How do I open the door on the button? Looking for information.
Murdoc123 2493 3
  • #1 15010646
    Murdoc123
    Hello, I'll say right off the bat that when it comes to electronics I'm a bit green.
    I wanted to get some information about a push button door, a normal door that is locked but the release of the bolts is dependent on the push button.
    In short, I would like to have a button in one room that allows access to another room.
    Regards and thanks in advance :)
  • #2 15010900
    oldking
    Help: 162
    Rate: 524
    Install an electric lock in the door.
  • #3 15010987
    Murdoc123
    thank you, if you are on the subject would you show me such a lock that I can fix myself? i have no idea how to do it, what is the principle of the button that opens the door and does it have to be close to the door or can it be in a completely different room?
  • #4 15097156
    68mustang
    Rate: 10
    Buy an electromagnetic hitch. It is powered by two cables. All you have to do is run a current through it and the lock opens. This is how intercom-operated wickets work. You can have the button where you want it. All you have to do is run a cable from the button to the lock and hook up the power supply.
