Choosing between PEX/AL/PEX, PERT/AL/PERT & PP-R SDR: High-Temperature CO, Reusable Joints
janek224 19617 6
  • #1 15724416
    janek224
    Which plastic pipes are best for high-temperature CO installation? Which ones can stand cooking the longest?
    Can PEX-Al-PEX bolted joints be twisted and unscrewed many times? Do you need to replace an o-ring, a piece of pipe or maybe even the entire fitting with every twist?
    Regards
  • #2 15724864
    mitsurugi
    After boiling, all three types are suitable for the garbage can.
  • #3 15724914
    janek224
    I don't know, the water in my CO boils at about 110 degrees and the manufacturers of these pipes say that they allow short-term operation up to 110 degrees. If the plastics were so weak, the cooling systems in cars would be copper ...
  • #4 15724919
    mitsurugi
    only that this "work" can be one-off, because the structure of molecules bonds changes in them.
  • #5 15724929
    janek224
    at what temperature for different types of plastics?
  • #6 15724936
    mitsurugi
    this question is for chemists
  • #7 15725460
    piotr_boncza
    Radiation cross-linked pexc pipes are the most resistant. Pe-HD and PERT are weaker, so they are often used for outer layers. The method of producing pipes is also of great importance, whether the alu tape is butt-welded (best) by laser, welded, overlapped and crimped, and the adhesive joining the individual layers. So the claim that all alupexes are the same and differ only in price is ... worth it.
    Especially with twisted connectors, I would recommend better grades, as pert and hd tend to flow under the influence of long-lasting force, which can weaken the connections. I use weaker and cheaper types only with the investor's full awareness, only for underfloor heating. It has low parameters and connections only at the distributor. The only risky place is when going through expansion joints, so you need to carefully build them and keep an eye on the floor.
✨ The discussion centers on the suitability of various plastic pipes for high-temperature carbon monoxide (CO) installations, specifically PEX/AL/PEX, PERT/AL/PERT, and PP-R SDR. Participants express skepticism about the durability of these materials under high temperatures, with some suggesting that all three types may not withstand boiling conditions. It is noted that radiation cross-linked PEX pipes exhibit the highest resistance, while PERT and PE-HD are considered weaker and often used for outer layers. The method of production, particularly the quality of aluminum tape welding, significantly impacts performance. Concerns are raised about the longevity of bolted joints in PEX-Al-PEX systems, with recommendations for using higher-grade materials to prevent failure under sustained pressure. The discussion highlights the importance of careful installation, especially at expansion joints.
