VW Passat B6 2006 2.0 Diesel Loses Power at High RPMs, Error 16618 Overboost
Gun 181196 27
Why does my 2006 VW Passat 2.0 TDI lose power at high RPM with error 16618/P0234 overboost, and what should I check or repair?
The most likely cause is a sticking variable-geometry turbocharger, where the vane control ring/actuator does not move freely, so boost rises too high and the ECU cuts power to protect the engine [#6978413][#6979544] Check that the vacuum actuator moves smoothly through about 1.8 cm in basic settings/group 011, and inspect the vacuum hoses, N75 valve, vacuum pump, pneumatic system, and actuator itself because any of them can trigger the same fault [#6978206][#6982084] A practical fix suggested in the thread is to remove the turbocharger, clean the variable geometry thoroughly, and reassemble it without changing the marked adjustment positions [#6978413][#6979424] In the reported case, thorough turbo cleaning solved the problem and the limp-mode/overboost fault did not return [#7518009]
  • #1 6978115
    Gun
    Rate: 17
    Hello everyone, I have a problem with the passat b6 2006 2.0diesel today, while driving in 6th gear at around 4500 rpm, the glow plug light turned on and the car lost power at the same time, after turning off the engine and restarting it returns to normal and again at higher revs at a speed of about 120 km / h the same happens,
    after connecting to the computer, it shows error No. 16618 the program is in the English version also the rest looks like this: boost pressure regulation
    : limit exceeded (overboost condition)
    I will just add that I had an earlier passat model in which it was similar, I replaced the n75 valve, the so-called boost valve and after the topic, only that there after the error code 17964 indicated that the regulation limit was not reached, which is opposite to what is happening here ...
    please help. :cry:
  • #2 6978206
    KamilW.
    Help: 6
    Rate: 26
    Everything seems to be the same in this case, but the forum is not a workshop and it cannot be said unequivocally that it is the fault of the turbine control transducer, i.e. how you wrote it for the 75 valve. % without diagnostics and I'm not talking about connecting a diagnoscope. It may be a valve, but it may well be the vacuum pump has lost its vigor and will also display a transducer error. It may be the fault of the pneumatic system or the actuator itself.
    fil2006
    Help: 63
    Rate: 395
    http://wiki.ross-tech.com/index.php/16618/P0234/000564
    Added after 8 [minutes]:
    buddy, this is the problem of the bearing in the compressor with variable geometry, the problem is that it rubs and does not work smoothly, it does not come back and the effect is exceeded the regulation limit, i.e. too high top-up pressure, which results in the ECU turning off the boost system control to protect the engine before destruction because the pressure must not exceed 2.4 bar, the pressure above can lead to e.g. opening of the inlet valves, which will cause a big boom.
    Added after 5 [minutes]:
    You can try to disassemble the compressor and clean the variable geometry along with this bearing often works and everything works ok.
    This is not another problem, because if the regulation limit is exceeded and just about 120 km per hour, it happens, and after turning off the ignition and restarting it is ok again for the given speed
    and don't look for a kumaty mechanic anywhere, you need to disassemble the turbine, clean it and install it.
  • #4 6979128
    Gun
    Rate: 17
    Thank you gentlemen for a quick answer, I checked the ross-tech site, I had so close and I did not look there thanks to FIL2006, I bought a hex + can cable from them, according to what they suggest are vacuum hoses and the n75 valve itself to check, about this turbine, what a colleague FIL2006 mentioned, in total, it is also worth thinking because the car was slightly knocked and stood for some time (the turbine hung in the middle), moreover, I read on the forum that if you do not put it once in a while, it can silt up and the effect may be similar , and I do not know who drove it before because I bought a knocked one from the insurance company - I will add that I live in the UK. oh, gentlemen here are literally magicians mechanics :) and not in a positive sense :(
    I am replacing the steering gear at my friend's mechanic in the older model of the belt from 2003 (exactly the one that had similar symptoms after replacing the n75, he passed and 170 ponies are nice) if I work, I will get a turbo for it, as my friend FIL2006 advises.
    As soon as I get to something, I will definitely describe the entire scope of work, maybe someone will save time, money in the future and immediately remove such a defect from his b6 passat without unnecessary costs.
    I have not mentioned my colleague KamiluW, which does not mean that I do not appreciate your opinion, if you feel offended, I apologize.
