Is Thawed Frozen Paint Still Usable for Painting an Extension?
radarek12 26604 6
  • #1 15302982
    radarek12
    Help: 11
    Rate: 31
    I wanted to start painting the extension, but I realized that I had brought frozen paint.
    I would like to ask if the paint is still usable after thawing?
  • #2 15303005
    robokop
    Help: 1763
    Rate: 6376
    Defrost and try. In most cases, there is a frost warning on the packaging?
  • #3 15303245
    yogi009
    Help: 850
    Rate: 2658
    The title of the post suggests a completely different problem :-)
  • #4 15303374
    telecaster1951
    Help: 829
    Rate: 818
    It depends on the paint.
  • #5 15303393
    radarek12
    Help: 11
    Rate: 31
    Taka:
    Link
  • #6 15303412
    telecaster1951
    Help: 829
    Rate: 818
    To be thrown out. Once thawed you will have water on the top and pigments on the bottom. You won`t disperse it.
    In January?
  • #7 15306658
    radarek12
    Help: 11
    Rate: 31
    In January?
    Yes, I have a fireplace and underfloor heating there. I`m going to set up a workshop.
    Thanks for the help.
The discussion revolves around the usability of thawed frozen paint for painting an extension. Responses indicate that the usability of the paint depends on its type. Some users suggest defrosting and testing the paint, while others warn that once thawed, the paint may separate, with water on top and pigments settled at the bottom, making it unusable. A user mentions having a fireplace and underfloor heating, indicating plans to set up a workshop for painting.
