Squeak during ignition in the DE DIETRICH MCR HOME 24/30 gas stove - overheating?
Taggin 23124 10
Why does my DE DIETRICH MCR HOME 24/30 boiler squeak briefly during ignition, and could it be overheating because it starts often?
It is more likely a burner whistling/squeaking at low flame or minimum power than overheating. The boiler has a minimum power of 5.2 kW at 50/30, so if the radiators or room demand less heat, it may keep cycling and raise the water temperature repeatedly; boiler settings, room regulator settings, and water flow all matter [#19057940] In one case, increasing the temperature helped at first, and later changing the Tybox PI setting to 30 minutes and lowering the room temperature to 21.5°C stopped the squeaking for about a month, which pointed to the thermostat causing frequent starts [#19190248] Another reply noted that burners can whistle when gas flow is low, and that cleaning the main burner and flame stabilizers/nozzles can help if there is dust, soot, or debris inside [#19177660] A similar case with a new boiler was also identified as burner squeaking at low flame rather than a fan or other mechanical noise [#19194702] If the boiler was already inspected and cleaned without change, the behavior may be normal in your installation conditions rather than an actual fault [#19190248]
  • #1 19057887
    Taggin
    Rate: 82
    When the stove is turned on (ignition), it squeaks for a while. The stove is new, one year old. In general, it lights up frequently, could it be due to overheating? The stove is DE DIETRICH MCR HOME 24/30
  • Minimum boiler power may cause frequent cycling
    #2 19057940
    BUCKS
    Help: 536
    Rate: 1087
    Taggin wrote:
    In general, it comes on often, could it be due to overheating?
    according to technical data, this boiler has a minimum power of 5.2 kW for boiler water 50/30.
    If the power of the radiators for a given boiler water temperature is lower than the minimum boiler power, the boiler will constantly raise the boiler water temperature.
    If the boiler temperature is set too low, the boiler turns off the burner when it is reached and after an appropriate time lock or when the sensors detect the appropriate water temperature in the boiler, it will restart unless the room regulator turns off the heating request. I don`t know your boiler, so I`m writing in general terms.
    The settings on the boiler and the settings in the room regulator, its operating algorithm, water flow through the radiators, etc. are important.
    This may also be normal behavior of the boiler in your conditions, but I do not rule out some fault if it worked completely differently before.
  • Condensate whistling from oxygen shortage in chamber
    #3 19057944
    irus.m
    Heating systems specialist
    Help: 122
    Rate: 453
    "It`s hard for me to understand what you mean," he squeaks.
    If it is not the whine of the fan at high speed or another mechanical noise, a vibration/whistling sound sometimes appears in the condensates when there is a lack of oxygen in the combustion chamber.
    You have to listen to it in person or measure it with an analyzer.
    the fact that it starts often may be a symptom of low heat demand, for example a small installation and the boiler is not working properly.
    Regards
  • #4 19058395
    Taggin
    Rate: 82
    Yes, this firing is normal. However, what I mean is the sound when the burner is turned on, as if it were whistling/squeaking. Raising the temperature on the stove helped me once, but now the problem is back
  • #5 19066109
    Taggin
    Rate: 82
    I`m refreshing it, when it squeaks it did, I turned up the temperature a bit. It doesn`t squeal every time I turn it on, but it happens a few times during the day
  • #6 19066196
    BUCKS
    Help: 536
    Rate: 1087
    maybe this squeaking is the effect of the buzzing of the coils in the gas module when it works at minimum power?
  • #7 19066484
    Taggin
    Rate: 82
    This sound is unpleasant, more of a squeaking than a buzzing sound. I can hear it in the living room from the bathroom
  • Cleaning burner and flame stabilizers stopped whistling
    #8 19177660
    maciejkao
    Help: 6
    Rate: 30
    Sometimes the main burner can whistle like this when the gas is flowing through it with sufficient efficiency. I had something like this in Termet G-19-02. Then I disassembled the stove and, among other things, thoroughly cleaned the main burner and flame stabilizers. There must have been something there, crap, burnt dust, soot, etc. whether in the burner or in the nozzles, we don`t know. After washing, it whistled only when the gas was turned on properly, but at low and medium power it stopped. Generally, once a year the stove should be removed from the wall, taken apart, washed, blown out, what needs to be lubricated, what needs to be descaled, etc. Now I have an old Ariston GIWH, which is about six years old, bought for a lot of money as a damaged one. and works flawlessly, but you need to take care of it.
  • #9 19181971
    ROWE
    Help: 239
    Rate: 535
    So hurry up because the warranty is already uphill.
  • #10 19190248
    Taggin
    Rate: 82
    I had a warranty inspection.
    There was nothing there, it was cleaned, etc. It didn`t make any squeaking noise when operated. After cleaning it still squeaked.
    I changed the PI setting in the tybox to 30 minutes and reduced the temperature in the house to 21.5. He hasn`t squeaked for a month.
    Most likely it was the burner squeaking, the tybox caused it to turn on every now and then.
  • #11 19194702
    tw57
    Rate: 16
    The burner in the gas stove (new Electrolux kitchen) makes a squeaking noise when the flame is low,
    so it`s definitely your burner that`s squealing.
    Regards.
The discussion revolves around a squeaking noise during ignition in the DE DIETRICH MCR HOME 24/30 gas stove, which the user suspects may be related to overheating. Responses indicate that the noise could be due to various factors, including low heat demand, mechanical vibrations, or issues with the burner. Some users suggest that the squeaking may be a result of the gas module operating at minimum power or a buildup of debris in the burner. Adjusting the temperature settings and regular maintenance, such as cleaning the burner, are recommended solutions. The user noted that changing the settings on their thermostat helped reduce the noise.
