Man TGL 12.250 - error 3257, 3650, 3209, 3519, 3207, 3522, 3002
panfil.lukasz 54492 17
What is causing the MAN TGL 12.250 EBS fault codes 3257, 3650, 3209, 3519, 3207, 3522, and 3002, and what should I check first?
These fault codes are all related to the EBS system, so one common problem is likely affecting multiple components [#16372873] Check the EBS wheel sensors on both sides for resistance, damage, and wiring faults, and inspect the impulse rings in both hubs for damage, corrosion, bends, or rust in the sensor gap [#16373625][#16373766] Also check for play in the hubs, because worn bearings can increase the gap between the sensor and the impulse ring [#16373625] Inspect the EBS socket and trailer/tractor cable for abrasion and corrosion, especially if the connector is green, and repair or replace it if needed [#16373625] Since the brake discs and pads were replaced, also check the brake pad wear sensors and their wiring, because the work may have damaged a ring or sensor during installation [#16373625][#16373766]
  • #1 16372409
    panfil.lukasz
    I'm having trouble with bugs in Man TGL 12.250. Errors 3257, 3650, 3209, 3519, 3207, 3522, 3002, probably several of them are from one fault, but I don't know which one exactly.
  • Corrected definitions for EBS fault codes 3257, 3209, and others
    #2 16372873
    darfur5
    Help: 267
    Rate: 1715
    Mistake:
    3257 - applies to EBS, pressure control module, rear axle right; impulse ring error
    3209 - pressure regulation module, rear axle on the left; no valid definition
    3207- pressure regulation module, rear axle on the left; impulse ring error, left wheel sensor
    3002 - damaged control device; unknown uC interrupt, timeout during data exchange, uC active or passive
    3519 - Wheel rotation sensor, error during the last connection cycle
    3522 - diagnostic mode active
    3650 - CAN semi-trailer interface, partial or complete failure of the tractor-semi-trailer interface.
    All errors are related to EBS.
  • #3 16373002
    panfil.lukasz
    Thanks a lot. What can I do with it or replace it?
  • #4 16373490
    darfur5
    Help: 267
    Rate: 1715
    Such a flood of errors concerning one system is probably not a coincidence. What has been done so far?
  • #5 16373540
    panfil.lukasz
    Discs and pads replaced.
  • #6 16373625
    darfur5
    Help: 267
    Rate: 1715
    Check:
    - EBS sensors for resistance and damage on both sides, right / left
    - wires of these sensors for damage, abrasions, breaks
    - impulse rings in both hubs, whether they are not damaged, crooked, corroded
    - there are no play in the hubs, because maybe the bearings are ending and thus the gap between the sensor and the impulse wheel has increased
    - EBS socket and cable semi-trailer - tractor for abrasions and corrosion, if the EBS socket or plug is green, it must be repaired / replaced.
    That's it for the beginning. Oh, and check the brake pad wear sensors and their wiring.
  • #7 16373732
    panfil.lukasz
    Thank you very much, I'll check it tomorrow and let you know.
  • #8 16373766
    darfur5
    Help: 267
    Rate: 1715
    By my understanding, when removing or installing the brake disc, you damaged the pulse generator ring or you did not clean it with a wire brush. If rust gets into the pulser wheel gap, the sensor will read it as an error or even if you accidentally treated the ring with a hammer, the effect will be the same.
  • #9 18211617
    Han18
    Rate: 29
    I have a problem with the EBS 3522 error and I do not know where to look for the cause.
  • #10 18212733
    darfur5
    Help: 267
    Rate: 1715
  • #11 18213256
    Han18
    Rate: 29
    I know, I read it before and my point is that I don't know where to look for the cause of this error.
  • #12 18213970
    darfur5
    Help: 267
    Rate: 1715
    Plug in your computer, preferably MAN Cats, and you'll know where the cause is. The scope of this error can be extensive.
  • #13 18213996
    Hektar Zahler
    Help: 230
    Rate: 528
    To my eye, the controller under the pedal (burnt?). Were there any adventures with the so-called boot device? Any visible symptoms? Check that the brake lights do not go out sometimes.
  • #14 21273279
    Fordos84
    Fault EBS: 03012-03. (MAN 12-240, 2006, Euro3 motor) The fault was deleted, but half sec come back it again. What can be the problem? How can I repair it? Maybe you can help me. Thank you.
  • #15 21274015
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    The EBS module (A402) is to be replaced. There is probably moisture inside.
  • #16 21292789
    Fordos84
    >>21274015 In this car, the EBS module is not the one with the blue connector, and it is not in front of the right seat among the other electronics. But it's on the back of the brake pedal air valve and it's black colored. In principle, it has to be reprogrammed... and I'll let you know how it ended.
  • #17 21293449
    ROKADI
    Help: 43
    Rate: 194
    SPN 3012 Parameters EEPROM, control device, electronic brake system
    (EBS)
    Monitoring strategy
    Customer perception/ description of symptoms
    Central warning lamp permanently illuminated in red while the vehicle is moving and stationary
    Failure Mode Identification (FMI)
    FMI 3 Unreliable
    Display
    Priority 2 Text
    indication
    Probably needs to be programmed
    ROKADI - MAN
    Kętrzyńskiego 8, Olsztyn, 10-506 | Tel.: 660-XXX-XXX (Show)
  • EBS computer in brake pedal valve caused errors
    #18 21341924
    Fordos84
    Problem solved! Thanks for the helpful advice! Yes, the EBS computer electronics were at fault: The previous owner replaced the brake pedal valve. In this type (12.240 / 2005), the EBS computer is in this brake pedal valve. (A black flat part on the back of the valve.) So not in its usual place in front of the right front seat in the drawers. The entire software was re-adjusted with the factory MAN diagnostic computer. The error is gone! I am happy! Thank you for your help!
The discussion revolves around multiple error codes (3257, 3650, 3209, 3519, 3207, 3522, 3002) encountered in a MAN TGL 12.250 vehicle, primarily related to the Electronic Braking System (EBS). The errors indicate issues with pressure control modules, wheel rotation sensors, and the CAN interface. Users suggest checking EBS sensors, wiring, impulse rings, and the EBS module for damage or corrosion. A specific case highlights that the EBS computer is integrated into the brake pedal valve, which may require reprogramming after replacement. The resolution involved using the MAN diagnostic computer to adjust the software, eliminating the errors.
