Removing Blown Tungsten Bulb Thread Safely: Potential Fire Hazards and Precautions
trzg 27867 17
How do I safely remove the broken bulb base from a chandelier, and is it safer to turn off the lighting circuit overnight to avoid a fire or short circuit?
Turn off the fuse/breaker before touching the chandelier, then remove the մնant bulb base with insulated pliers or long pliers; if you want extra safety, wear gloves and glasses [#14925960] [#14925961] [#14926585] There is a short-circuit risk from the remaining threaded base, so don’t assume it is harmless [#14926001] If you can’t remove it right away, leave the circuit switched off; if the room switch truly opens the phase, nothing should happen overnight, but wiring may be done differently and you can’t rely on the switch alone [#14926031] [#14926019] If you’re tired or unsure, stop and have an electrician deal with it in the morning [#14926018] [#14925961]
  • #1 14925946
    trzg
    Hello, a dozen or so minutes ago an ordinary tungsten bulb in my room exploded in a chandelier. The thread remained in the chandelier, the glass fell down. Pre-meter fuses went well and household ones too. I had already turned the switch off the chandelier and turned on the fuses again. For this reason, I have questions:
    1) How to safely remove this thread? I would like to add that the "phase" part of the thread flew along with the bulb.
    2) Will turning on the light with this switch cause a fire? For example, will the phase not be short-circuited with zero?
    3) Is it not better for (fire) safety to turn off the entire lighting fuse before going to bed?
    I would like to add that I called 991 and they told me that they only take care of the network ;)
    Regards and thank you
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Turn off the fuses, just in case (it is not known if the chandelier is not controlled by "zero"), then use pliers to remove the rest of the bulb.
    That's all the work.
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1569
    trzg wrote:
    I would like to add that I called 991 and they told me that they only take care of the network :wink:
    You made yourself a real ball :D Fortunately, you did not call the Bełchatów power plant :D
    Turn off the security, if you have it, take the pliers. For your safety, put on gloves and glasses and carefully wring out any residue. If you are afraid, invite an electrician to clean up tomorrow.
  • #4 14925973
    trzg
    Got it, thank you for the answers :D Probably not much would be missing, and if I called, the glass hardly fell in my eyes :) Is there a risk of a short circuit on the thread remnants in the chandelier?
    Łukasz-O
    Help: 654
    Rate: 4292
    Yes there is.
    opornik7
    Help: 316
    Rate: 1569
    Theoretically, no, but practically in front of the monitor, I can not give you such an assurance. I saw various "miracles" in homes.
  • #7 14926010
    trzg
    So, to be sure, it is better to turn off the electricity at night?
  • #8 14926016
    opornik7
    Help: 316
    Rate: 1569
    Don't you have "insulated pliers or tongs" at home? What are you for a peasant? ;) :D
  • #9 14926018
    Łukasz-O
    Help: 654
    Rate: 4292
    Turn off the electricity while you rummage around the chandelier.
    If you still haven't removed the bulb residue (it takes several seconds), you'd better go to sleep now and call an electrician in the morning.
  • #10 14926019
    DVDM14
    Help: 315
    Rate: 553
    Yes - you will have a guarantee that nothing will happen to you, for example, if the switch is on the neutral and not the phase wire.
  • #11 14926029
    trzg
    But of course I have ticks, I would only have to go to the garage, and I'm quite tired at the moment, and I prefer to do it when it's light. The only thing I am afraid of is that there may be some fire at night due to a short circuit on the remaining thread. I know that during the operation of pulling the fuses off, it only bothers me whether to turn them off at night.
  • #12 14926031
    DVDM14
    Help: 315
    Rate: 553
    If you turn off the light in the room (i.e. the switch through which you have the chandelier plugged in), nothing will happen overnight.
  • #13 14926032
    trzg
    Ok, I will. The only thing I don't know is the switch is currently off or on and that's the problem ;) But well, life is brutal, you have to take the risk
  • #14 14926036
    opornik7
    Help: 316
    Rate: 1569
    At home "being tired" ;) I would have left it until tomorrow. But what you do is your business.
  • #15 14926041
    trzg
    That's why I'll keep it until tomorrow. I just had doubts that this thread would not short-circuit and light the installation at night, because I am not sure if the switch is in the off position: p Well, we'll see :)
  • #16 14926049
    opornik7
    Help: 316
    Rate: 1569
    In normal ;) For the house / apartment, all switches, except for the stairs one, should be installed according to one system. E.g. down key - on. Up off. Simple, it's a pity that not for everyone and everywhere.
  • #17 14926076
    trzg
    For me - unfortunately it is different: /
  • #18 14926585
    lukiiiii
    Help: 82
    Rate: 392
    "Long pliers" will be the best.
A user experienced an explosion of a tungsten bulb in a chandelier, leaving the thread in place and raising concerns about safety and potential fire hazards. Responses emphasized the importance of turning off the fuses before attempting to remove the bulb remnants using pliers, preferably insulated ones, and wearing protective gear like gloves and glasses. There was a consensus that turning off the entire lighting fuse at night is advisable to prevent any risk of short circuits, especially if the switch's status is uncertain. The discussion highlighted the unpredictability of electrical systems and the importance of safety precautions when dealing with electrical components.
