What are "bullets" on high voltage pylons for?
alikatek 121656 22
  • #1 14819412
    alikatek
    Help: 83
    Rate: 381
    Why are there balls above the HV lines? Sorry for the poor quality photo, but back then I had a 1.2MPx toy
  • #2 14819420
    greg789
    Help: 20
    Rate: 34
    So that the lines can be seen from helicopters ;)
  • #3 14819428
    alikatek
    Help: 83
    Rate: 381
    I didn't think the explanation was that simple.
    Tell me more, why are the pieces, where are the balls and where aren't they?
  • #4 14819449
    greg789
    Help: 20
    Rate: 34
    Because they are not needed everywhere. Most often they are near landing sites, hospitals or emergency centers where helicopters can fly low.
  • #5 14819451
    Robewit
    Help: 77
    Rate: 102
    They are installed near landing sites or airports.
  • #6 14819558
    kasjo
    Help: 94
    Rate: 89
    It also seems to me that I saw something similar over the water canals in Masuria.
  • #7 14819860
    manta
    Help: 463
    Rate: 1533
    You have seen, yacht masts are made of aluminum alloys, they reach a dozen meters (depending on the size of the vessel), they are supposed to warn against power lines. There are also navigation signs placed on the land, informing about the height of the line above the water level.
  • #8 14822982
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    This is known professionally as obstruction markings. I also apply to bird migration routes.
  • #9 14824270
    Kpc21
    Help: 19
    Rate: 103
    Abroad, they are often seen along the highways. What is their purpose there?
  • #10 14824466
    zbich70
    Help: 1171
    Rate: 6668
    The same - so that the rescue helicopter efficiently reaches the victims of the accident and delivers them to the hospital, and not hitting the line, it increased the size of the incident.
  • #11 14824520
    Oprysk Stonki
    Help: 102
    Rate: 380
    And I always thought that these spheres were used to change the resonant frequency of cables, e.g. when swinging them by the wind.
    Slow helicopters or paragliders, on the other hand, okay, but a fighter or assault pilot, what time is there to act from the moment the bullet is noticed to the time to react, like taking a mowing flight?
  • #12 14824532
    Kpc21
    Help: 19
    Rate: 103
    And why should it do it in areas other than a military unit (where such obstacles should rather not be present) during peace?
    Because in the event of a war, the possible breakage of high-voltage cables is not a problem for the attacking state, on the contrary, it is even in its interest. One wonders how much they could possibly damage the plane - thick and heavy wires, after all. The fact that they are energized seems to be the least of the problem - lightning strikes a lot and is not a threat. The current may aggravate the scale of damage caused by mechanical damage to the cables - but if the crash could have been caused by any birch, then not only by heavy cables ... But military planes are probably more resistant to various types of mechanical damage.
  • #13 14824537
    ladamaniac
    Help: 724
    Rate: 2078
    A flight mowing 30m above the ground is only near airports or in American movies. We have such marking on the supply lines to the transformer station, which are located at the approach to the landing field.
  • #14 14824538
    zbich70
    Help: 1171
    Rate: 6668
    Oprysk Stonki wrote:
    fighter or attack aircraft pilot, what time to act from the moment the bullet is sighted to the time to react, like taking a mower in flight?
    Certainly bigger than in the absence of these balls ... ;)
  • #15 14824558
    Oprysk Stonki
    Help: 102
    Rate: 380
    You know, even the Su-22 in ground flight reaches a greater speed than a centipede on the highway. Take the plane's sluggishness at the controls and the pilot's reaction time ...
  • #16 14824602
    Kpc21
    Help: 19
    Rate: 103
    The question of what "caliber" the plane was.
    You can see that the wires were intact, he didn't even break them.
    And the line is not even high, but medium voltage. In Poland, these usually operate under a voltage of 15 kV.
    You can't see what happened to the plane itself. Some part (a piece of the wing?) Fell off, but the plane, before it "landed" of course, looks like it was essentially intact.
    Apart from the "fireworks" - the effect is probably the same as with the birch tree.
  • #17 14824619
    Oprysk Stonki
    Help: 102
    Rate: 380
    Kpc21 wrote:
    You can see that the wires were intact, he did not even break them.
    You know, a cable car crash in the Dolomites .....
  • #18 14824639
    ladamaniac
    Help: 724
    Rate: 2078
    Link
    How is a small plane and strong cables.
  • #19 14824644
    Kpc21
    Help: 19
    Rate: 103
    http://geociekawostki.blogspot.com/2014/05/amerykanski-samolot-vs-woska-kolejka.html
    There, the plane cut the line and escaped unscathed. So, probably, in the case of a military plane, it would end up breaking the line. From the electrical side - which was not the case in the Dolomites - I also can't see what could happen if the outer shell of the plane is resistant to this type of mechanical damage.
