Samsung UE32D5500: Power Supply (BN44-00458A) Behavior After Motherboard Disconnection?
Rubinh 6540 3
  • #1 15065872
    Rubinh
    Help: 7
    Rate: 67
    How should an efficient power supply (BN44-00458A) behave in the TV set after disconnecting the power supply to the motherboard ?. With me every 4 seconds there is a voltage impulse, the backlight will blink and so on. 5V voltage is correct. TV after overvoltages in the network.
  • #2 15066522
    Olek II
    Moderator
    Help: 452
    Rate: 413
    If there was an overvoltage, it is possible to short-circuit the secondary voltage on any branch.
  • #3 15066587
    Rubinh
    Help: 7
    Rate: 67
    In one of the posts about a similar power supply, I read that after disconnecting the motherboard, the power supply works constantly, the backlight works and that's what I was asking about. I just wanted to make sure this is the case. The fact that there is a short circuit on any branch of secondary voltage is known by itself. Without a pattern of looking for a fault, they do not make much sense when someone is in a hurry.
  • #4 15066730
    lisek
    Service technician RTV
    Help: 6332
    Rate: 6843
    Read and understand Link
    Then look for similar info. (about IC used there) in this forum.
    It is slowly being repaired on the workbench of this power supply BN44-00458A. Link
    - stby ICS801s STRA6052M 5.3V
    After the on / of H administration should appear
    B5V = 5V B13V = -13V, AMP = 13V
    and 1.3V 3.2V 2.5V 5V on DC / DC Main, respectively
    helpful from the forum
    - BN44-00428B / BN44-00351B
    - BN44-00428B PD55B2_BHS (FA5591N SQD3011K FSFR1800XSL SLC4011M)
    ps
    In S models from the "6" series
    First flash-Standby OK.
    Second flash-Low voltage switch signal.
    Third flash-Low voltage level check.
    Fourth flash-VS switch signal OK.
    Fifth flash-VS signal OK.
    Sixht flash-high voltage is an OK panel.
