SSD Disk Defragmentation is it a myth that it is not allowed?
spinacz66 19479 32
Can Windows 10 defragmenting an SSD shorten its life, and should SSD defragmentation be disabled?
An SSD does not need traditional defragmentation, and repeated unnecessary defrag operations can shorten its lifespan because they create extra writes; one accidental short run is not worth panicking about [#15289093][#15287228][#15292450] Windows 10 usually detects SSDs and uses “optimization” instead of classic HDD-style defragmentation, which is typically just a TRIM-related action [#15292297][#15296726] Fragmentation on an SSD does not meaningfully hurt access speed the way it does on an HDD because SSDs can access any area equally fast [#15286888][#15287363] Some replies note that filesystem metadata, MFT, or the swap file may still be optimized, so Windows may occasionally do maintenance on an SSD even though normal defrag is unnecessary [#15287663] The “System Reserved” partition is just the boot partition and does not need defragmentation either [#15287455]
  • #1 15286638
    spinacz66
    I have automatic defragmentation of disks turned on in win 10. And I did not even know that the system gave me the SSD drive C (where is the system) but it was unchecked (reserved by the system, it was unchecked in the system) and I have a question if this shortens the life of the disk or it can break because of this SSD I read various columns and most write that this is a myth because the new drives are resistant and should not be turned off in windows?
    quote from a column: "Of course, individual parts of the file on the disk may be fragmented and in the case of SSDs it will not drastically affect performance, but this fragmentation has its limits determined by metadata. When the maximum is reached, further attempts to write the file will cause errors. Defragmentation is so necessary to reduce the number of fragments and also keep the filesystem consistent "
  • #2 15286888
    310artur
    Help: 980
    Rate: 670
    For logic - defragmentation in the case of twisted algorithms used for this often repeatedly reading and writing files. It doesn't "corrupt" the disk, it consumes it. In SDD, access to the entire "surface" is equally fast. It doesn't really matter where the files are saved and in how many parts up to the aforementioned limit.
    In my opinion - defragmentation does not make sense. How do I know life when it is necessary win10 will do it anyway, regardless of the will of the user. After all, this system has a life of its own.
  • #3 15287049
    spinacz66
    I accidentally defragmented because I had the regular HDD marked in the system. Once today it only happened to me. Will SDD slow down after defragmentation and will it work the same as before?
    It consumes the so-called How many% could use my disk as I did it once, defragmentation did not last longer than 5 seconds?
    310artur
    Help: 980
    Rate: 670
    As much as installing one game or copying a movie, or updating the system ... How many read operations could he do in 5s? Several megabytes of data had been shoved through. Don't panic ... Defragmentation doesn't cut the disk. In fact, it could be and be active, but why if after defragmentation and before it works the same? After a long time, you will probably notice that the system with defragmentation turned on "consumes" the disk up to several% faster.
  • #5 15287355
    spinacz66
    All I have is a system and minor programs like daemon, winrar (no heavy), no games. I have a normal HDD for games, so there is only the system and when you write updates, I do not record anything there and do not delete it
    310artur
    Help: 980
    Rate: 670
    It's not exactly nothing. The truth is, the system is constantly reading and writing files. But that's why you just bought an SSD so that the system works quickly and efficiently. Don't worry about wear and tear to such an extreme degree, nothing is forever. It's just about not making nonsense. And the fact that you even install the game there ... Nothing bad will happen. You just have to judge if you want it. And so for each program. If you use something very often, you will run it faster with SSD (e.g. browser). That's what you got it for. Not that it only was and was of no use. HDD wears out too and eventually dies too.
  • #7 15287370
    spinacz66
    How do I enter the defragmenter and the options to change the disk, in addition to the SSD C drive (system) and regular HDD E, I still have a selection of the volume of the partition (without a letter) "reserved by the system", what is it for, I have unmarked it so that the system does not defragment it?
  • #8 15287414
    310artur
    Help: 980
    Rate: 670
    I don't want to hit my face and I don't remember what it's called. Windows from version 7 seems to create such a small partition during installation. He keeps his treasures there ;) . Nothing to worry about.
    mythbusters
    Help: 10
    Rate: 24
    This is typically 100 MB reserved for the boot partition to the system.
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    spinacz66 wrote:
    in addition to the SSD C drive (system) and the regular HDD E, I also have a selection of the partition volume (without a letter) "reserved by the system", what is it for, unmarked so that the system does not defragment it?
    This partition has a bootloader, if you have an SSD system then this partition is probably also SSD. Regardless of which disk it is located on, there is no need to defragment it.
  • #11 15287618
    spinacz66
    One more thing whether to uncheck SDD in the automatic defragmentation schedule so that it does not use up the disk faster?
    Dra98
    Help: 1321
    Rate: 1076
    Basically, an SSD does not need to be defragmented [even some manufacturers have recommended not to defragment.] In the case of SSDs, fragmentation will not have a particularly negative impact on performance.
    However, the file system - Metadata and MFT that is defragmented - may sometimes require it - e.g. conclusion - http://www.hanselman.com/blog/TheRealAndCompleteStoryDoesWindowsDefragmentYourSSD.aspx
    Personally, I would run \ run it manually from time to time.
