninstall other audio drivers, reboot, then install MSI’s Realtek ALC1220 package for Z270 Gaming M3.
  2. Open the Realtek panel, confirm jack detection for front/rear/center‑sub, and select 5.1 in Windows.
  3. Play a known 5.1 source to validate rear and center channels. [Elektroda, sylweksylwina, post #16834559]
When should I consider replacing the sound card?
If clean installs, jack checks, and 5.1 tests still fail, a new card can be pragmatic. The original poster ultimately reported moving to a new sound card. Swapping hardware can bypass stubborn driver or codec issues on specific boards. [Elektroda, N0dy1117, post #17199430]
How many speakers will stereo content use without upmixing?
It will use 2 of 6 speakers (front left/right). That’s expected and not a fault. To involve rears/center, enable upmixing in your audio manager or play a true 5.1 file. This single fact explains most “rear speakers silent” complaints. [Elektroda, jdubowski, post #16835605]
