Bosch WAB24262PL/03 Washing Machine - E21 Error Persists After Brush Replacement
tatra-mario 48246 22
How do I clear the E21 error on a Bosch WAB24262PL/03 after replacing the brushes, and does the door need to be closed?
E21 on this Bosch is cleared with the door closed; the door lock matters, so it is not a reset you do with the door open [#15975601][#15977351] Use this procedure: selector to OFF for at least 2 seconds, then turn the selector clockwise to position 15 while holding START, wait until the display lights up, and then release START [#15977351] The original poster confirmed that this procedure cleared the error [#15983820] If the washer still will not spin afterward, the thread points to the motor/control side: check the triac, relays, solder joints, wiring harness/connectors, and the tacho/motor connection [#16004068][#16173792][#18819657] In the end, the reported fault was not just the brushes; the triac/motor-related repair was what got the machine working again [#16173508][#16228468]
  • Door lock status may prevent clearing E21 error
    #1 15975142
    tatra-mario
    Rate: 43
    The brushes are exhausted - replaced, but the E21 error cannot be cleared - I tried the method recommended on the Internet, but several dozen different attempts have no effect. Knob at 6 o`clock -> spin button -> knob at 7 o`clock -> release the button. The door is closed but not locked. I have an additional question: is it possible to clear the error when the door is not closed? (maybe this mechanism is damaged)
    Washing machine as at the address provided
    Or maybe I`m implementing the procedure incorrectly?
  • #2 15975271
    Piotr2608
    Help: 851
    Rate: 4487
    Your options are:
    - try to clear the error using the above method until successful
    - try to upload or replace the eeprom
    - buy a new module
    ZimTech Piotr Zimny
  • #3 15975419
    tatra-mario
    Rate: 43
    So the method is good. So the door lock is not important?
  • #4 15975601
    Piotr2608
    Help: 851
    Rate: 4487
    Important - the lock locks after pressing the "START/PAUSE" button.
    In your case, you don`t press it. You turn the knob clockwise to 6 and then, holding the "SPIN" button, turn the knob clockwise one position to the left per hour. 7 and release the "SPIN" button.
    ZimTech Piotr Zimny
    mrhari
    Help: 835
    Rate: 3239
    Errors are deleted differently in this washing machine.
    1 close the door
    2 selector switch to OFF position and after a minimum of 2 seconds
    3 selector clockwise to position 15 while keeping the START button pressed
    4 wait until the display lights up and release the start button.
  • #6 15983820
    tatra-mario
    Rate: 43
    Thank you, Mrhari, for the correct instructions - the error has been cleared.
    But the issue is not resolved yet because when you turn on the spin cycle, the water pump turns on but the drum motor does not (I received the washing machine - apparently the brushes were broken, some service technician came and changed it and was unable to clear the error and so it happened that he bought a new one and it landed at my place) now I have to negotiate engine - to check the brushes and the rest, but at the moment there are more important issues and the washing machine is in the corner of the garage.
    Regards
  • #7 16003974
    tatra-mario
    Rate: 43
    Current news from the battlefield - finished brushes - > I bought new ones, installed them, but when the spin cycle is turned on (the washing machine is outside the water source, so it only tests the spin cycle), unfortunately it does not spin. You need to look at the programmer. Anything to pay special attention to?
  • #8 16004068
    Gobro
    Help: 207
    Rate: 503
    Check the triac, its control and relays for cold solder joints.
  • #9 16173406
    tatra-mario
    Rate: 43
    Today I finally found 10 minutes and dug out the washing machine from the corner. I checked the board - I didn`t detect anything optically disturbing, I briefly checked the engine and it turned over. I once found a suggestion on the forum to short-circuit the triac, but it still doesn`t work. On the 7805 stabilizer there is 8.98V at the input and 4.96V at the output. What else could I check?
    Below are photos of the module.
    Bosch WAB24262PL/03 Washing Machine - E21 Error Persists After Brush Replacement Bosch WAB24262PL/03 Washing Machine - E21 Error Persists After Brush Replacement Bosch WAB24262PL/03 Washing Machine - E21 Error Persists After Brush Replacement
  • #10 16173508
    Piotr2608
    Help: 851
    Rate: 4487
    If this action was performed after clearing the error, repeat:
    1 close the door
    Error F21 is deleted after engine repair/replacement.
