Choosing a 3-phase UPS for a 10kVA home - how to connect and is it worth it?
zaper13 3213 4
  • Questions about whole-house UPS and generator integration
    #1 15011973
    zaper13
    Rate: 9
    I'm considering getting a UPS for my house due to frequent voltage drops and no power 5sec-30min and electrical equipment doesn't like that kind of thing. Once there was 17 hours out due to a storm in 2 years. Ideally it should be 3-phase on input and output. Why 3-phase then it could be plugged in directly under the installation and output directly to the installation then it would serve the whole house. But the price is 2x more expensive than a 1-phase UPS. And probably easier to plug it in then :)
    For the whole house ordered power of 10kW only the induction hob uses 3 phases, the rest goes on 1 phase. I have the installations divided up for the lighting, individual floors in the house and the kitchen and dishwasher separately. So would it be possible to hook up the single-phase one somehow?
    As for the power of the UPS I'm thinking about 10kVA, it should be able to pull the whole house without the induction hob. Of course, I would use it on battery power if there was no power, e.g. dishwasher, washing machine and iron.
    I have a further query about when the power is out for a longer period of time, I would like to connect the aggregate to the installation and then charge the UPS slowly. I wonder if a 3.5kV 3-phase or single phase aggregate would be suitable for this and able to charge the UPS. Or would the UPS just not see power from it because the power is too low. I know that if I want to connect the genset to the installation I will have to buy a mains/aggregate switch and still preferably approach the power company and anger it to have a clear conscience.
    From what I've found the smallest one is 10kVA and the price starts at 13,000s, although there are also the same ones for 28,000s. I assume that every company is a company and the device is not maintenance-free and the batteries need to be replaced from time to time. I have also seen on the internet used UPS from 3-7 thousand PLN. Is it worth to be interested in such a thing?
    What ideas do you have to do this and protect your home from power failure?
  • #2 15012010
    kindlar
    Help: 919
    Rate: 1624
    How about self-producing for your own needs?
  • #3 15012143
    zaper13
    Rate: 9
    kindlar wrote:
    Can self-generate for own consumption?
    Can you elaborate on the statement?
  • #4 15012435
    kindlar
    Help: 919
    Rate: 1624
    Start with how much power do you need in an emergency? What appliances are needed, what power.
  • Eight-hour backup for 120 W continuous loads and controls
    #5 15012461
    zaper13
    Rate: 9
    I would like to back up fridges, lighting, monitoring, house control (electric blinds and a control panel controlling various things and internet). Of these, the fridges and monitoring run non-stop and take about 120W per hour. The roller shutters and control panel work when I use them, but for example at night or in the morning it would be good to open or close the shutters. I'd like the UPS to back it all up for me for up to 8 hours. What is the total current of all things I will give in the evening when I have calculated it all.
