300Mb Fiber Connection: ASUS RT-N65U Wireless-N750 Router, Speed Test Shows 48Mb & 20Mb on Laptops
Msrtin 28572 11
Why does my 300 Mb fiber connection only reach about 48 Mb on one laptop and 20 Mb on another over Wi‑Fi, and how can I improve the speed?
Your Wi‑Fi is the bottleneck, not the fiber line; 300 Mbit/s on the router is often only realistic in ideal lab conditions, while about 100 Mbit/s or less is common in practice [#15353264] To improve it, use the 5 GHz band, avoid 2.4 GHz, and make sure the adapter supports 2x2 MIMO and a 40 MHz channel [#15353264] The Intel Wireless N7260 is dual-band and should see 5 GHz, but the Dell Wireless 1704 is 2.4 GHz only, so that laptop cannot use 5 GHz without replacing its Wi‑Fi card or using a suitable USB adapter [#15354828][#15355245][#15356691] If you only have 100 Mbit ports/cards, wired tests around 90 Mbit/s are normal, and to get close to 300 Mbit/s you need gigabit Ethernet or faster Wi‑Fi hardware such as AC [#15353450][#15357991]
  • #1 15352965
    Msrtin
    I have 300Mb fiber connected. The speed test on the laptop shows 48Mb. I was updating my network card. ASUS RT-N65U Wireless-N750 Dual-Band 300 + 450Mbps router. On the second laptop it only shows 20Mb. What is it to blame and how can I improve my results?
    Thank you in advance for your help
  • #2 15352996
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Hello. What results does speedtest show after connecting the laptop with a cable to the router? What models of network cards (WiFi) are installed in these laptops?
  • #3 15353024
    Msrtin
    The results are better after the cable. On both pages, download and upload 90Mb each. Intel Wireless N7260 card on one and Dell Wireless 1704 on the other. Like the 90Mb cable, but it's still 3 times less than it should be. So what to do to improve the results via WIFI.
  • #4 15353076
    hermes-80
    Help: 1177
    Rate: 743
    What ETH card do you have in your laptop - maybe 100 Mb / s?
    ISP bandwidth works on cables, not WIFI - wifi is a lame medium as you just found out.
    m.jastrzebski
    Help: 679
    Rate: 865
    Do not expect any miracles. As they write 300mbit on the WiFi router, expect in practice around 100mbit or worse.
    To get the most out of WiFi:
    - you mess with the channels, you scare the neighbors
    - you use 5Ghz you avoid 2.4Ghz
    - make sure that your computer's network card can use the fastest operating mode, i.e. MIMO 2x2 (two transmitting and 2 receiving antennas) and a 40Mhz channel. Sometimes you have to bury in the driver settings to force some things. Then you have 100mbit chances a bit more / less on WiFi.
    300mbit are ladies in the laboratory, on WiFi AC, with an 80Mhz channel.
    smario11
    Help: 140
    Rate: 120
    If you only have laptops with 100Mbit ports, you only have to replace laptops with new, better ones. You can combine with the router in AC, but the wifi cards in laptops also need to be replaced with AC. The cost is quite high.
    100Mbit over wifi is quite real, if you want 300Mbit, you need to connect with a cable and have a gigabit card
  • #7 15354294
    Msrtin
    Thanks for the answers. I have an asus 2.4 / 5ghz. up to 2.4ghz there is a different ssid and up to 5ghz it is different and wifi only sees ssdi with a frequency of 2.4ghz. How to change to 5ghz?
  • #8 15354828
    dt1
    Help: 7315
    Rate: 8292
    This card should see the 5GHz network. It is a dual band card and supports both 2.4GHz and 5GHz.
    Msrtin wrote:
    Dell Wireless 1704
    This card should not, because it is an 802.11bgn card that works only on the 2.4GHz band.
  • #9 15355239
    Msrtin
    I was looking in the card settings to help her see 5ghz, I found nothing. Maybe someone knows what to do to make the card see 5ghz?
  • 2.4 GHz-only Wi-Fi card limits 5 GHz and speeds
    #10 15355245
    m.jastrzebski
    Help: 679
    Rate: 865
    That is not possible! The radio module is designed to receive only 2.4Ghz. You won't change it with the settings.
    You would have to replace the WiFi card in the computer. But there are antennas connected to the card (usually hidden somewhere behind the screen). It may be that the antenna itself will not work at 5Ghz, even if the card can.
    Another problem, it may be (and this is suggested by the speed of 20mbit) that you only have 1 antenna there, then from 300mbit you will be 150mbit both ways, i.e. max 75mbit. In practice, if 60mbit will come out, it will be a success.
  • #11 15356691
    Msrtin
    OK thanks. Would it help to buy a usb network card so that it could support at least 5ghz? Maybe you recommend something?
  • #12 15357991
    dt1
    Help: 7315
    Rate: 8292
    Give more models of wired network cards on which you are testing the connection. It is also worth doing the test by connecting without the router - directly to the operator's access device. However, it is worth doing such a test with a GbE (1000Mbps) card.
The discussion revolves around a user experiencing suboptimal WiFi speeds on laptops connected to a 300Mb fiber connection via an ASUS RT-N65U Wireless-N750 router. Speed tests reveal 48Mb and 20Mb download speeds on two laptops, despite achieving 90Mb when connected via Ethernet. The conversation highlights potential issues such as outdated network cards (Intel Wireless N7260 and Dell Wireless 1704), limitations of WiFi technology, and the importance of using dual-band capabilities. Suggestions include switching to the 5GHz band for better performance, ensuring network cards support MIMO technology, and considering USB network adapters for improved connectivity. The need for gigabit Ethernet cards for optimal wired connections is also emphasized.
