samsung - led tv SAMSUNG UE40D5003 power supply+driver LED : BN44-00473A -not tu
zoro33 3273 4
  • #1 19847092
    zoro33
    I have this tv with this problem: at start-up, the St.By LED flashes twice, after which it stays in St.By, sometimes the LED flashes twice in a cycle of 5 times. At the start, for a moment, is present the tensions PFC = 390V, voltages of 5.2V, 12.7V and voltage for led driver, after that this tensions fall in 0 https://showbox.bio/ https://tutuapp.uno/. I replaced ICP801S = SPC7011F, ICM801 = FSFR1700XSL, the electrolytes caps beside these two integrated and PC801S, PC802S, PC803S optocouplers, I redo the soldering, including the smd components, "cold" measurements on components. Only the voltage St.By = 5.2V, the rest, no change. With the coupler removed from the mainboard, the backlight does not work at all. Maybe someone has encountered this problem, thank you!
  • #2 19860587
    mirek 1
    Rate: 12
    I had a similar problem, no matrix backlight.
  • #3 19860682
    Indyczes
    Help: 185
    Rate: 270
    I confirm that I had the same panel illumination damaged.
  • #4 19934855
    jeanfares
    What voltages do you have on led connector?
  • #5 20025042
    ivtv1
    A LED TV BACKLIGHT TESTER is needed to check the diodes