    The screen shows% fragmentation on SSD Metadata, MTF or swap file [I have a constant fragmentation of 0%]
  • #13 15288977
    spinacz66
    On another forum I was told that file fragmentation on SSD affects performance, is that true?
    Can the system slow down after SSD defragmentation (loading, reading)?
    Or is it reading or writing large files?
  • #14 15289093
    310artur
    Help: 980
    Rate: 670
    paperclip66 do you understand generally what is disk fragmentation? I have the impression that you are asking, but you do not know the basic concepts. You use the word "efficiency" all the time, it is a magic parameter that sellers use to sell more expensive goods, otherwise of little use.
    Affects how? If anyway, it is negative at best
    Immediately after defragmentation, it can only accelerate imperceptibly. In the long run, frequent and unnecessary defragmentations will slowly but successively wear out the disk. This will shorten his life, will not affect his performance.
    I suggest starting your search for knowledge, however, from scratch. Read how an HDD works (how it is built, how data is saved, what mechanics it has), then read how an SSD is built. You will discover the strengths and weaknesses of the structure. Compare such parameters as transfer, random data access time. Then look for what file fragmentation is. If you understand it, you will stop thrashing, because now you are reading opinions on the forums but you do not understand them.
  • #15 15289205
    maurycy123
    Conditionally unlocked
    Help: 226
    Rate: 744
    http://www.pcworld.pl/news/383428/Dyski.SSD. Optalne.konfigurowanie.i.uzytkuje.html
    Read on. Especially point 6.
    Install yourself the program: SSD Fresh. It will show you what you have turned on and what is harmful to the SSD.
    Each write of a cell shortens its life (reading no). In the case of SSD disks, the access time is so short (compared to regular HDDs) that defragmentation does not make sense. Each defragmentation shortens the lifetime of the disk. But also let's not get paranoid. In normal use, the drive will last a long time. Before that, you will change the computer to a "better model".
  • #16 15289457
    arekb81
    Help: 135
    Rate: 746
    And it is not sometimes the case that Windows 10 does not defragment the SSD drive, only optimization, i.e. it is nothing else than sending a Trim command?
  • #17 15290319
    necavi
    Level 19  
    Help: 5
    Rate: 57
    spinacz66 wrote:
    All I have is a system and minor programs like daemon, winrar (no heavy), no games. I have a normal HDD for games ...
    This is what I had when I had a 64GB SSD. After switching to 128 GB, I keep all the programs on it, the difference when starting "big" games like WoT, WoWs - huge.
  • #18 15290442
    helmud7543
    Help: 1216
    Rate: 1564
    As for lifetime - SSDs have cells that can withstand a certain number of erases and writes. Therefore, each redundant entry is a very small, but still shorten life.
    As for the need to defragment SSDs, it is debatable. The drive has access to every memory area, so there will be no slowing down of work with fragmented files as in the HDD. However, a curiosity - Perfectdisk was shown here. In the newer version (and certainly in 12.5) it has an SSD optimization option. However, I have no idea what defragmentation algorithms are - it's definitely not the same as in HDD.
  • #19 15290482
    spinacz66
    This is a gaming machine only assembled last year, I have two computers to work with, so I do not have to load unnecessary ballast there. The fact is that I have a few games on SSD, but this is not a huge difference for me when loading levels, otherwise the system loads a few seconds here, and on an ordinary one, it took about 1min and 30s.
  • #20 15292297
    sylweksylwina
    Help: 1882
    Rate: 2355
    Windows 10 (I do not know about previous versions) automatically detects SSDs and the system disk defragmenter does not even allow to analyze the disk fragmentation, only optimization is possible that probably sends a trim command to the disk. Do not defragment the SSD as it reduces its lifespan.
  • #21 15292450
    deus.ex.machina
    Level 32  
    Help: 91
    Rate: 341
    Frequent defragmentation doesn't make much sense and can shorten SSD lifespan.
    Some defragmentation programs offer special SSD defragmentation algorithms.
    Unfortunately, it is impossible to completely ignore the problems related to NTFS (unfortunately this system is not immune to file fragmentation).
  • Defraggler selective defragmentation for heavily fragmented SSD files
    #22 15292751
    filipmagik
    Defragmentation on SSD should be run once a week for files over 100 fragments, unless they are larger than 1 GB then you have to accept it.
    As if about fragmentation, I recommend Deflaggler -> in it, first click "analysis" then "file list" and select these according to the above guidelines and click "defragment selected". It does not defragment unnecessary files and takes a very short time, about 10 seconds.
  • #23 15294169
    spinacz66
    What program can you check the life of an ssd and do such programs have to be installed on the ssd or can they be on another disk?
    maurycy123
    Help: 226
    Rate: 744
    SSD-Z. This will check the disk.
  • #25 15294932
    spinacz66
    A colleague will tell you in which tab to look for and what will be the name of this lifetime?
    SSD optimization runs TRIM, not traditional defragmentation
    #27 15296726
    rzymo
    Help: 206
    Rate: 322
    Now write which controller and SSD will allow you to divide the file into 100 or more chunks :) There are no such.