    Sztomel
    Help: 284
    Rate: 1237
    fil2006 wrote:
    buddy, this is the problem of the bearing in the compressor with variable geometry, the problem is that it rubs and does not work smoothly, do not come back
    Could you enlighten us about what kind of bearing is it ?!
    fil2006
    Help: 63
    Rate: 395
    toc joz has long been checked, connect the tester and eat at the probe in the channel, probably 10 measured values, check the charging pressure, it will exceed 2.4 bar and the power will drop, the error will be displayed.
    oh and it also happens in new cars, the impact of driving is too high sometimes drivers: they save "the car and it is made to drive and sometimes it has to get burned, You can try pouring wd 40 through the egr valve inside and overhaul the car several times, it helped me more than once and I did not have to pull out the turbine.
    it is the ring which guides the blades, it is professionally called a bearing
    Oh, I poured this agent in older models, not necessarily in this
    if it has egr coolers it may not be possible
    Sztomel
    Help: 284
    Rate: 1237
    the ring is called a bearing - interesting since when? - neither the placenta resembles nor has such a task,
    you don't have to explain to me what is the cause of the variable geometry sticking and the boost pressure value works well in group 011.
    the engine of the founder of the topic has an exhaust gas cooler.
    fil2006
    Help: 63
    Rate: 395
    http://www.vw-passat.pl/index.php?option=com_content&task=view&id=266&Itemid=11
    there, this control ring is a bearing because it is professionally called and it does not work smoothly causes the turbine to overload, there you have everything shown, someone wanted to take photos and praise him, Remember not to touch these adjustments on the boost regulator marked with paint because it is then difficult set. Do not turn anything, just mark yourself as the guest showed before disassembling and clean and assemble. You do not touch the rotor and you do not disassemble anything, it remains as it was before, you do not interfere in it.
    Added after 58 [seconds]:
    buddy, if you will work using professional documentation, you will find out what it is called.
    and when you speak, help and do not criticize my professional friend because I am one.
    Added after 17 [minutes]:
    http://forum.vwgolf.pl/viewtopic.php?t=78603
    handlebars and three "bearings" (bushings)
    I don't want to add my technical documentation here, buddy
    Added after 41 [seconds]:
    and it's not because I'm keeping it to myself it's just a lot of fun to box it up
    Sztomel
    Help: 284
    Rate: 1237
    fil2006 wrote:
    buddy if you will be working using professional documentation then you will find out what it is called.
    and when you speak, help and do not criticize my friend professionals because I am one .
    professional documentation, professional - hello good!
    you tell your colleague to disassemble and clean the turbocharger and you did not even advise him to check with his hand or Vag in group 011 in Basic Settings mode, as for the vacuum actuator string regulating the angle of inclination of the blades of variable geometry - it has to move freely without jams in the range of 1.8 cm, you are such a professional.
    Nobody tells you to paste your entire professional documentation here - just paste a few screnów of the most important ones.
  • #10 6981740
    mercedesik
    Help: 80
    Rate: 522
    If the author in this bar has a dpf filter, good luck with pulling the turbine-massacre
  • #11 6981896
    janusz2008
    Help: 170
    Rate: 515
    Some people think that a bearing must have balls. And that's not true.
    Sztomel
    Help: 284
    Rate: 1237
    I know what types of bearings are and what function they have to fulfill, but probably not everyone knows, and calling the control ring with the variable geometry of the blades of the blades is a pure misunderstanding and misleading someone - which of course does not mean that I do not agree with the col.fil2006 that I am to blame it is responsible for this overloading condition that the variable geometry is blocked.
  • #13 6981969
    brandy-p
    Help: 128
    Rate: 542
    And the B6 2.0 tdi does not control the blades with the servo motor (this is what I associate with it)
    Added after 30 [seconds]:
    Maybe there is a problem
    Sztomel
    Help: 284
    Rate: 1237
    Neither the 140 HP and 170 HP engines have a servomotor, the vacuum actuator is pneumatically controlled, and only in 170 HP 2.0 TDI the variable geometry actuator has limit sensors, with FAP there is also a differential pressure sensor, exhaust gas temperature sensor and lambda probe, the servomotor has turbines in 3.0 TDI engines
    and as for the professional nomenclature, even ETKA is banging on in the style of calling the vacuum accumulator - a silencer - embarrassment.
    fil2006
    Help: 63
    Rate: 395
    buddy, that's why I always try to read in English, unfortunately, there are a lot of errors in Polish, besides, we, Poles, have only a good joke and nothing but that, we create nothing and we are not the leader of the automotive industry, so there are no technical names in Polish / Everything is trying I just need to translate it somehow and it goes wrong, which is the reason for pointless disputes more than once.
    it is enough to use original names and the problem is solved and technical English is really easy. It's a pity that you didn't work on vasa in English for a few years I had the pleasure when I came back to the Polish website and worked in Polish, I grabbed my head and asked every day their what they do. As a result, I ignored this work and I do not intend to undertake any more on our websites.
    Added after 55 [seconds]:
    see i for example i don't know what you call servo motor?
