TV with built-in power supply and additional antenna power supply
cysiu997 39099 10
Can I use an external antenna power supply with my Samsung 43J5500 TV, or should I rely on the TV’s built-in antenna power feed?
If the TV already supplies voltage to the antenna input, you do not need an extra power supply; just make sure the voltage matches the antenna amplifier, and if the amplifier is not needed you may be better off without it [#15316416] Samsung G/J series TVs are reported to support antenna power feed, and the on/off setting can be hidden deep in the menu [#15322396] If you do use a separate antenna power supply, it is the type with a separator, meant to feed the antenna amplifier rather than the TV input directly [#15316629] Several replies also suggest testing without the amplifier or using only an impedance transformer, because in strong-signal areas an amplifier can overload the setup [#15320526][#15321374] An example from another TV model shows the antenna feed marked as 5VDC-60mA, with the option to switch it on and off in the menu [#15322379]
  • #1 15316113
    cysiu997
    Hello everyone. I would like to know if I can connect an additional antenna power supply because the Samsung 43J5500 TV model, from what I found out, has its own power supply on the antenna, probably 5V. I have a mesh antenna installed on the roof at a height of about 5 m, and the cable from the antenna to the TV is about 15 m. When connecting the antenna without a power supply, theoretically it should not receive any channel and it searches for 13 channels, most of which are cut off. However, when connecting the old DVB-T overmax tuner, the tuner without a power supply does not find any channel, while after connecting the 12V power supply, there are 22 channels and everything runs smoothly. Can connecting such a power supply to a new TV damage the system or burn out the electronics? I will add that in the TV settings there is no option to enable / disable the antenna power supply
    TV with built-in power supply and additional antenna power supply TV with built-in power supply and additional antenna power supply
  • #3 15316416
    niewolno2
    Level 40  
    Help: 628
    Rate: 1255
    If the TV set has the ability to supply voltage to the antenna input, there is no need to install an additional power supply. The most important thing is the voltage value of the TV set and the voltage of the possible amplifier in the antenna and whether it is needed, you did not specify your location in relation to the transmitter because it may turn out that the amplifier is not needed and everything will run on the basic installation.
  • #4 15316629
    andpol 33
    Help: 513
    Rate: 1145
    After all, the power supply for the grid is with a separator.
  • #5 15317883
    LeDy
    Help: 1989
    Rate: 2930
    There is nothing to think about, connect the power supply from the mesh antenna and watch. Programs should be 24 .
  • #6 15319026
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Possibly the MUX-L local might catch something ;)
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #7 15320526
    sosarek
    Help: 9318
    Rate: 15512
    Discard the amplifier, put on the impedance transformer for a test.
    Z
    Pka, Poznań, 60-850
  • #8 15321374
    irekr
    Help: 1192
    Rate: 1238
    I am inclined to throw away any amplifiers.
    You don't write where you live, but if it's Zielona Góra and its vicinity, then MUX3 at k.32 is very strong there.
    In addition, there is 2.5 kW lighting on Ptasia, and this must completely distort any amplifier in the whole of Zielona Góra and its vicinity.
    The TV you have is one of the newest from Samsung and is known to have very high antenna / cable requirements. Virtually any signals greater than 1 mV must wreak havoc.
    If you receive anything with the power supply disconnected from the antenna, it means that the signal must be at least 10 times stronger, even without the amplifier.
  • #9 15322379
    kazikszach
    Help: 513
    Rate: 1100
    If what the author writes about the power supply for the antenna amplifier built into the TV set is true, it must be possible to turn this voltage on and off in the menu.
    In the Medion MD 30200 tv, which has this option above the antenna socket, there is a clear description: 5VDC-60mA and in the menu it is possible to turn this voltage on and off.
  • #10 15322389
    LeDy
    Help: 1989
    Rate: 2930
    So far, I have not encountered TV power supply for an antenna amplifier and it is logical for me.
  • #11 15322396
    irekr
    Help: 1192
    Rate: 1238
    All Samsung G and J series have the ability to feed power to the antenna input. In fact, the tab for turning the voltage on and off is quite deeply hidden in the menu.
    Now I do not have any Samsung at hand to lead "by the hand" and give the path.
✨ The discussion revolves around the Samsung 43J5500 TV model and its capability to supply power to an antenna. The user inquires about the possibility of connecting an additional antenna power supply, given that the TV likely provides a 5V output for the antenna. Responses suggest that if the TV can supply voltage, an additional power supply may not be necessary. Some participants recommend measuring the voltage output and checking the TV settings, as the option to enable or disable the antenna power supply may be hidden in the menu. Others advise against using amplifiers, citing strong local signals that could interfere with reception. The consensus is that the TV should be able to handle the antenna's power requirements without additional supplies, provided the signal strength is adequate.