    Defragmentation on SSD is unnecessary. Anyway, in newer systems this option is called "defgrament i." optimization ", and has nothing to do with defragmentation as understood on the HDD, i.e. the physical transfer of data ...
    (almost always it comes down to running the Trim command).
  • #28 15296909
    spinacz66
    I understand that in win10 I did not defragment but optimization?
    Because when I enter, I am writing 3 days from the last start and in an ordinary HDD, otherwise defragmentation 0%
    sylweksylwina
    Help: 1882
    Rate: 2355
    Exactly ;)
  • #30 15297499
    spinacz66
    And does this optimization, like defragmentation, shorten the life of the disk?
The discussion centers around the necessity and implications of defragmenting SSDs in Windows 10. Users express concerns about whether automatic defragmentation affects SSD lifespan and performance. It is generally agreed that defragmentation is unnecessary for SSDs due to their architecture, which allows for equal access speed across the drive. While some argue that defragmentation can lead to wear from excessive write operations, others note that Windows 10 primarily performs optimization (like sending TRIM commands) rather than traditional defragmentation. Users are advised to monitor SSD health using tools like SSD-Z and SSD Life, and to be cautious with unnecessary write operations to prolong SSD lifespan.
TL;DR: Modern consumer SSDs survive 150–600 TBW host writes [Samsung, 2023]; Microsoft engineer Scott Hanselman says "defragmenting SSDs is generally unnecessary" [Hanselman, 2014]. Windows 10 schedules TRIM, not classic defrag, so leaving Optimization ON won't shorten life measurably. Why it matters: Understanding the difference stops needless write-wear and panic.
• Windows 10 runs “Optimize” (TRIM) weekly for SSDs, not full defrag [Microsoft Docs, 2022] • Typical home PC writes ≈5–10 GB/day to system SSD [TechReport, 2020] • One manual defrag adds ~1–3 GB extra writes [AnandTech, 2015] • Endurance rating: 250 GB SATA SSD ≈150 TBW; 1 TB NVMe ≈600 TBW [Samsung, 2023] • NTFS raises Event ID 257 if metadata exceeds ~1.5 million fragments, a rare edge case [Microsoft KB4005625]
Does Windows 10 actually defragment SSDs?
No. When Windows detects an SSD it replaces traditional defrag with the “Optimize” task, which merely issues the TRIM command and consolidates metadata, not data blocks [Microsoft Docs, 2022].
Will one accidental defrag session hurt my SSD?
A single 5-second pass moves only a few MB of data—similar to copying a small file—so the wear is negligible [Elektroda, 310artur, post #15287228]
Does file fragmentation slow an SSD?
Access time is almost uniform across flash cells, so typical fragmentation has <1 % impact on sequential reads [AnandTech, 2015]. Random reads remain unchanged. "Fragmentation hardly matters on flash" [Hanselman, 2014].
Should I disable scheduled optimization for my SSD?
Keep it on. Weekly TRIM keeps the free-block map tidy and adds minimal writes—roughly 0.5 % of monthly TBW consumption [Microsoft Docs, 2022].
What is the “System Reserved” partition and must I defrag it?
It holds the bootloader (≈100 MB). It sees few writes and never needs defrag or TRIM adjustments [Elektroda, dt1, post #15287455]
How can I check SSD health and remaining life?
Use SMART-reading tools such as SSD-Z or SSD Life. Look for attributes like “Host Writes” and “Percent Life Left” [Elektroda, maurycy123, post #15296562]
3-step How-To: Read SMART with SSD-Z
  1. Install SSD-Z on any drive. 2. Open the program and select the SSD tab. 3. Click SMART → read “Lifetime GB Written” and “Health” percentages [Elektroda, spinacz66, post #15298663]
How many writes can my SSD tolerate?
Consumer drives last until their rated TBW: 150 TBW for 250 GB SATA, 600 TBW for 1 TB NVMe. Lab tests show many drives exceed ratings by 2–4× before failure [TechReport, 2020].
Is there any scenario where defragmenting an SSD is useful?
Only when NTFS metadata or the MFT exceeds the fragment limit (~1.5 million). Then Windows may force a consolidation pass to avoid write errors [Microsoft KB4005625]. This is rare on normal desktops.
What is TRIM and why is it important?
TRIM tells the SSD which blocks are no longer in use so the controller can erase them in advance, sustaining write speed and reducing write amplification [Samsung, 2023].
Will defragmenting very large files (>1 GB) help game load times?
Tests show no measurable gain on SSDs; sequential throughput remains bottle-necked by interface speed, not file contiguity [AnandTech, 2015].
Does optimization harm the drive like defrag could?
No. Optimization sends metadata and TRIM commands, writing only a few KiB. Wear impact is statistically insignificant compared with daily OS writes [Microsoft Docs, 2022].
Edge case: What happens if SSD cells wear out?
When spare blocks are exhausted, the SSD turns read-only or throws SMART error E8/E9. Plan backups; failure often occurs suddenly after the warning [Samsung, 2023].
