When the antenna is connected to the cable, the power supply diode goes out
maniek1203 17163 16
Why does the LED on my antenna power supply go out when I connect the cable to the DVB-T antenna, even though the TV end is disconnected?
The power supply LED goes out because the antenna side is effectively shorting the supply [#16172384] The thread points out that the TechniYagi UHD LTE antenna is a passive antenna with a balun, not an amplifier, so a power injector/voltage separator is the wrong match for it [#16172471][#16172805][#16172865] When the cable is connected only at the power supply, the LED lights normally, which confirms the short is on the antenna side, not in the TV lead [#16172384] You should check the antenna box and connector for any shield strand touching the center conductor, but the main fix is to use the correct antenna arrangement for a passive balun antenna or remove the power supply/injector [#16172384][#16172805]
  • #1 16172360
    maniek1203
    Hello! I bought a Samsung LED TV yesterday, and a TechniSat antenna for terrestrial television, as well as a cable and power supply (also TechniSat). When connecting the cable to the DVB-T antenna, the diode on the power supply goes out, regardless of whether the terminal on the TV side is connected or not, the cable on the antenna side is connected through the nut (F). Why?
  • #3 16172393
    maniek1203
    Kurtka na wacia wrote:
    A diode going out in the power supply indicates a short circuit. Double-check the power supply-antenna connection again. Often, one small wire from the shield causes a short circuit. Do you have an amplifier on the antenna? Is the LED on without the F plug connected to the antenna? Show the photo of the antenna and the inside of the antenna box as much as you can.
    I have checked the cable several times and the screen does not come in contact with the "hot wire" without the F plug connected, the LED lights up normally, the problem starts when I screw the nut into the antenna, I will send photos soon
    TELMOR_PL
    Level 32  
    Help: 158
    Rate: 234
    So the short circuit comes from the antenna side, maybe it is without an amplifier only with a balun? The balancer is a short circuit when we connect the power supply ...
  • #5 16172616
    maniek1203
    Is there any way to solve this?
    fidotp
    Help: 38
    Rate: 127
    First you need to check exactly what you have.
  • #7 16172766
    maniek1203
    Antena techniYagi uhdt lte
    • When the antenna is connected to the cable, the power supply diode goes out IMG_3910.JPG (485.65 KB) You must be logged in to download this attachment.
    • When the antenna is connected to the cable, the power supply diode goes out IMG_3909.JPG (362.16 KB) You must be logged in to download this attachment.
    LeDy
    Help: 1992
    Rate: 2940
    Crash the power supply, give the antenna plug and after a problem. There is a balancer, not an amplifier.
    TELMOR_PL
    Level 32  
    Help: 158
    Rate: 234
    Well, we have the culprit.
    The question arises: why / who advised the author to buy an antenna with a balun and a power supply with a voltage separator?
    And what is the location where this antenna should work?
    fidotp
    Help: 38
    Rate: 127
    I have better specs around here.
    They claim that no antenna tile is needed at all.
    One by one they crawl onto the roof and disassemble the balancer, connecting the cable sharply.
    TELMOR_PL
    Level 32  
    Help: 158
    Rate: 234
    And who prohibits the rich ... maybe they have symmetrical cables of concentric cities :D
    In one case, the symmetriser plate is not needed, ... for the logarithmic antenna.
  • #12 16173272
    maniek1203
    Thanks for all the advice, stupid advice was given by a saleswoman from RTV EURO AGD who claimed that she sells 5 such sets a day and it certainly works. The location is exactly Zubrzyca Górna, a single-family house, the signal I download from Gubałówka, found 39 programs of which 10 are Slovak channels (that's how it is with me :) ) The most important channels work fine.
  • #13 16173447
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    I can't resist asking where my colleague was connecting this power supply (where)?
    I admit that I went a little hard because I haven't been with antenna amplifiers for a long time. I forgot about the separator, which will most often be at the antenna plug. A really aware seller will not sell such a set, or the purchase was made in installments.
  • #14 16173528
    LeDy
    Help: 1992
    Rate: 2940
    And this is not clear?
    When connecting the cable to the DVB-T antenna, the diode on the power supply turns off, regardless of whether the terminal on the TV side is connected or not
    I take the correction for unprofessional terms.
  • #15 16173533
  • #16 16173558
    TELMOR_PL
    Level 32  
    Help: 158
    Rate: 234
    This is a good question, curiosity eats me up, but I don't know if we'll get the answer.
    The ground is that the situation "mastered" and the system worked because he did not have to, the rather difficult area.
    As for the saleswoman, we also sell through this network and I am afraid to think what these "experts" say to customers interested in buying equipment.
  • #17 16173962
    maniek1203
    what do you mean in which places? in one place, antenna cable to the plug from the power supply and all this from the TV side, contact power supply. How else?
The discussion revolves around a Samsung LED TV and a TechniSat DVB-T antenna setup, where the power supply diode goes out when the antenna is connected via cable. Users suggest that the issue may stem from a short circuit caused by improper connections or a faulty balun in the antenna. The original poster confirms that the LED lights up normally without the F plug connected, indicating the problem arises when the antenna is connected. Suggestions include checking the antenna's components, particularly the balun, and ensuring proper installation. The conversation highlights the importance of correct equipment selection and installation for optimal performance.
