Does the SOMFY Tahoma work with Z-Wave control panels like VERA or FIBARO?
rnarek 4890 2
  • #1 15114741
    rnarek
    Hello!
    I would like to ask whether SOMFY products, i.e. roller shutter drives, garage door operators and others based on the Z-WAVE network protocol (i.e. a frequency somewhere around 868Mhz) are compatible with other Z-WAVE control panels such as VERA or FIBARO, for example?
    Anyone have any?
  • #2 15117800
    Marek J.
    Help: 526
    Rate: 951
    Z-Wave is Z-Wave and is always compatible within a territorial group ( there are different frequencies in different regions).
    Somfy products are not directly adapted to Z-Wave and TaHoma is like another system competing with Z-Wave.
    Somfy does, however, sell interfaces that allow its drives to be controlled via Z-Wave....
  • Somfy Tahoma supports only selected Z-Wave devices
    #3 20206441
    VG
    Somfy products are not directly compatible with Z-Wave and TaHoma is like another system competing with Z-Wave.
    This is a very old topic but after so many years not much has changed and I am writing to warn others : SOMFY has its own Z-Wave support policy and NOT ALL Z-WAVE devices are supported by SOMFY.
    How do I know ?
    Well, from the fact that I have a Tahoma control panel and SOMFY roller shutters and Fakro Solar roller shutters ( Z-Wave) and despite buying a Z-Wave dongle for the Tahoma, it was not possible to run the Fakro roller shutters with the Somfy Tahoma. After consulting the Fakro service I received confirmation that this is Somfy's policy thus eliminating the competition.
    Fakro can be freely controlled from other Z-Wave based home automation systems