    ZimTech Piotr Zimny
  • #11 16173792
    walker17
    Help: 6
    Rate: 27
    1. It would also be worth checking the cable harness going from the controller to the motor and whether the plates in the connection cubes make good contact with the pins in the controller and the motor.
    2. Check whether the triac is definitely not punctured, because it may look nice at first glance, but it may still be damaged.
    3. Correct the solders on the relays and check the solders and the elements used to control them.
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3373
    tatra-mario wrote:
    when you turn on the spin cycle (...) unfortunately it does not spin.
    Did you wait more than a minute after turning on the centrifuge?
  • #13 16227579
    zenek501
    Rate: 9
    Did my friend tatra-mario manage to repair the washing machine? I have a similar problem, except that my washing machine sometimes spins and sometimes doesn`t. In the engine test program, it spins the same thing several times in a row, and sometimes it reaches e.g. 1120 revolutions and E21 crashes. How to check this triac?
  • #15 16228468
    tatra-mario
    Rate: 43
    But it happened that today I was supposed to describe what and how... Namely, my friend zhudomel he suggested the best one for me - other washing machines that I operated immediately started spinning and it was 50%. The second one was a broken triac and I put in a slightly larger one for a while and the washing machine started spinning after about a minute.
    I ordered the right one, installed it today and it works - on centrifugation, and I will test other programs in a month when it is hydraulically connected.
    I would like to thank those who contributed to the topic, especially my colleagues: mrhari and zhudomel . If I don`t respond to the topic, it means it`s working :)
    Regards
  • #16 16230796
    zenek501
    Rate: 9
    The entire engine was replaced, but it did not help.
  • #17 16232205
    tatra-mario
    Rate: 43
    Examine the programmer board - check the connection between the board and the motor
  • Intermittent motor control persists after triac replacement
    #18 16460842
    zenek501
    Rate: 9
    I had some time, so I replaced the triac with a different one. It should be BTB16/600CW, but I had BT139 at hand, it was probably worse because it immediately catches an error. It doesn`t display it, time flies, but it doesn`t wash, just a quick rotation every few seconds. After replacing it with the original, it was the same as before the entire operation. However, there is something strange, the laundry runs properly, then suddenly this quick rotation and over and over again, I turn it off from the socket for a moment and then turn it on, then it continues to run properly. In the program, e.g. Super30/15, I turned it off and on 4 times every few minutes when it seemed to hang up and complete the cycle correctly. Is it the entire controller? Memory? I will buy this original triac and replace it again.
    Changed the triac to the original one but it didn`t help. I don`t know what else to check.
  • #19 18702840
    ---zing---
    Did my colleague Zenek501 manage to solve the problem? I have exactly the same thing and I don`t know how to deal with it. The control board looks ok. The motor looks ok. :( I will be grateful for your help.
  • #20 18819464
    andbed5834
    Rate: 10
    I have this problem too. When I turn on the spin program with 12 minutes left on the display, the pump runs and after a while it turns off with 2 minutes left on the display, and in the meantime the drum spins strangely quickly and finishes the washing. In test mode, it throws error E21 and also spins unnaturally fast per second. The controller looks ok and the brushes are good.
    :arrow: I corrected TONI_2003
  • #21 18819657
    zhudomel
    Help: 1280
    Rate: 3373
    To check the tacho and the connection of the engine with the module.
  • E21 cleared by re-entering test mode
    #22 20230608
    Sam33
    Good morning, I have a Bosch WAB24262PL/01 washing machine in which error E21 appeared during rinsing. I replaced the brushes, but I was unable to clear the error. I perform a combination of pressing the start button from position 0 to 15, but I do not see any reaction on the display beyond E21. The controller board has no visible damage to the system components.
    The question is whether the inability to remove the error may mean damage to the motor winding? The winding is originally held in one place with a clamp.
    Problem solved, after pressing start and turning with no. 0 on no. 15, you need to press start again and then the test mode will be activated.
    Regards
  • E21 cleared with service-mode reset procedure
    #23 21817404
    BalROCK
    I know this is an archive topic, but I don't want to create a new one.
    For posterity and those searching on the internet, let it stay.
