RGB in traditional enclosures, external controller for YKY 5x1.5, 7 lamps?
monter79 1392 0
  • Seeking RGB bulbs with power-on automatic color cycling
    #1 14896725
    monter79
    Help: 31
    Rate: 47
    Hello, I am looking for an unusual solution, for lighting the facade. The luminaires will be installed in the paving, except that instead of ordinary bulbs, I am looking for RGB light sources with an external controller. I have found remote-controlled bulbs, but this solution is out.
    Assumptions:
    1 When power is applied, the controller will switch on the RGB lighting in slow colour changing mode.
    2. Wiring YKY 5x1.5mm in series through 7 lamps. Length of all wiring 25mb.
    3 Optionally the same controller is to operate the RGB LED strip
    Has anyone fitted RGB bulbs that switch on when voltage is applied rather than from a remote control?
