Galaxy S4 I9505 heats up and discharges quickly
foniu2 6261 4
  • #1 16220773
    foniu2
    Rate: 19
    In Galxy android 6.0.1 cyanomod. New battery. One day the telephone fell down and the display crashed. It has been replaced with a new one. But since then, the battery when using the phone discharges extremely quickly 1% in 3 minutes and of course the screen heats up strongly at the height of the flash. It sometimes heats like it would hang, because even if I turn off the phone, it won't cool down anyway, only the phone off and on. With charging the phone no problem there is no heating, but sometimes you can see how the charging LED blinks slightly. Is going to diagnose and fix the fault yourself.
  • #2 16220927
    majsterek
    Help: 79
    Rate: 70
    foniu2 wrote:
    the display crashed. It has been replaced with a new one. But since then the battery discharges extremely quickly when using a telephone
    Why are you not advertising? A display defect or folding error may be the cause. Did you restore the phone to factory settings?
  • #3 16221229
    foniu2
    Rate: 19
    Yes, the phone was restored to the factory settings. And the new display has bland colors.
  • #4 16221383
    majsterek
    Help: 79
    Rate: 70
    If you have the opportunity, advertise ...
  • #5 16284040
    Erka09
    I had a similar problem, the phone was very hot and the battery could fall within 2 hours. Sometimes even at 40% the phone could turn off as if it was unloaded. I replaced the battery but the problem persisted. At one of the forums, someone advised me to start the phone in an emergency and helped. I don't remember exactly how it went, but there was something like turning the phone on / off while holding the bottom volume button. As you type in google it will definitely pop up :)
