Samsung and others - What temperature should you use to peel off touch screens and LCDs
sagem90 29628 7
  • #1 14989095
    sagem90
    Help: 22
    Rate: 85
    Hello, I have a window heater and I always have a problem when removing the LCD screen. It's going somehow, but "tediously"
    I decided to buy a heat gun
    Temperature range: 40-400 degrees C
    I have a question about how to safely remove the LCD, e.g. in a Samsung S4.
    How much should I spend on the heater and then at what temperature should I heat it from the bottom with a heat gun?
    What is the approximate heating time?
    And the second question, I would like to remove the touches properly, e.g. in LG, so that the original gasket - glue remains. Also, can I do it with just a heat gun?
  • #2 14995758
    misiekelk
    Help: 47
    Rate: 121
    A good heater, 70 degrees measured on the LCD and a cardboard playing card, and all Samsung models come off. And the seals and adhesives can be replaced with new ones. And this heat gun is a container. Buy a Makite or Steinel with smooth temperature and air flow control.
  • #3 14996424
    sagem90
    Help: 22
    Rate: 85
    Hello, thanks, could you tell me in more detail how you do it? I read that the most optimal temperature is 90 degrees, but I don't know how much to set for the back of the phone frame.
  • #4 14997872
    Multi_COM
    GSM specialist
    Help: 93
    Rate: 60
    @sagem90: pay attention to what misiekelk wrote - measure the temperature on the LCD and don't rely on what you have on the device
  • #5 14999386
    sagem90
    Help: 22
    Rate: 85
    Multi_com do you have any thermometers?
  • #6 15000489
    Multi_COM
    GSM specialist
    Help: 93
    Rate: 60
    There are some, but buy a regular probe and connect it to a meter - most of them can measure temperature and it will be the cheapest
  • #7 15002976
    sagem90
    Help: 22
    Rate: 85
    I didn't even know, to sum it up. We can heat the entire LCD with a heater or heat gun from the bottom or top, as long as the temperature is around 70 degrees, right?
  • #8 15003865
    Multi_COM
    GSM specialist
    Help: 93
    Rate: 60
    If you are talking about separating the LCD from the frame, it is best to use a separator - after bathing in chemicals (if it is AMOLED), first a heater, then a heat gun - the whole thing looks like here https://www.youtube.com/watch?v=GdY1Jx8ykmw
To safely remove LCD screens, such as from a Samsung S4, it is recommended to use a heat gun with a temperature range of around 70-90 degrees Celsius. Users suggest measuring the temperature directly on the LCD rather than relying on the heat gun's settings. A good practice is to heat the LCD from the bottom or top, ensuring even distribution of heat. For optimal results, a separator tool may be used, especially for AMOLED screens, after applying heat. Maintaining the original adhesive when removing touch screens, like those from LG, can also be achieved with careful heating techniques.
