Manta LED2205 TV: Seeking W25Q32 Memory Chip for HK-T.SP9202V05 Board - LED2204 Incompatible
Piotrek34 5283 6
  • #1 14931667
    Piotrek34
    Rate: 36
    Looking for the W25Q32 memory chip for the Manta LED2205 TV.
    HK-T.SP9202V05 board.
    The original memory is damaged, the programmer does not read the content.
    From the LED2204 model does not work.
    Greetings.
  • #2 14932023
    stacho57
    Help: 170
    Rate: 449
    And what matrix?
  • #3 14932044
    Piotrek34
    Rate: 36
    M215HW03V.1 matrix
  • #4 14932076
    stacho57
    Help: 170
    Rate: 449
    I have to matrix M240HTN01.2. Keep trying.
    • U4_W25Q32BV.BIN (4 MB) You must be logged in to download this attachment.
  • #5 14932127
    Piotrek34
    Rate: 36
    Unfortunately, on this file, it will only turn on the TV without the backlight.
  • #6 14932290
    stacho57
    Help: 170
    Rate: 449
    You have one more.
    • W25Q32FVS1G_ID_EF4016_U4.BIN (4 MB) You must be logged in to download this attachment.
  • #7 14945678
    Piotrek34
    Rate: 36
    This one also does not work.
    Maybe someone has the ability to read from the TV.
The discussion revolves around the search for a W25Q32 memory chip for the Manta LED2205 TV, specifically for the HK-T.SP9202V05 board, as the original memory is damaged and unreadable by the programmer. The author notes that attempts to use a memory chip from the LED2204 model have failed. Participants inquire about the matrix type, with the author confirming it is M215HW03V.1. Other users mention having different matrices, such as M240HTN01.2, but these do not resolve the issue, as they only power the TV without backlight functionality. The author expresses a need for assistance in reading from the TV to find a suitable solution.
