Low Sound Issue on Realtek Sound Card, MSI B85-G41 MOBO, Windows 7: Volume Sliders at 100%
Roojozzo 30537 12
Why is my Realtek audio on Windows 7 suddenly very quiet even though all volume sliders are at 100%?
First check the Windows mixer and make sure no individual app is muted or turned down, then reinstall the Realtek/audio drivers and test with another player such as VLC [#14693768][#14693815][#14694520] If Spotify, YouTube, AIMP, and Skype are still all quiet after that, the thread suggests the onboard audio codec on the motherboard may be damaged rather than it being a driver setting [#14693840][#14694174][#14695071] In that case, use the motherboard warranty or service it if warranty is no longer available [#14695406]
  • #1 14693687
    Roojozzo
    Help: 10
    Rate: 16
    Hello everyone. My problem is that when I listen to music it is way too quiet. I have all the sliders at 100% and the green bar that shows the volume of the music is up to half. The card is Realtek with the latest drivers, MOBO MSI B85-G41, and Win 7 Low Sound Issue on Realtek Sound Card, MSI B85-G41 MOBO, Windows 7: Volume Sliders at 100% This is what the greatest volume level looks like. Headphones are good, when I listen to music on my iPhone to the max, you can't have headphones on. It used to be very loud and suddenly it started quietly.
  • #2 14693753
    pitrala1
    Help: 129
    Rate: 111
    What program are you using to play music?
  • #3 14693768
    Nemonek
    Help: 106
    Rate: 378
    Click below on the "Mixer" inscription, you should open the sound levels of individual applications sending beeps, maybe one is muted.
  • #4 14693783
    Roojozzo
    Help: 10
    Rate: 16
    I usually listen to music on Spotify or YouTube.
    Added after 14 [seconds]:
    They all have maxx
  • #5 14693815
    pitrala1
    Help: 129
    Rate: 111
    Try to reinstall the drivers, and try to play music via vlc media player eg.
  • #6 14693840
    Roojozzo
    Help: 10
    Rate: 16
    I reinstalled and there seems to be an improvement on AIMP3 because it plays much louder and Spotify plays quietly, but that's probably because I have the free version. However, it still plays quietly on Youtube.
  • #7 14694174
  • #8 14694318
    pitrala1
    Help: 129
    Rate: 111
    But here you can see that there is a problem on the programming side! Because the system does not give 100% sound power, otherwise this green bar would fly 100%.
  • #9 14694520
    winmap
    Help: 361
    Rate: 753
    Reinstall all steroids together, starting from the plate.
    Then check if, for example, youtube is muted.
    Check all the sliders in the programs you play in that they are not muted below.
    If it does not help, I put on a Masterpiece diagnosis that I had a similar problem, although I may be wrong.
  • #10 14695071
  • #11 14695393
    Roojozzo
    Help: 10
    Rate: 16
    Piotrek Majstersztyk wrote:
    Rather, it will be a broken codec, because I do not think that the driver dedicated to this codec would do such a number.
    So what? Exchange motherboard?
  • #12 14695406
  • #13 14695415
    Roojozzo
    Help: 10
    Rate: 16
    If the motherboard has a guarantee, use it, if not, then service it with it.
    I just doubt it, because I bought most of the parts together with the album in 2013.
    @Edit. I reinstalled all drivers except graphics. Still the same, the system does not give 100% volume.
    @ edit2 From what I can see on the website from which I was buying, the album has a 36-month warranty, so you have to give it back.
    @ edit3 It is actually possible that something with the motherboard, because my friends complain that when I talk to them on Skype, they hear everything what I listen to.
The discussion revolves around a low sound issue experienced by a user with a Realtek sound card on an MSI B85-G41 motherboard while using Windows 7. Despite all volume sliders being set to 100%, the audio output remains quiet, particularly on platforms like YouTube and Spotify. Suggestions include checking the audio mixer for muted applications, reinstalling drivers, and using different media players like VLC and AIMP3, which showed some improvement. Concerns were raised about potential hardware issues, such as a damaged codec on the motherboard, leading to inadequate sound output. The user is considering returning the motherboard under warranty due to persistent problems, including audio feedback during Skype calls.
