Paint Drying Time: Metal & Wood Surfaces in 5-10°C Garage Conditions, Overdiluted with Solvent
pawel1162 51874 19
How long will metal and wood paint dry if it was thinned too much and applied in a 5–10°C garage?
At 5–10°C, the paint can take several days to dry, especially if it was overdiluted with solvent. Most paints are only rated down to about 5°C for application, and the drying times are usually specified at 20°C or higher [#8792607] Low temperature and high air humidity can extend drying time a lot, in extreme cases to several days [#8985761] If you want it to dry faster, warm the garage a bit; otherwise just wait [#8792635] Wood usually dries faster than metal because it absorbs the paint better [#8792582]
  • #1 8792558
    pawel1162
    Rate: 9
    Hello, I have a problem. I painted a few things with one paint for metal and wood, I painted metal. Yesterday I was painting and today it is sticky in the garage it is about 5-10 degrees Celsius how much the paint can dry I added a little too much solvent but please write down how much the paint can dry in such conditions.
  • #2 8792582
  • #3 8792607
    Błażej
    Help: 1923
    Rate: 3625
    The colder the longer. On most paints, the lower application temperature is just 5 '. So don't be surprised. And the drying parameters are given for a temperature of at least 20'C.
  • #4 8792611
    pawel1162
    Rate: 9
    oh, so I have to wait and do nothing and how much can it dry up because I added too much solvent a little and I have a low temperature in the garage
  • #5 8792635
    Błażej
    Help: 1923
    Rate: 3625
    Then heat up this garage a bit and it'll dry up faster. And it will dry as much as it takes. At this temperature, a good few days ...
  • #6 8792654
    pawel1162
    Rate: 9
    I have one more question, what would happen if I put the elements on the field and sat them with frost
  • #7 8792907
    balonika3
    Help: 1334
    Rate: 3754
    With this frost, it's an inflection, but in general, the longer something dries, the more durable it is. Compare oilseed oil to those spray inventions - scratchable with your fingernail.
  • #8 8792911
    pawel1162
    Rate: 9
    ok thanks for the answer
  • #9 8831378
    barubar
    Help: 35
    Rate: 187
    Balloon and buy me some oil paint now ...
  • #10 8831414
  • #11 8831504
    barubar
    Help: 35
    Rate: 187
    Emolak is based on phthalic resins and not on Jurek air-drying oils. :D
  • #12 8831794
    Doominus
    Help: 163
    Rate: 390
    Phthalic paint.
    I painted it twice, it's a pity that I can't say the first and the last: /
    Nitro, polyurethane drying time a few minutes and another layer can be fully cured for 24 hours.
    However, when dealing with polyurethane, the varnish must dry well.
    He paints the wood.
  • #13 8985761
    Doradca Techniczny
    Low temperature plus high air humidity significantly extend the drying time (in extreme cases it may even take several days). Therefore, it is important to follow the manufacturer's recommendations and paint in favorable conditions. Ideally, the temperature should be in the range of 20 +/- 2 degrees and the humidity should not exceed 55 +/- 5%. Another reason may be the wrong solvent and too quick application of successive layers one after another (the first one will not have time to dry and the second is already being applied). When we paint in conditions worse than the above, the drying time is longer and therefore the next layers must also be applied at longer intervals.
    Ryszard Frycowski
    Technical Advisor of Tikkurila Polska SA
  • #14 8985810
    ogur3k
    Help: 170
    Rate: 159
    Counselor, applause for his reflexes, I suspect that this paint has already dried up for these ~ 14 months :)
  • #15 8985920
    Afcht
    Level 30  
    Help: 32
    Rate: 82
    What 14 months? They didn't teach at school to add?
  • #16 8986710
    ogur3k
    Help: 170
    Rate: 159
    Aaaargh, my fault, oh this New Year's Eve, I think he's still holding me ... ;)
  • #17 18405466
    mathun
    Rate: 22
    Personally, I would check the expiration date of the paint first. I usually don't check the date before painting, but when something doesn't dry, it turns out later that I used a very old paint. Things were able to dry in record for a few weeks.
  • Oven drying at 60°C speeds metal paint curing
    #18 19612479
    jacekggg321
    Hello, I had to register on your electrode forum - to tell my colleague what to do to make the paint dry faster, on metal.
    Below, I read the posts of my colleagues - but they were somehow unhelpful to solve the problem - I had the same problem - the oil paint did not want to dry on the metal casing of the ceiling lamp.
    And I solved this problem by putting the case in the oven, set to 60 degrees - for fifteen minutes, turning on the air circulation every now and then.
    The effect was that after half an hour, the lamp housings were dry and dried up - intuition worked, so do powder painters.
  • Oven drying at 60°C for 15 minutes
    #19 19612553
    viayner
    Help: 1563
    Rate: 2052
    jacekggg321 wrote:
    ... And I solved this problem by putting the casing in the oven, set to 60 degrees - for Fifteen minutes, turning on the air circulation every now and then.
    - as for solving the problem, it is relative because you destroyed the oven, probably no reasonable person will use it for food purposes after such an operation. Nevertheless, it is one of the right ways - to increase the temperature.
  • #20 19614065
    r103
    Level 37  
    Help: 283
    Rate: 967
The discussion revolves around the drying time of paint applied to metal and wood surfaces in a garage with temperatures between 5-10°C, particularly when the paint has been overdiluted with solvent. Users share experiences indicating that lower temperatures significantly extend drying times, sometimes taking several days. Recommendations include increasing the garage temperature to expedite drying and ensuring proper application techniques to avoid issues with stickiness. The importance of following manufacturer guidelines regarding temperature and humidity is emphasized, as well as checking the paint's expiration date. One user suggests using an oven at 60 degrees Celsius to accelerate drying, although this method may damage the oven for food use.
