Delphi DS150E Autocom connects to PC but not car—no system responded error
Staxu 72651 8
  • #1 14912759
    Staxu
    Rate: 9
    I have autocom fully communicating with delphi 2.14.2.2 software. The device communicates with the computer, the com port is set, the device test is successful, the hardware update is successful. For some reason I can't establish a connection with the car, as I do all the tests I get the message "no system responded". Does anyone know the cause? Could it be the com port settings? The cable from the device looks intact. I'm out of ideas, if anyone has an idea, please let me know.
    Ps. I will only add that before everything worked and now it does not communicate with the same car.
  • #2 14912767
    diablo23248
    Help: 102
    Rate: 614
    Generally, since there is communication with the interface ("...device test successfully completed..."), com has nothing to do with it. The problem lies with the interface - the car. What did you test on?
  • #3 14912768
    Staxu
    Rate: 9
    i.e. what car? peugeot 308 1.6 hdi
    and when it comes to the device, it is AUTOCOM CDP+
  • #4 14913221
    diablo23248
    Help: 102
    Rate: 614
    Have you tried to connect on universal obd (program settings)? Or on a different car model selected in the program?
  • #5 14913411
    Staxu
    Rate: 9
    Yes, universal cable, I don't know what you mean (program settings)...
    I tried connecting to my car on which everything worked, now it doesn't connect, I didn't change the computer in the car so it shouldn't make a difference. As CDP searches for a connection, the LEDs flash as usual, everything looks as it was, except that the connection itself fails.
  • #6 14913449
    leonov
    Help: 1039
    Rate: 2247
    Staxu wrote:
    LEDs flash as usual
    Can you hear the relays? even if it is 99% their fault or the quality of the solders on the board. I suggest starting with this. See how many repair offers for these devices are available at auctions.
  • #7 14913480
    Staxu
    Rate: 9
    So as I thought. I was hoping it was something programmable that could be fixed right away. Thanks for the help. However, if anyone has had similar experiences, please share.
  • #8 14913491
    Pawel wawa
    Help: 1262
    Rate: 4432
    Once well hit such a chinoshinobox and the end of communication. Repair device.
  • #9 15033914
    nici
    Help: 266
    Rate: 979
    If quinol is a matter of course.
    Facebook software update, and February on the switch board.
    OE doesn't have it, btw.
The discussion revolves around a user experiencing connectivity issues with the Delphi DS150E Autocom device while attempting to connect to a Peugeot 308 1.6 HDI. Despite successful communication with the computer and device tests, the user receives a "no system responded" message when trying to connect to the vehicle. Responses suggest that the issue may not be related to the COM port settings, as the device communicates with the interface. Suggestions include checking the relays and solder quality on the device's board, as well as exploring software updates or trying different car models in the program settings. The user expresses frustration, noting that the device previously worked with the same car.
