[Solved] Realtek HD Audio Manager Not Starting on Win 10: Configuring 7.1 Sound on Gigabyte H81M-S2PV
Patryk402 20364 3
  • #1 17428207
    Patryk402
    Rate: 15
    Although it is in the task manager as running at startup and generally enabled.
    I have 4 speakers and only 2 work because I can't change the sound configuration in this manager by default set as (stereo) and I have a problem because this manager worked without problems on win 7. It looks like I click the icon and nothing happens literally.
    Those speakers that do not work are connected to this black input and when I connected to the pink one they worked, so I know that they are functional and you need to change it to 7.1 (I'm not sure), I will also add that I do not know if I have the correct realtek drivers for my board H81M-S2PV GIGABYTE motherboard, although I downloaded them to this motherboard model.
    Unless you know some other way to change this configuration without this Realtek Manager, I will also be grateful.
    aachi
    Help: 73
    Rate: 46
    You start this manager from the control panel or from the icon next to the watch?
    You can also try to enter "Sound" in the search field and "configure" in it, there should also be a selection of the number of channels.
  • #4 17429483
    Patryk402
    Rate: 15
    The version sent by colleague Roberto is correct and after installing the Manager is working properly.
    Thanks so much for your help and time.
    I close.
