He can hear himself in the speakers when I am talking to the micro.
szmid 59664 13
How do I stop my microphone from being heard through my speakers and headphones in Windows 7 with a Realtek ALC888 sound card?
Mute the microphone’s playback volume/monitoring slider in the Realtek HD Audio Manager’s microphone tab; that stops your own voice from being played back through the speakers/headphones [#9073675] If you also use Skype, change Skype’s audio output from Realtek digital output to Speakers so you can hear the other person [#9073742]
  • #1 9071157
    szmid
    Rate: 11
    Hi!
    I'll go straight to the problem. I moved my system from windows xp to 7 and after installing drivers for the sound card, there was such a problem:
    when I am talking into the microphone, I can hear myself in the speakers and in the headphones. When I call someone on skype, that person can hear me, but I can't.
    I like listening to music from speakers, so I want to have headphones and speakers plugged in.
    My sound card is built into the motherboard, it is the Realtek ALC888 # 8 channel sound card.
    And the motherboard is:
    GA-Q35M-S2
    http://www.gigabyte.pl/products/mb/specs/ga-q35m-s2.html
    RADU23
    Help: 2428
    Rate: 1732
    Right in the icon next to the watch and open, Then the Mixer-recording tab - mark with the tick FRONT MIC, MIC BOOST, FRONT MIC BOOST.
  • #3 9071291
    szmid
    Rate: 11
    @U.P.
    Did you give it to windows XP or seven?
    Maybe I'll come out as a rookie or something, but I can't find it. So I conclude that you gave me the solution to the problem on windows xp.
  • #4 9071307
    RADU23
    Help: 2428
    Rate: 1732
    I gave you the solution for the Realtec card. If you do not have this icon, change or install the drivers for the card.
  • #5 9071394
    szmid
    Rate: 11
    I have an icon, only in windows 7 they display a little differently. I found everything, go to the Realtek HD Audio Manager and please, I do not have the tab you are talking about.
    As proof, you have ss.
  • #6 9071412
    RADU23
    Help: 2428
    Rate: 1732
    Show screen from mic tab.
  • #7 9071424
    szmid
    Rate: 11
    Here you are :
    Thanks for the quick reply, by the way.
    Added after 26 [minutes]:
    Anyone else have any ideas? I care about it; P
  • #8 9072639
    RADU23
    Help: 2428
    Rate: 1732
    You have to figure it out with the microphone yourself, I had the same problem as you. Select acoustic echo cancellation and select microphone calibration.
  • #9 9072903
    szmid
    Rate: 11
    He's been working on it for a few days. I couldn't think of anything else so I wrote here.
    It all started to happen when I installed windows 7. I downloaded the updated headset then and everything went wrong.
  • #11 9073638
    szmid
    Rate: 11
    This video that you gave above is for windows xp, and as I said before, I have windows 7. These two systems are quite different, you know?; P
  • #12 9073675
    RoStER
    Level 30  
    Help: 98
    Rate: 28
    In the tab where you have the microphone, mute this slider from "playback volume". greetings.
  • #14 9073742
    szmid
    Rate: 11
    Okay, case's solved.
    In order not to hear in the loudspeakers, it was enough to do what RostER ordered. Thank you very much. However, to hear others via skype, it was enough to change the audio settings (of course in skype) from Realtek digtal output ba speakers. Thanks a lot for your help and best regards.
The user experienced an audio issue after upgrading from Windows XP to Windows 7, where they could hear their own voice through the speakers and headphones while using a microphone. The sound card in use is the Realtek ALC888, integrated into a GA-Q35M-S2 motherboard. Solutions discussed included adjusting settings in the Realtek HD Audio Manager, enabling acoustic echo cancellation, muting the playback volume slider, and disabling stereo mix. The user resolved the issue by changing audio settings in Skype to use the Realtek digital output for speakers, eliminating the feedback problem and allowing them to hear others during calls.
