Lowering Overfilled Pressure in De Dietrich MCR3 Gas Stove: Seeking Step-by-Step Guide
Kacp3r7 24771 9
How do I lower the pressure in an overfilled De Dietrich MCR3 gas boiler back to normal?
Lower the pressure by draining water from the central-heating circuit, usually with the drain valve on that circuit. If you cannot find the valve near the boiler, you can release water through the vent on one of the radiators, preferably the highest one so any trapped air can escape too [#15063311][#15063321] The exact valve location depends on the installation, so you may need to inspect the pipework or take photos to identify it [#15063311] The safety valve can also let out excess water when pressure/temperature rises, but the replies suggest using the circuit drain or radiator vent for this problem [#15063274][#15063311]
  • #1 15063158
    Kacp3r7
    Hi
    I have a De Dietrich MCR3 gas stove.
    Recently I noticed that the pressure on the stove was too low, so I turned on some water to raise it... and unfortunately I overfilled it. I have 3 now and would like to get them down to "normal". I looked in the manual and on the Internet and I still don't know how to do it.
    Can someone explain this to me like a 5 year old?
    Thanks
  • #2 15063274
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    During use, when the temperature and pressure increase, it will leak out of the safety valve, which you should check during the season.
    You can also pour out as much as you want with this valve, but I don't see the need (unless the boiler reports an excess on the computer ; and there's a huff).
    Valve
  • #3 15063289
    Kacp3r7
    Of course, I have my furnace inspected once a year.
    But what bothers me is that I have a clue in the red area. Where exactly is this valve located - because I have several of them.
  • #4 15063311
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    If you added water to the central heating circuit, drain it using the valve in the central heating circuit.
    It's hard to guess what you have there, installation depends on the installer's imagination.
    Unless you want to take photos, then go ahead ;)
  • #5 15063321
    BILGO
    Help: 393
    Rate: 725
    If you cannot find the safety valve near the stove, you can release the water, for example, through the vent on one of the radiators. ;)
  • #6 15063327
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    If so, it's best to place it in the highest position, as some air will escape from the knife ;)
  • #7 15063376
    Kacp3r7
    Your smiles distract me... :)
    So it will be safest if I drain the water from one of the radiators?
  • Drain small amounts from the highest radiator and recheck pressure
    #8 15063394
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    Come on, stop distracting yourself ;)
    It's so hard to find a safety valve in the central heating circuit? It's not an installation in the Palace of Culture and Science to get lost in the pipes. :D
    Finally, you can go to the furthest/highest radiator, fill your wife with a bowl of a few liters from the kitchen, and first pour 0.5L, sprint to the basement, check the pressure, repeat until you succeed - your private trainer recommends ;)
  • #9 15063422
    BILGO
    Help: 393
    Rate: 725
    Or maybe he will find a central heating system drain valve along the way? :D
    bestboy21 wrote:
    and drain 0.5L at the beginning,
    Why so modestly? immediately with 5 liters... if it is not enough, I will add water again :D
  • #10 15063562
    Kacp3r7
    I won't be far because I have an apartment. The stove in the bathroom is under the ceiling and the highest valve is in the ceiling (under the flap) - I also don't mind. I'll pour out 1 liter and we'll see
The discussion revolves around lowering the overfilled pressure in a De Dietrich MCR3 gas stove after the user inadvertently added too much water to the system. Participants suggest checking the safety valve, which can release excess water, and recommend draining water from the central heating circuit or a radiator. The location of the safety valve is emphasized as crucial, with advice to use the highest radiator for draining. The user is encouraged to monitor the pressure closely while adjusting the water levels to achieve normal operating conditions.
