Bosch - Gas-electric cooker: how to raise to the level of the countertop?
skydancer 29475 9
How can I raise a gas-electric cooker by about 40 mm so it is level with the countertop?
The cooker should be brought up to the same height as the worktops, because with larger pots the flame may reach the countertop edges [#15196831] Since the cabinets cannot be lowered, the practical solution is to recreate the previous setup and place 40 mm blocks/board sections under the stove’s feet [#15209702][#15224667] A board of the right thickness from a DIY store is enough; it can be cut to size [#15224667] The gap should then be hidden with a plinth matching the adjacent cabinets for a functional and neat finish [#15224667]
  • #1 15196785
    skydancer
    I recently replaced the gas and electric cooker. It turned out that the previous stove was placed on a kind of raised platform / plate, which was screwed to it so as to be level with the neighboring worktops. This base could not be reused, it was taken away along with the old kitchen. The new one, after insertion, is 40mm lower than the table tops, with the leveling legs fully extended. Please see the picture. My question is: can you leave it like that, and if not, what to put under the bottom of a new kitchen to raise its level? Ordinary wooden board is enough?
  • #2 15196831
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    It is advisable that the hob is at the same height as the worktops, note that when using larger pots, the flame may reach just those of the worktops.
  • #3 15197037
    skydancer
    This is what I am afraid of. Can you just put a wooden board underneath it will lose this difference, or does it have to be some special mat / board for this purpose?
  • #4 15197046
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    These 4 cm are neither a dog nor an otter, you need to use a solution that will be functional and aesthetic. If you can, insert a photo from the front of the kitchen, taking into account the original feet.
  • #5 15203653
    skydancer
    This is what it looks like.
  • #6 15206039
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    Can the remaining countertops with cabinets be lowered to the level of the kitchen? I have the impression that at the moment they are too high, unless they were made to order and were supposed to be of such height.
  • Questioning whether the surrounding countertop height can be lowered
    #7 15209601
    skydancer
    There is no such option, I have already bought a flat with a ready kitchen and as I wrote in the first post, the previous gas stove had a screwed up platform (some DIY), but I was not able to translate it into a new stove.
  • #8 15209702
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    It remains in this arrangement to apply the same solution.
  • #9 15224628
    skydancer
    Do you think that an ordinary MDF board of the appropriate height (40mm) is enough for this?
  • #10 15224667
    TomaszC.
    Help: 60
    Rate: 842
    Looking at the second photo, I estimate that the distance between the floor and the bottom edge of the oven is about 3-5 cm. In my opinion, blocks made of a 40mm board should be placed under the stove's feet and the whole thing should be masked with a plinth similar to that in the adjacent cabinets. The height of the plinth will result from the sum of the current distance and the above-mentioned 40mm. You can get the board and cutting it in any DIY store.
The discussion revolves around the installation of a Bosch gas-electric cooker that is 40mm lower than the surrounding countertops. The user seeks advice on whether it is acceptable to leave the cooker at this height or how to raise it to be level with the worktops. Responses suggest that the hob should ideally be at the same height as the countertops to prevent issues with larger pots and flames. Suggestions include using a wooden board or MDF board of appropriate height (40mm) under the cooker’s feet, with the possibility of masking the height difference with a plinth similar to adjacent cabinets. The feasibility of lowering existing countertops was also considered but deemed not possible in this case.