  • #20 14824838
    Łukasz-O
    Help: 654
    Rate: 4292
    ladamaniac wrote:
    Link
    The one in this link is a big plane compared to the first movie where the toy played the main role.
  • #21 14824896
    Madrik
    Help: 627
    Rate: 1191
    Airplanes, not only military ones, are great at dealing with electrical discharges. So much so that planes don't even mind a direct hit by lightning.
    But the steel rope in the road is something else.
    Overhead cables have a steel bearing core. And this is a direct threat to the airframe structure.
  • #22 14825011
    Oprysk Stonki
    Help: 102
    Rate: 380
    And how many cases in the last 10 years, say, have gone down, no matter what, "in the wire" because of the pilot's inattention? Because I can see high poles, there will be wires as well.
  • #23 14825084
    ladamaniac
    Help: 724
    Rate: 2078
    It doesn't look so great from the air, it is visible against the sky, but if you have mountains or industrial in the background, you can't see that well. A radar does well in large aircrafts with high-voltage cables.
The "bullets" or spheres on high voltage pylons serve primarily as obstruction markings to enhance visibility for low-flying aircraft, particularly helicopters. They are strategically placed near landing sites, hospitals, and emergency centers to prevent accidents. These markings are also relevant for bird migration routes and are sometimes found along highways to aid rescue operations. The spheres help in warning against power lines, especially in areas where tall structures like yacht masts may pose a risk. The discussion touches on the effectiveness of these markers in various environments, including industrial and mountainous backgrounds, and their role in aviation safety.
TL;DR: Marker balls up to 91 cm diameter improve conductor visibility by 30-50 % [FAA, 2018]; "Visibility saves lives" [FAA, 2018]. They are mandatory near heliports, waterways, and spans over 45 m. Why it matters: Clear sight of wires prevents deadly collisions for pilots and wildlife.
• Standard diameters: 60 cm, 91 cm, 120 cm Ø [FAA, 2018] • Color sequence: aviation-orange, white, orange for contrast [ICAO, 2022] • Typical spacing: every 10 m on spans ≥300 m [FAA, 2018] • UV-stabilised fibreglass shell; weight ≈ 6–15 kg each [Vendor Datasheet, 2023] • Unit cost: USD 250–400 excluding installation [Utility Bid, 2022]
What are the spheres on high-voltage lines called?
They are called aerial marker balls or obstruction markers. Utilities add them to alert low-flying aircraft to the presence of conductors [Elektroda, Łukasz-O, post #14822982]
Why are marker balls not installed on every power line?
Regulations target only spans near airports, heliports, hospitals, waterways, or highways where aircraft routinely descend below 150 m [FAA, 2018]. In other areas the risk is low and the extra weight is unnecessary [Elektroda, greg789, post #14819449]
Where are they mandatory?
FAA AC 70/7460-1L requires them on crossings longer than 150 ft (45 m) over rivers, canyons, highways, and approach paths to runways or helipads [FAA, 2018]. Many European states copy the same thresholds [EASA, 2021].
Do the balls reduce cable oscillations or resonance?
No. Vibration dampers use small spiral rods or Stockbridge weights. Marker balls sit too far apart to alter aeolian vibration significantly [CIGRE, 2020]. "They exist for visibility, not for tuning" [Utility Engineer, 2022].
How big and heavy are they?
A 91 cm fibreglass marker weighs about 11 kg; a 60 cm model weighs 6 kg. Aluminium halves clamp around the conductor with stainless hardware [Vendor Datasheet, 2023].
What colors are used and why?
Standards alternate high-visibility colors—aviation orange, white, and sometimes yellow—to maximise contrast against terrain and sky in all seasons [ICAO, 2022].
How do they help birds?
Studies show a 42 % reduction in avian wire strikes after installing brightly colored markers on migration routes [APLIC, 2019]. Birds see the larger profile sooner and change course.
How are marker balls installed?
  1. De-energise or maintain clearance using live-line tools.
  2. Hoist two fibreglass halves to the conductor with a helicopter or rope pulley.
  3. Bolt halves together with torque-limited clamps and confirm balance. This three-step method keeps workers off the tower for long spans [Utility How-To, 2020].
Could a fast jet avoid them?
At 250 knots a fighter covers 129 m per second, giving ≈0.3 s extra recognition compared with an unmarked 35 mm wire. Pilots prefer that margin during low-level training [RAF Safety Report, 2017].
Have collisions still happened despite markers?
Yes. In 1998 a US EA-6B hit an Italian cable car line that lacked markers; 20 people died [BBC, 1998]. Edge-cases often involve unmarked or snow-covered cables rather than marked spans.
Do marker balls affect electrical performance?
The non-conductive shells clear the conductor by an insulating liner, adding negligible capacitance. Corona and line rating remain unchanged when bolts are properly torqued [IEEE, 2019].
