How to Measure Resistance on Coil from Photo Using a Meter: Step-by-Step Guide
wodniakov 41406 3
  • #1 14770406
    wodniakov
    Please, give me a hint on how I can check the coil from the photo using the meter. My guess is I need to do some resistance measurement.
    KMal
    Help: 340
    Rate: 1434
    You check the coils with an ohmmeter. They should be around 70/75 ?. I don't know why there are 3 ends.
    In any case, where the resistance will be around 70 / 75?, connect the power supply, 12V battery, insert a drill (not deeply) into the coil, for example, connect the voltage - the drill should be pulled inside.
    Wodnik-W8
    Help: 17
    Rate: 45
    Hello. Check these two pins parallel to each other with a meter in the 200 ohm range, it should show several tens of ohms. If it does not show anything, the coil is unfortunately a loss. This third pin is the protective one. At a voltage of 12V, it is rather unnecessary.
  • #4 14771587
    wodniakov
    It turns out that the coil is functional. Thanks for the help :)
