Impedance in Speakers: How Does It Affect Audio Quality and Performance?
boruta_m 68914 14
How does speaker impedance affect the power an amplifier delivers and the speaker’s sound?
Speaker impedance is the speaker’s opposition to alternating current, and it changes with frequency because the loudspeaker contains a coil [#1580123][#1580206] In a normal voltage-driven amplifier, higher impedance means less current flows, so the amplifier delivers less power at that frequency [#1580123] A 4-ohm speaker will draw more current than an 8-ohm speaker at the same voltage [#1580162] That is why amplifiers are specified for particular loads, such as 100 W at 8 ohms or 400 W at 4 ohms, and connecting a different impedance can reduce output or overload the amplifier [#1580206][#1580123]
  • #1 1580026
    boruta_m
    I wanted to know what impedance is. I searched on google but did not find a satisfactory answer. I know this is resistance, but I don't know how it relates to the sound produced by the speakers.
    Thanks in advance for your help
  • #2 1580087
    F4T4L
    Help: 6
    U = Z * I
  • #3 1580117
    Masster
    Level 32  
    Help: 156
    Rate: 46
    F4T4L wrote:
    (...) so the greater the impedance, the greater the power ...
    No offense, but you print stupid things, impedance is the resistance to the wave, that is for the variable component. Z = 1 / RW in audio equipment, the higher the impedance, the less current will flow from the amplifier and therefore less power will be distributed.
  • Voltage-driven amplifiers deliver less power into higher impedance
    #4 1580123
    gzeho.p
    Rate: 15
    We can say that impedance is the equivalent of resistance, but for alternating current (you can probably say so) the resistance in the case of direct and alternating current is constant and the impedance depends on the frequency of the signal.
    I think that it cannot be said that the higher the impedance, the greater the power (in the case of standard audio equipment), theoretically it is so, but in practice the audio equipment is not current-coupled, but voltage-coupled (I mean the signal waveform is the voltage, not the current), and therefore in the case of a normal amplifier, the increasing speaker impedance with the frequency will reduce the value of the current flowing through the loudspeaker and therefore the power output by this loft.
    Regards
  • #5 1580135
    boruta_m
    OK thanks
  • #6 1580151
    k3048
    Level 37  
    Help: 515
    Rate: 281
    I see. So if I have a loudspeaker with a power of 300W and an impedance of 8? and 4?, this 8? will be stronger?
    no
  • #7 1580162
    Masster
    Level 32  
    Help: 156
    Rate: 46
    As for the current, the 4? speaker will withstand a larger one (it will flow through it) at the same voltage.
  • Lower impedance doubles power but may damage amplifiers
    #8 1580181
    gzeho.p
    Rate: 15
    Well, not necessarily because:
    If the amplifier is 300W 8 ohms, you will have 300W of power on an 8 ohm speaker, and on a 4 ohm speaker, it will be around 600W, but you will burn the amplifier.
    Which speaker to use depends only on what the amplifier is designed for, if you have an 8 ohm amplifier, you cannot connect a 4 ohm amplifier because you will burn the amplifier, and again if you connect an 8 ohm speaker to the 4 ohm amplifier, you will have only half the power.
    Pyroaniah
    Help: 118
    Rate: 30
    Not all of them are stronger ... ehh ..
    1. Whether a speaker is 4 or 8 ohms does not change the amount of heat it can dissipate
    2. the amplifiers are voltage-controlled, i.e. they are controlled by the power resistance. That is why the amplifier says: 100w 8ohm (home) or 400w 4ohm (rather already on stage)
    This is how much each amplifier will deliver with this number of ohms.
    Connecting differently than it is adapted is pointless because a.you burn it b.it will give half power (for gzeho)
    And impedance is the resistance to alternating current. It is not equivalent to resistance because the loudspeaker has a coil, and as you probably know the coil is an active element for alternating current (audio)
  • #10 1580219
    boruta_m
    thanks for all now i know
  • #11 1580256
    glen1
    and I have a question, if I have an amplifier that has 8ohm at the speaker outputs, is there a risk of damaging any of the equipment by connecting the 6ohm?
  • #12 1580269
    Pyroaniah
    Help: 118
    Rate: 30
    What kind of amplifier is it? if this is a Prlowish box, it has no prolem, like a Chinese mini-tower, do not turn the knob above 2/3 of a turn and it will be approx.
  • #13 1580272
    glen1
    thomson dpl-560 receiver and want yamahy nsp-110
  • #14 1580380
    Pyroaniah
    Help: 118
    Rate: 30
    Considering that it is quite powerful equipment, I would not risk it, or I would count the exact volume at which the thomson volume knob is set at 6 ohms and will give its 300w. And he marked it as max on the knob, of course. Ev. interfering with the amplifier itself and the use of an additional resistor will prevent an "accident"
  • #15 1580505
    tomaszo
    Help: 139
    Rate: 100
    Everything is clear ... I close.
Impedance is defined as the resistance to alternating current (AC) and is a crucial factor in audio equipment performance. It differs from direct current (DC) resistance as it varies with signal frequency. Higher impedance speakers (e.g., 8 ohms) draw less current from an amplifier compared to lower impedance speakers (e.g., 4 ohms), which can lead to higher power output at lower impedance but risks damaging the amplifier if not designed for it. The relationship between speaker impedance and amplifier power output is critical; for instance, a 300W amplifier rated for 8 ohms may output around 600W at 4 ohms, but connecting mismatched impedances can result in equipment damage or reduced performance. Proper matching of speaker impedance to amplifier specifications is essential for optimal operation.
