Short Circuit on Antenna Cable: Storms & Electrical Devices Impact, Decoder Reset, Triax TMS 9X6P
easierone 21351 16
Why does one satellite decoder occasionally lose antenna signal during storms or when other electrical devices like a drill or grinder are switched on, while the other receivers keep working, and how can I fix it?
It is probably not a short circuit in the antenna cable, but an interference or signal problem caused by the electrical installation or the multiswitch. The storm part can be normal, because storm clouds can temporarily weaken the signal and it usually returns after a few seconds; that is different from a real short-circuit fault [#16605005][#16604674] If only one receiver/outlet is affected, swap the decoders or move the cable to another multiswitch output to check whether the fault follows the decoder, the socket, or the output [#16603021][#16605322] If the problem appears with several decoders, the multiswitch becomes the main suspect and replacing it is the simplest test/fix [#16605261] The fact that a grinder can trigger the issue points to interference from the tool or from the electrical wiring/sockets, since simple power tools often do not have interference filters [#16612360]
  • #1 16602479
    easierone
    The problem is:
    Once in a while, most often during a storm or after connecting some additional electrical devices, such as a drill, to the network, there is some kind of short circuit on the antenna cable.
    The effect is that the decoder gives the message about the lack of antenna signal, then I have to either reset the decoder (longer method), or remove and insert the antenna cable (now in the summer I have not tightened the plug, so that it would be faster, because every now and then a storm ). It looks like a short circuit would occur with minimal voltage invisible to the eye.
    The antenna sockets are next to the contacts, the signal is separated by the Triax TMS 9X6P, the cables are released in the walls. In total, 3 separate TVs and set-top boxes are connected. The problem occurs one at a time, when one of the decoders gives a message about the lack of a signal, the others work correctly.
    Is there any way to get rid of the problem?
  • #2 16602500
    rafcio_21
    Help: 137
    Rate: 299
    These three TVs operate from one antenna or separate?
  • #3 16602551
    easierone
    The antenna is one, the signal separates this Triax switch from it.
  • #4 16602586
    tomiok
    Help: 133
    Rate: 292
    Maybe you have a distorted (too strong) signal from Multiswitch?
    You won't know it without the meter.
    What sockets do you have - terminal or so-called through?
    Is this happening when watching SAT or terrestrial or both?
  • #5 16602618
    easierone
    The sockets are final, I only use TV SAT.
  • #6 16603021
    andpol 33
    Help: 513
    Rate: 1146
    Start by switching decoders.
  • #7 16603190
    tomiok
    Help: 133
    Rate: 292
    easierone wrote:
    ... or after connecting some additional electrical devices, such as a drill, to the network, there is some kind of short circuit on the antenna cable. ...
    And the electrical installation, is it certainly OK?
  • Questioning the short-circuit diagnosis on antenna cable
    #8 16603768
    Darek.S
    Help: 216
    Rate: 979
    easierone wrote:
    The problem is:
    The effect is that the decoder gives a message about the lack of antenna signal,
    That I interrupt timidly how do you know it's a short circuit. After all, there is no signal on the decoder (if I read correctly), and as far as I know there is a short circuit message when shorted. In addition, I can not really imagine a short circuit that occurs during a storm or turning on the drill. :shocked!:
  • #9 16604674
    tomiok
    Help: 133
    Rate: 292
    Well, no signal and a short circuit - these are probably two different messages?
  • Reset-required antenna fault, not a decoder short circuit
    #10 16604928
    easierone
    I don't know much, I thought it was a short circuit because you need to reset the decoder or remove and reinsert the antenna cable. With normal signal loss, this one just comes back after a few seconds. All other decoder functions work at all times.
    My wife regularly works with a grinder and this is the rule, a fired grinder is an error message on one of the decoders. And as for the storm is a fact, there are also signal fades, but such as I wrote above they return after a few seconds, in the latter case only the above helps.
    Perhaps it is the fault of the electrical installation, unfortunately the summoned electrician did nothing. Certainly this is not the fault of set-top boxes, I have already processed several from ordinary DVBTs, through polsat to nc +. The problem occurred at all.
  • Asking whether the fault affects DVB-T or one outlet
    #11 16605005
    Darek.S
    Help: 216
    Rate: 979
    It is normal - storm clouds obscure the signal but it is a temporary phenomenon - so let's not mix the storm in it. Remains of interference in the network (sparking)
    A few questions...
    Is the problem also on DVBT?
    Does it occur in a specific outlet or in the whole house?
  • #12 16605261
    tomiok
    Help: 133
    Rate: 292
    easierone wrote:
    ... Certainly this is not the fault of the set-top boxes, I have already processed several from ordinary DVBTs, through polsat to nc +. The problem occurred at all.
    So you can argue that the culprit is Multiswitch.
    The easiest way would be to change it.
  • #13 16605322
    Darek.S
    Help: 216
    Rate: 979
    That's what I was heading for. But if the problem is only in one socket, you can simply unplug them to another output. And since there are three TVs, one is definitely for use. But so far the author has not answered my question.
  • #14 16612360
    M.Mikolajski
    Help: 13
    Rate: 22
    Well, but if turning on the grinder causes perturbation, it is something with the grinder and / or the installation of the el.- the device should have an interference filter - or there is something in the electrical circuit in the distribution of the sockets :?:
  • Grinder interference points to tool or wiring fault
    #15 16612526
    Darek.S
    Help: 216
    Rate: 979
    As far as I know simple power tools, rather filters do not have them, while power supplies for electronic devices (multiswitch tuner)
  • #16 16612625
  • #17 16612746
    Darek.S
    Help: 216
    Rate: 979
    telper wrote:
    - unscrew any of the cables that comes to the multiswitch from the converter, e.g. from Hot Bird
    A good idea and if it will be a Hotbird and the cable will be HL (Horizontal Low or 18V 22kHz Off), it does not have to look for the effect, just turn on TVP1HD. The second alternative is VL (Vertical Low or 13V 22kHz Off) and TVN HD is in this range. Generally, most Polish stations are in these two ranges.
The discussion revolves around a recurring issue with a decoder losing antenna signal, particularly during storms or when additional electrical devices, like a grinder, are connected. The setup includes a single antenna connected to multiple TVs via a Triax TMS 9X6P multiswitch. Users suggest potential causes such as signal distortion from the multiswitch, electrical installation issues, or interference from power tools. Recommendations include switching decoders, checking the electrical installation, and testing the multiswitch by bypassing it to isolate the problem. The author notes that the issue manifests as a need to reset the decoder or reconnect the antenna cable, indicating possible intermittent short circuits or signal loss rather than a true short circuit.