    Added after 6 [minutes]:
    turbine with variable geometry is recognized in the simplest way by the boost pressure actuator. If it is mounted vertically in relation to the turbine rotor, the variable geometry is variable, and if horizontally in relation to the turbine rotor, then it has a bleed-off valve.
    Sztomel
    Help: 284
    Rate: 1237
    the servo motor is the controller of the turbocharger with the motor performing the work of the then vacuum actuator.
    As for the vertical and horizontal position of the actuator, starting with the 90 HP AGR engine, all other than ANU PD have VNT.
    fil2006
    Help: 63
    Rate: 395
    Oh, and he will correct that I did not advise him about what you write because, as I wrote above, such a symptom at 120 loses power after turning off the ignition and driving again is ok to about 120, and this error is this 100% problem and another simply cannot be because I used to do it in about 20 cars. Of course, at the beginning it was not so clear with the first and the next, but then it went like clockwork.
    Sztomel
    Help: 284
    Rate: 1237
    fil2006 I'm for cleaning variable geometry but not with the nomenclature you use, no bearing but a ring because it only misleads others.
    fil2006
    Help: 63
    Rate: 395
    well, the servomotor, and in the English documentation and in the vasa it is called turbocharger control unit, I think J217 I may be wrong about this j but it is important and it is the way it is, and the servomotor is associated with? Servo + motor ??
    good good it's okay to argue, let there be a ring: -}
    Added after 24 [seconds]:
    because the bearing in the wheel will wash away
    Sztomel
    Help: 284
    Rate: 1237
    the bearing in the VNT can be associated with the turbine shaft bearing and the servomotor only with external control of variable geometry, unless there are other servomotors besides the turbine - if I even put it this way, everyone knows what's going on - do I tell someone that it's about a servomotor that regulates the blows of meat in pea soup for this money.
  • #21 6996267
    Gun
    Rate: 17
    Hello everyone, I can see that the topic has exploded, which proves that there are still people who will advise you selflessly how and where to bury something to fix something.
    Buddy -fil2006- do not worry about the bearings in the wheels I will not wash :)
    I agree with my colleague -Sztomel- that the correct nomenclature is the basis, there is no point in developing bad habits, which involves misleading people - because how can they help you if they do not know what kind of turbo bearing you mean? :( probably many wondered what the hell the bearing is so fancy, what it fades and you need to clean it :)
    Coming back to the problem, so far I only had time to replace the fuel filter and change the oil, I also added a fluid to the fuel - which allegedly - cleans the injectors and the catalyst is also supposed to reduce exhaust emissions, I lost it a bit in lower gears and, interestingly, it did not turn on yet the emergency mode and he got to 4th gear almost to the end, tomorrow I will go to the ring roads and check how it behaves on the 5th and 6th, if nothing has changed, I take the turbine into rotation.
  • #22 7013499
    Gun
    Rate: 17
    Hello, I am already in Poland with this belt, it did not work to chase it away on the route, due to the fact that I have never done it and I would not want to spoil something
    I have a question if someone would clean this turbo? I am asking for a quick reply if possible.
  • #23 7013722
    fil2006
    Help: 63
    Rate: 395
    to clean it is no problem, but the question is how will it fail? Who will pay for the removal and installation of the turbine?
    where are you from ??
  • #24 7013805
    Gun
    Rate: 17
    Thank you mate fil2006 for a quick reply - my answer is: of course, I will pay for the removal and installation of the turbine - even if it fails - it will be clean in the end - and at least for this :)
    besides, as it turns out that this is not what I will pay for the exchange of n75
    please provide a quote for this treatment and possibly the address and phone number.
    And I am from the vicinity of Wrocław, I can drive almost anywhere along the route to Warsaw and then to Lomze.
  • #25 7019119
    fil2006
    Help: 63
    Rate: 395
    I'm too far, I will not suggest prices.
  • #26 7234765
    tommiuk
    Hello everyone, has the same problem as a colleague from Passat 2006.
    In 4th gear at 3,000 revolutions, the glow plug indicator blinks and the engine loses power.
    I also have a Passat from 2006, did the turbine cleaning help ??
    Do you want to return to Poland with this car or maybe something else breaks down?
  • #27 7234951
    jaro710426
    Better fix it first and then go back to Poland ha ha
  • #28 7518009
    Gun
    Rate: 17
    Hello everyone, it's a little late, but better late than never :)
    So back to the topic: the problem in my streak was solved by thorough cleaning of the Turbine (as my colleague Sztomel suggested) everything that was dirty was cleaned, after installing any more messages on the dashboard or power drops while driving, there was no more than 1700 with speeds of most 180-200 km / h.
