How to Adjust/Reduce Dishwasher Height from 81.5cm to 80cm: Tips for Built-in Kitchens
Kenjiro75 32259 4
  • #1 16979976
    Kenjiro75
    I have a serious problem, I have a built-in kitchen in which the height to the countertop is 80 cm and I can not find a dishwasher under it!
    The lowest dishwasher (width up to 45 cm is at stake) is 81.5 cm. From what I can see, you have experience with dishwashers here, so maybe someone will tell you if there are 80 cm or 81.5 cm dishwashers in which you can disassemble any legs or something and break these 1.5 cm?
    Thanks a lot for any suggestions!
  • #2 16980066
    DiZMar
    Help: 2891
    Rate: 6648
    Kenjiro75 wrote:
    I have a kitchen, where the height to the countertop is 80 cm ...
    The mistake was made by the mounting top. For me, the kitchen top is 82 cm high. It will be difficult to find a dishwasher lower than 81.5 cm tall. The legs are practically nonexistent and the 81.5 cm size used is standard. Although here state that height 80 cm.
  • Dishwashers may require chipping tiles for clearance
    #3 16980113
    yanes
    Help: 210
    Rate: 609
    You didn't go crazy with those 82 cm either, my height is 88 cm and the kitchen is 20 years old. IKEA has a standard height of countertops, from the floor to the working surface 92 cm, minus 4cm the thickness of the top remains 88cm. I met such dishwashers that need 87 cm, and in this case you can only chip the tiles under the dishwasher, provided that the countertop can be dismantled before placing the dishwasher in such a hole.
  • #4 16980143
    DiZMar
    Help: 2891
    Rate: 6648
    yanes wrote:
    You didn't go crazy with those 82 cm either ...
    It was not me "crazy" but a company that assembled custom-made kitchen furniture.
  • #5 16980242
    mychaj
    Help: 214
    Rate: 941
    And you don't have adjustable feet under the cabinets ??? There should be adjustable legs and a plinth made of plate fastened to these legs.