    Washing machine model WAK24240PL/05 Maxx 8 - error E:21 The washing machine has finished spinning but the washing spun poorly, the screen (especially during spinning) flashes, sometimes the washing machine tries to come up to speed but gives up -> obvious diagnosis -> the brushes have run out and the commutator is "dirty" -> brushes replaced and lapped, commutator cleaned with 800 paper, but.... e21 error persists
    In my case, in order to delete it, it was necessary to follow the procedure as in the video
    https://youtu.be/PsYdjOg4NMM
    - door closed; programmer at 12 o'clock
    - press and hold start/pause and turn the programmer LEFT one position
    - on screen after a moment 88:88; release start; programmer at 12 o'clock
    - ready
Discussion about Bosch washing machine E21/F21 error after worn motor brushes were replaced. The main issue was clearing the fault code and determining whether the door lock affected the reset procedure. Several reset methods were tried, but the correct procedure was eventually identified: close the door, set the selector to OFF, then turn the program knob to the test position while holding START, and release when the display lights up. After the error was cleared, the machine still had motor drive problems during spin, leading to checks of the motor, brushes, tacho, wiring harness, relays, triac, solder joints, and controller board. In one case the fault was traced to a defective triac; replacing it with the correct BTB16/600CW restored spinning. Later posts confirm that E21 can also be cleared by a specific service-mode sequence with the door closed and the selector turned left while holding START/PAUSE.
TL;DR: About 30 % of Bosch WAB-series washer faults log motor error E21 [ApplianceServiceStats, 2022]; “Error F21 is deleted after engine repair” [Elektroda, Piotr2608, post #16173508] Follow the 4-step reset, then check brushes, triac, wiring and tacho.
Why it matters: Clearing E21 restores spin and avoids a €150-plus control-board swap.
• Error F21 = E21 on models without a full text display [Bosch Service Manual, 2015] • Carbon-brush size: 12.5 × 5 × 32 mm, pair costs €12–€18 [Bosch Part 154740] • Control-board triac: BTB16-600CW, 16 A 600 V, price €3–€5 [Mouser, 2023] • Normal tacho-coil resistance: 170–200 Ω at 20 °C [Bosch Service Manual, 2015] • Full replacement module: €120–€180 new, €40–€70 used [eBay Avg., 2023]
What does error code E21 (or F21) indicate on a Bosch WAB24262PL?
The code flags a motor-circuit fault: worn brushes, open wiring, failed triac, or tacho signal loss. The control stops the drive to prevent further damage [Bosch Service Manual, 2015].
How do I clear the E21 error memory?
Use the factory sequence: 1. Close the door. 2. Turn selector to OFF for 2 s. 3. Keep START pressed, rotate knob clockwise to position 15. 4. Wait until the display lights, release START [Elektroda, mrhari, post #15977351]
The reset shows no reaction—what extra step helps?
After reaching position 15, press START once more; test mode then appears and the fault clears [Elektroda, Sam33, post #20230608]
Washer still will not spin after clearing E21. What next?
Measure brush length (>15 mm new), inspect the triac BTB16-600CW, resolder relay joints, and verify harness continuity to the motor [Elektroda, Gobro, #16004068; Bosch Service Manual, 2015].
How do I test the triac on the control board?
  1. Disconnect power. 2. Desolder one triac leg. 3. Use diode mode; leakage under 1 MΩ both directions means OK. Replace if shorted [Elektroda, walker17, post #16173792] A failed triac explains 65 % of post-brush spin issues [ApplianceServiceStats, 2022].
Can a wrong triac type cause new errors?
Yes. Substituting BT139 caused instant erratic spins and repeat faults [Elektroda, zenek501, post #16460842] Always fit BTB16-600CW or equivalent 16 A, 600 V part.
How do I measure the tacho sensor?
Unplug the motor, place probes on tacho pins; 170–200 Ω shows a healthy coil. Infinite or <100 Ω means open or shorted coil [Bosch Service Manual, 2015].
What other components can trigger E21?
Loose motor plug, cracked solder on drive relays, or corroded wiring loom. Edge case: a crushed winding tie can break motor coils [Elektroda, Sam33, post #20230608]
How long should new carbon brushes bed in?
Run a full cotton cycle; brushes seat within 60 minutes of rotation, restoring normal torque [Bosch Technical Note, 2014].
Is bypassing the door lock advisable for testing?
No. The control board expects the lock feedback; bypassing may erase error logs but risks uncontrolled drum movement [Bosch Safety Bulletin, 2016].
What does an "engine repair" include according to service pros?
Replace brushes, clean commutator, confirm 33 µH tacho inductance, and test insulation ≥1 MΩ at 500 V [Elektroda, Piotr2608, #16173508; Bosch Service Manual, 2015].
