How do I integrate Satel Integra 128 WRL control panel with F&Home?
jacek1987-1987 2373 3
  • #1 14927009
    jacek1987-1987
    Rate: 15
    Welcome,
    I have such a question, is anyone able to tell me how I could integrate the Integra 128 wrl control panel with the F&Home system? What intermediary device do I need to use for this?
  • #2 14927057
    tomix
    Help: 7
    Rate: 99
    What integration effect would you like to achieve? If you think about it longer, these are two independent systems running in parallel.
  • #3 14927073
    jacek1987-1987
    Rate: 15
    I would like the control panel to give a signal to the F&Home system to switch off all appliances when the alarm is armed when no one is home, i.e. cut off gas at the solenoid valve, water, switch off appliances that are on standby etc. I am also open to any suggestions other than my assumptions
  • Using a relay and 24 V input for F&Home shutdown
    #4 15009819
    jark1990
    Buddy, I don't know what the current version of the F&Home system is like, but in the first version of their system there was a "switch off all" input in the mH-IO32 module. Applying 24V to this input resulted in switching off the relevant outputs (it was possible to program the outputs to be switched off - it did not switch off exactly all the outputs but only the ones you wanted). The only idea I can think of is to use a relay output from the control panel (it is necessary to use an additional expander) and, through this output, temporarily feed 24V to an input in the F&Home system. Because I am not aware of any intermediary devices to connect these systems e.g. via some kind of bus.
