Which gas cooker works with KNX and Satel Integra?
uzdzik 2514 4
  • #1 14754653
    uzdzik
    Help: 13
    Rate: 15
    i am looking for a solution to the problem of controlling a gas cooker to work with a fireplace and the rest of the automation in the house.
    I am looking for a cooker that preferably communicates via KNX or programmable inputs/outputs.
    I also want it to be able to communicate with an alarm system (satellite integra) which, for example, will report a gas shortage and send me an SMS.
    It is supposed to stop working when the fireplace is lit, but I can't turn it off because it still has to heat the water, and many other dependencies.
    First of all, I want to know which gas cooker will work with which automation system - satellite, siemens S7 etc....
  • #2 14755172
    kosmos99
    Help: 338
    Rate: 820
    uzdzik wrote:
    First of all, I want to find out which gas furnace will work with which automation system - satellite, siemens S7 etc....
    Whether with the control panel or PLC, communication will be via digital signals, i.e. the controller in the oven will short-circuit the appropriate contacts when a particular event occurs. So you need to read the instructions on the furnace controllers in question and check what signals are issued in the individual devices.
  • #3 14763197
    uzdzik
    Help: 13
    Rate: 15
    Doesn't anyone have anything proven- preferably to work with satel's knx module?
    grudziu
    Help: 14
    Rate: 14
    there is a bit of it, e.g. viessman (vitogate 200), buderus (FM446 and its newer version). I have experience with the Vitogate and it allows switching via KNX to "DHW only, no CH" mode.
  • #5 14799568
    uzdzik
    Help: 13
    Rate: 15
    I would also like to ask which of these cookers would be the most suitable for a 70 metre flat? The need for heating and hot water. The cooker is to be supplied from a 33 kg cylinder.
