What does the "Antenna Short circuit" message mean?
admgrcki 42321 5
  • #1 14833845
    admgrcki
    Hello, first of all I would like to point out that I am a layman and I came here looking for an answer to a problem that bothered me through Google.
    So the problem is as follows: At home, I have an antenna on the roof for receiving regular digital TV, connected to a T-connector with an amplifier, three cables go from the T-connector to three rooms - that`s all I need to describe what the installation looks like.
    I have two TVs: one quite modern and one a bit older (the latter has an mpeg4 decoder purchased separately).
    The TV with a built-in decoder works normally, but on the older one, after connecting, the message "antenna short circuit" appears.
    A puzzle: if I replace this older TV with a borrowed "modern" one (one with a built-in decoder), i.e. I have two "new" ones connected, both of them work.
    Can anyone explain to me why this is happening?
    Regards
    abart64
    Help: 271
    Rate: 633
    Maybe the decoder has the power supply option for the antenna amplifier turned on and sees the tee as a DC short circuit.
    Check in the decoder menu if this is not the case.
    Kazi_kam
    Rate: 9
    option_1
    Try to play with the "antenna power" function. Most TVs and decoders have such a function. If it is turned on, try turning it off in the decoder, and vice versa, if it is turned off, turn it on and see what the effect will be.
    option_2
    It is possible that the decoder is faulty or damaged
    option_3
    Try disconnecting the antenna amplifier from the power supply and see if the short circuit still persists.
  • #4 14834487
    KOCUREK1970
    Help: 3862
    Rate: 5490
    What kind of tee is it, exactly, what does it look like and where is the power supply in this installation?
    LeDy
    Help: 1992
    Rate: 2940
    admgrcki wrote:
    and one a little older (the point is that the second one has it decoder purchased separately mpeg4).
    The TV with a built-in decoder works normally, however, on the older one, after connecting, the message "antenna short circuit" appears .
    Puzzle: If I replace this older TV with a borrowed "modern" one (one with a built-in decoder), i.e. I have two "new" ones connected, both of them work.
    Can anyone explain to me why this is happening? ?
    Regards
    This message is given to you by the decoder and they have already told you what to look for . Turn off the antenna power in the decoder.
    to the tee with the amplifier,
    I won`t write anymore, but isn`t it logical that it has? active splitter ?
    Unless the author doesn`t know what he`s writing?
  • #6 14836468
    admgrcki
    The problem was solved by turning off the antenna power option in the decoder menu. Thanks for the help :)