    In general, I will say that Passat B6 2.0 TDI (140) too low power for a station wagon is once, the first two signs of the end of the thrust bearing (or the entire clutch) already at 200,000 km, three strange thing with this turbo cleaning, B6 ALREADY SOLD but gladly I offer advice on an earlier model from mid-2003. 1.9TDI (130) which I have already 4 years, after tuna (170) on a 19 inch rim :D I've been driving for two years (my leg is heavy), I highly recommend this older drive unit.
    I cordially greet all VW users in Poland and the UK
The discussion revolves around a 2006 VW Passat B6 2.0 Diesel experiencing power loss at high RPMs (around 4500) and triggering error code 16618, indicating an overboost condition. Users suggest potential causes including issues with the N75 boost control valve, vacuum pump failures, and problems with the variable geometry turbocharger (VGT). Cleaning the turbocharger and its variable geometry components is recommended as a solution, as well as checking vacuum hoses. The conversation highlights the importance of proper terminology regarding turbo components and the necessity of thorough diagnostics before making repairs. Several users share their experiences with similar issues and solutions, emphasizing the need for professional cleaning of the turbocharger to resolve power loss.
TL;DR: 90 % of VAG overboost faults trace back to sticky VNT vanes [Bosch, 2016]; “cleaning fixes it 8 times out of 10” [Elektroda, fil2006, post #6982499] Fault code 16618/P0234 means the turbo is making too much boost and the ECU cuts power. Why it matters: ignoring overboost can burst hoses or damage pistons.
• VW fault 16618/P0234 = boost ≥ 2.4 bar before ECU cut-off [Elektroda, fil2006, post #6978413] • N75 valve price: €45–€70 OEM (2024 listing, Autodoc) • Variable-geometry turbo removal on B6 with DPF adds ≈2 h labour [Elektroda, mercedesik, post #6981740] • Actuator rod travel spec: 18 ± 2 mm, vacuum 180–250 mbar [Garrett, 2017] • Typical VNT cleaning job in PL: 400–600 zł incl. re-install (AutoBild PL, 2023)
What causes error 16618 / P0234 on a Passat B6 2.0 TDI?
The ECU sees boost pressure exceed its 2.4 bar limit, so it logs P0234 (16618) and puts the engine in limp mode to protect it [Elektroda, fil2006, post #6978413] The usual root cause is sticky variable-geometry vanes, a weak N75 boost solenoid, leaking vacuum lines, or a lazy vacuum pump.
How can I quickly test the turbo actuator at home?
  1. Pull a 0–1 bar hand-vac pump on the actuator hose.
  2. Rod should move 18 ± 2 mm smoothly and hold vacuum 30 s [Garrett, 2017].
  3. Any stiction or leak points to vane fouling or diaphragm damage.
Can driving in limp mode harm the engine?
Short trips are safe, but prolonged limp mode starves EGR and DPF regeneration, raising soot and intake temps. Over 200 km in limp can clog the DPF and degrade oil [Bosch, 2016].
What’s the three-step fix most owners use?
  1. Remove turbo and separate hot housing.
  2. Ultrasonically clean vane ring and guide pins; no grinding [VW TPI 204321].
  3. Re-assemble, marking stop-screw positions as shown by VW to retain calibration [Elektroda, fil2006, post #6979424]
Does WD-40 through the EGR really help?
It may temporarily free light soot build-up, but it can foul the DPF and is useless for heavy carbon [Elektroda, fil2006, post #6979363] Professional cleaning is safer.
What if my Passat has a DPF?
On DPF-equipped B6s, turbo removal is harder because the filter blocks access; expect two extra labour hours and new downpipe gaskets [Elektroda, mercedesik, post #6981740]
Could the vacuum pump be the hidden issue?
Yes. A worn tandem pump delivers < –0.6 bar at idle, starving the actuator. Measure pump vacuum before blaming the turbo [Elektroda, KamilW., post #6978206]
How often does cleaning fail and a full turbo rebuild is needed?
Around 10–15 % of cases need a rebuild due to excessive shaft play or cracked housings, according to Garrett service data (2019).
Is a servo-motor turbo fitted on the 2.0 TDI 140 PS?
No. Both 140 PS and 170 PS B6 engines use a vacuum-actuated VNT; only the 3.0 TDI gets an electric servo-motor [Elektroda, Sztomel, post #6982084]
What other edge-case can trigger P0234?
A split intercooler hose can fool the MAP sensor into over-boosting at part throttle before the leak vents, causing transient overboost and the same code.
After cleaning, what boost numbers should I log?
Target and actual boost should track within ±100 mbar up to 2.2 bar under full load in 3rd gear. Larger gaps indicate remaining control issues [Ross-Tech Wiki].
