[Solved] VW Passat b5 1.8 20v 2000 - Engine Fails to Start When Warm: Sensor, Fuel Pump or Coil?
Maksiu922 11178 9
Why does a VW Passat B5 1.8 20V start normally when cold but fail to start when warm, and what should be checked first?
Check the engine with a diagnostic tester first, because in this case the warm no-start was linked to a camshaft adjustment/camshaft sensor fault (17927 / P1519) and dirty contacts on the 3-pin connector, especially the middle pin [#16557605][#16558838] Replacing the sensor later fixed the problem and the car started and ran normally again [#16624959] If the engine still cranks but there is no spark during the failure, the ignition module should also be checked [#16562373] Another reported cause for the same symptom was a cracked cold solder joint in the main relay near the ECU under the hood [#17060453]
  • Warm-start no-start points to sensor or fuel issue
    #1 16557597
    Maksiu922
    Rate: 10
    I ask for advice. I have a VW passata b5 1.8 20v 125km. The car is not gassed, only petrol. The problem is that on a cold engine the car smokes right away, without any problems. However, if the engine heats up a bit, it doesn't burn anymore. I can turn the key and nothing. Even on the pop will not light. The engine then turns nice, without problems but does not want to start. For example, once on a hot day I drove 80 km I parked and wanted to move the car and did not start. 7h later I get in and lit it immediately. I made 1km to gas stations and that's a problem. I tried a cake to the air intake, pushes and nothing ... And an hour later (in the meantime I tried to fire it many times) it fired as if nothing had happened. I am asking for advice on where to start? Currency sensor Fuel pump? Or maybe a coil or something else? Someone maybe had a similar case with this engine or this electrics?
    Thank you for your advice and best regards
  • #2 16557605
    Ireneo
    Help: 747
    Rate: 2469
    Start by checking what is missing when it doesn't smoke best from the tester level.
  • #3 16558838
    Maksiu922
    Rate: 10
    This case looks like this. Although the car fired without a problem, after connecting the VAG, it showed an error - "17927 - camshaft adjustment P1519 - 35-10 - fault - Sporadic". After unplugging the sensor at the valve and removing it, it turned out that the contacts have become dirty (gray coating). Especially the middle pin (3-pin connector) was heavily soiled and he was responsible for the signal and problems. Sensor to be replaced in the future.
    I would like to point out that on a cold engine, it would start without problems even after it had cooled down. On warm time after repeated filming or not at all.
    Greetings and thanks Ireneo
  • #4 16561980
    misterbociek
    Help: 40
    Rate: 120
    My colleague in Audi 1.8 APT had it like that, something was probably wrong with some relay or something. Then I'll try to call him and let you know.
  • #5 16562373
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    If there is no spark at the moment when I do not want to ignite, then from what I associate, there often ignited ignition modules, it should be at the right cup
  • #6 16562390
    Maksiu922
    Rate: 10
    Thank you very much for your interest but as I wrote above the matter has already been solved ;) .
  • #7 16562430
    misterbociek
    Help: 40
    Rate: 120
    As for this sensor in the front of the head near the timing cover, you can detach it yourself, the engine will work the same. I know I have this engine and I tried; P
    I talked to a friend and his main computer relay broke down and the warm engine wouldn't start.
    I recommend you check the vacuum bulb in the intake manifold and on the coil. As I washed the engine, I flooded it and fell, I bought a drug and my friend's coil broke and bought a new one for PLN 450 :)
  • Main relay failure can cause warm no-start
    #8 16563989
    Maksiu922
    Rate: 10
    As long as nothing happens, I do not move :) . I will go and if nothing happens for a month, I will let you know. And if there were problems again, I would check the relay. I solved this problem based on the computer. Because the fact that the relay disconnected is just an error pops up but the engine flies :) .
  • #9 16624959
    Maksiu922
    Rate: 10
    So after a month I can write what's going on. I admit that in the meantime I decided to replace the sensor (2 weeks ago) about which I wrote early. As we know from a week the temperature below 30 degrees does not drop during the day or at least at my place :) (a holiday would be useful: p). For now, the car drives and smokes without a problem and it seems that he was the cause of the problem.
    Greetings to you
    And the sensor, of course, Bosch, and 230 PLN when it comes to costs
  • #10 17060453
    Maksiu922
    Rate: 10
    Eventually the cold solder on the relay was cracked. Relay near the computer under the hood. Corrected February in the relay.
The discussion revolves around a VW Passat B5 1.8 20v (2000) experiencing starting issues when the engine is warm. The owner reports that the car starts without problems when cold but fails to ignite after running and then parking. Various potential causes are explored, including a faulty camshaft adjustment sensor, ignition modules, relays, and vacuum issues. The owner eventually identifies a dirty sensor as the primary issue, which was resolved by replacing it with a Bosch part. Additionally, a cracked cold solder on a relay was noted as a contributing factor. The car now operates normally without smoke or starting problems.
